Question about Roland Pd 8 Dual Trigger Pad
The cable assigned to my roland TD 4 mesh snare is not registering. I thought it a cable problem so a replacement was shipped however still the same prblem. I have ensured the settings are right so I'm thinking its the module. When I use the extra 3rd crash cable it works so it's not the snare. Any other possibilities?
    President:
  • 1,138 Answers
You may have a bad solder joint where the jack for the snare trigger input is soldered to the circuit board. You will have to open the case and have a look. Make a note of how many screws and where they go etc. If you have a digital camera, take pictures as you go. We have a TD3 and it has two circuit boards one on top of the other.
Posted on Nov 11, 2010
FCan get my Ipod to play through my Roland TD-20 Mudule
You need to get yourself a cable - with a 3.5mm male jack plug on one end (which will fit into your ipod), and a 1/4 inch male jack plug on the other end.
(you could use a lead with a 3.5mm male plug on each end, and used a 3.5mm female to 1/4 inch male adaptor to achieve this)
Connect the 3.5mm end into the ipod - play a track, with the volume at say, 75%.
Connect the 1/4 inch end of the cable to the 'Mix In' input in the back of your TD20.
Use the 'Mix In' control - at the top right hand side of your TD-20 module to control the volume.
If you wish only to have the iPod going to (for example) headphones - and not Front Of House (PA) speakers - which you will have connected via the Master and / or Direct Out(s); this can be achieved in the 'Mixer' settings (accessed via pressing the 'Mixer' button).
Oct 22, 2012 | Roland TD-20X V-Drum Sound Modul
Where does hihat control cord go
The hi-hat trigger goes into trigger #1. Using a footswitch will change the hi-hat trigger sound to a closed hi-hat. On page 8 of the user manual is the list of triggers and their assignments. Note that some new triggers from newer drumsets use TRS cables because they have two sensors within the drum head... Often the new ones have a rim shot snare trigger as well as a trigger for the mesh head. These newer different brand triggers would require special cables to be made to attempt to use them with the DM5. The DM5 is older technology now but is still useful.
Jul 25, 2011 | Alesis Dm5 Drum Module 18 Bit
I have a TD9KX and the problem i get is right in the centre of snare the sound seems to overload or is too sensitive. I cant get rid of this even when adjusting sensivity.
If the drum set is older, the cone that is in the center that transfers the hit to the piezo is degraded. You can find replacements on Ebay. You have to remove 4 screws to get the bridge under the snare out and then peel off the old cone from the piezo disk CAREFULLY and then stick new one on. The point of these goes bad. You will then want to adjust the height of the cone with the adjuster screws so it is barely, barely touching the drum head.
May 15, 2011 | Roland Elektronische Musikinstrumente...
I have to hit the bell really hard to get it triggered
On dual trigger devices makee SURE you use a three conductor cable that has a tip-ring-sleeve connectors both ends. This is similar to a 1/4 inch stereo cable. Single trigger devices only require the tip-sleeve type cable. It is common to have dual triggers on the snare and in your case on a cymbal and often users use the cable intended for the dual trigger on one of the single trigger ones and vice versa so the dual doesn't work.
Apr 05, 2011 | Roland Cy12rc Dual Trigger Cymbal Cy12 Rc
No rim on pd125 one td10and tdw chart
Make sure you are using TRS cable (three conductor that has a tip-ring-and sleeve) to connect to the module. This look like a stereo 1/4 inch cable instead of mono. If you use the wrong cable, the rim shot will not work. Most others will be mono cables but this one.
Apr 03, 2011 | Roland PD125 VPad (VPad 12 DualTrig Mesh...
For Sale Brand Korg OASYS 88 88-Key Workstation ????2100.00 EUR
If you scroll to the bottom of the page and click on Advertisers the site can help you.
Aug 05, 2009 | Music
Roland Pd 8 Dual Trigger Pad Logo
121 people viewed this question
Top Roland Music Experts
Michial Gueffroy
Alex McGaughan
Alex McGaughan
Level 1 Expert
Are you a Roland Music Expert? Answer questions, earn points and help others
