Question about Brother Office Equipment & Supplies
Brother DCP-6690CW Printer Error, it shows unable to clean 50
Inti.50 error code please solve this priblem
Posted on Apr 07, 2011
    Master:
  • 149 Answers
According to Brother's Europe/United Kingdom site (http://welcome.solutions.brother.com/BSC/public/eu/gb/en/faq/faq/000000/000500/000065/faq000565_011.html?reg=eu&c=gb&lang=en&prod=dcp6690cw_eu_as&Cat=11):
1. Unplug power
2. USING THE FINGER HOLDS ON EITHER SIDE, lock scanner cover into open position
DO NOT TOUCH THE ENCODER STRIP (clear plastic strip in front of the white vinyl band)
3. Remove jammed paper/foreign objects (check under the print head; if the print head is in the middle, slide it to the either the left or the right side, & check for paper scraps underneath the print head)
[IF WHEN THE SCANNER COVER WAS OPENED, THE PRINT HEAD IS ON THE LEFT SIDE]
4. Move the print head to the middle
5. With the print head in the middle, remove any ripped paper/foreign objects from the left corner (SINCE THE RIPPED PAPER COULD BE VERY SMALL, USE A FLASHLIGHT TO INSPECT)
6. Close the scanner cover & plug the machine back into the power outlet
[PERSISTANCE OF THIS ERROR MESSAGE OR NO PAPER SCRAPS/FOREIGN OBJECTS FOUND MEANS THAT THE ENCODER STRIP WILL REQUIRE CLEANING]
[IF WHEN THE SCANNER COVER WAS OPENED, THE PRINT HEAD IS ON THE RIGHT SIDE]
7. Plug the power cord back into the power outlet...LCD will show "Cover is Open"
8. Press Stop/Exit for approximately 5 seconds until the print head moves to the middle
9. UNPLUG MACHINE FROM POWER OUTLET
10. USE A FLASHLIGHT & TWEEZERS TO INSPECT: Remove any debris from the right corner
11. USING THE FINGER HOLDS ON EITHER SIDE, close scanner cover & plug machine into power outlet
TO CLEAN THE ENCODER STRIP... (clear plastic strip in front of the white vinyl band)
[Markings & debris can adhere on the surface of encoder strip FROM HAND CONTACT &/OR GREASE CONTACT INCURRED FROM REMOVAL OF JAMMED PAPER]
DO NOT USE FLAMMABLE SUBSTANCES NOR ANY TYPE OF SPRAY TO CLEAN INSIDE/OUTSIDE MACHINE
1. Unplug machine from power outlet
3. Clean both sides of encoder WITH ONLY A DRY, LINT-FREE CLOTH
DO NOT FORCEFULLY PULL ON ENCODER STRIP
DO NOT TOUCH ENCODER STRIP WITH BARE HANDS
DO NOT FORCEFULLY SCRUB ENCODER STRIP (THAT COULD SCRATCH ITS SURFACE)
4. Clean encoder strip from right to left--stopping just before the left corner
5. Clean encoder strip from left to right--stopping just before the right corner
6. Repeat steps 5 & 6 two or three times to clean thoroughly
7. After cleaning encoder strip, USE FINGER HOLDS TO close scanner cover
8. Plug machine back into power outlet.
Posted on Nov 11, 2010
Brother error code dcp-j 125 unable to Init 50
hi good day! the printer is error 50 due to a paper or some sensor error.. open the printer, or dismantle, clean the sensor and wash the pump of water and change the waste pad of new absorber. locate the sensor under the pump, clean it of alcohol.
Mar 17, 2014 | Brother DCP 165C Compact Color Inkjet...
Brother dcp-6690cw a3 scanner replacement glass
Probably best to go the Brother Support at
http://www.brother.co.uk/g3.cfm/s_page/204620/s_name/askaquestion2
Maybe you could go to a glass seller and have a replacement cut to match?
Mar 10, 2014 | Brother DCP6690CWU1 DCP-6690CW Colour A3...
Printer error unable to print AF
Sir/Madam
Hear is the solution For Your Problem,Just Watch The Video On And Fix Your Brother Printer Issue,
www.youtube.com/watch?v=BxbJbXf1u9w
or Go to Brother Official Web Site ->FAQ's & Troubleshooting ->Error Messages (LCD, PC) or LED Lights > faq002555_00
I Hope By Now You Fixed Your Problem Brother Printer Support
Dec 26, 2013 | Brother Ink for Dcp-6690cw and Lc-1100
Printer Brother DCP-6690cw unable to print 50, sometimes unable to clean 50. please help
A 50 error code indicates a problem with the "maintenance unit".
This unit controls and cleans the printhead and ink delivery system. You will need a technician to figure out if this is the problem or some other component has failed.
Sep 03, 2013 | Brother Office Equipment & Supplies
Unable to clean error 46 Printer Brother DCP-6690cw
my DCP 6690 printer causes problem unable to clean 46 how can i solved this ..............
Jun 12, 2012 | Brother Ink for Dcp-6690cw and Lc-1100
Brother dcp 7055 error-EF
brother dcp 7055 error-EF laser
Nov 22, 2011 | Office Equipment & Supplies
Brother dcp-165c print unable 50
how ca n i fix my brother dcp 195 c unable 50?
Nov 21, 2010 | Brother DCP 165C Compact Color Inkjet...
DCP-165C Compact Colour Inkjet Multifunction Printer: in brother dcp 165 printer the error message clean...
brother dcp-165c printer unable to clean , see troubleshooting and routine maintenance chapter in User's guide
May 16, 2010 | Brother DCP 165C Compact Color Inkjet...
i have brother dcp 6690cw and it said unable clean 46 i want solution for this
thank you so much
Apr 14, 2010 | Brother MFC 6490CW InkJet Printer
My printer brother DCP115C ''UNABLE TO CLEAN error code 50''
Machine error 50 is a error in Purge unit.You can't fix it by yourself and your printer need service.In most case the cost of repair is more than cost of new printer.
Nov 03, 2009 | Brother DCP 115C All-In-One InkJet Printer
2,132 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
