Question about RIM BlackBerry Pearl 8100
Have an Ultronic World Time Calendar folding calculator. Have lost instructions for it. Need help setting time for central time USA.
2 Suggested Answers
SOURCE: Need instructions for a ULTRONIC WORLD TIME CALENDAR,
How to set the ULTRONIC WORLD TIME CALENDAR 01-22-2011
1. press the SET (MRC) key. The SECONDS in the lower right corner will start to blink
2. press again and the HOUR will start to blink. And again for the MINUTES, again for the YEAR, again for the MONTH, and again for the DAY DATE.
3. when you get the number you want to set, press the UP (M-) or DOWN (M+) ARROW key to adjust that number as you wish.
4. then press TIME to lock in that number.
5. repeat as needed to set the other numbers
Posted on Jan 22, 2011
How to set alarm on ultronic world time calendar
This is a question for the app developer, it actually has little to do with your phone and more to do with independant software.
Mar 11, 2015 | Cell Phones
HOW SET THE DATE AND TIME FOR A "ULTRONIC " WORLD TIME CALENDAR
I have a ultronic TDoo552 clock that I cannot set. HELP
Sep 06, 2009 | RIM BlackBerry Pearl 8100
Set the time and date on a canon mp25dv/instructions
To set date:
1. Press the calendar/clock button (display should show date)
2. Press and hold the 'time set' button for 3 seconds (first digit of the date should flash)
3. Use the numeric keys to enter date using mmddyyyy format
4. Press 'time set' button
To set time:
1. Press the calendar/clock button twice (display should show time)
2. Press and hold the 'time set' button for 3 seconds (first digit of the time should flash)
3. Use the numeric keys to enter time using hhmm format, press 'AM/PM' button as needed
The '12/24' button changes between 12 hour and 24 hour format for time.
The 'format' button changes the date format from mmddyyyy to ddmmyyyy or yyyymmdd.
Feb 26, 2009 | Canon MP-25DV Calculator
Need to set an Ultronic clock
Press the time (current time - numbers) to get to the date mode. Then hold-press "SET" to set it.
Feb 19, 2009 | RIM BlackBerry Pearl 8100
Feb 10, 2009 | RIM BlackBerry Pearl 8100
Canon P170-DH Calculator
CLOCK & CALENDAR FUNCTION
Look for the key with the cal/clock pic on it. Use to switch between calendar or clock mode. It is next to the feed key.
(12/24) Key used to switch between 12 or 24 hour at clock mode.
(Time Set) Key used to set the date and time in calendar & clock mode.
(AM/PM) Key used to switch between AM or PM at clock mode time setting.
(Format) Key used to select date format between "YYYY/MM/DD",
"DD/MM/YYYY" or "MM/DD/YYYY" at calendar mode.
Hope this helps, play with it I figured it out with instruction sheet.
Jan 10, 2009 | Canon P170-DH Calculator
Canon P23-DH
I don't think the P23-DH has a calendar/clock mode. I have found the instructions for setting date and time for the P23-DH V. If your calculator does not have [Calendar/Clock], [Time Set], and [AM/PM] keys, you cannot set the date and time.
To set date:
1. Press the [Calendar/Clock] key once
2. Press and hold the [Time Set] key for three seconds
3. Enter the date in MMDDYYYY format
4. Press the [Time Set] key
5. Press the [C/CE] key
To set time:
1. Press the [Calendar/Clock] key twice
3. Enter the date in HHMM format, press [AM/PM] key if necessary
Aug 27, 2008 | Canon P23-DH Calculator
Setting an ultronic clock
Press "Mode" once to view the calendar
Press Mode again to view the alarm time
Set Time:
Press and hold Mode for 3 sec. to enter the time setting...Hour blinks..change by using Up or Down buttons. Press Mode again to set Minutes Press Mode to finish
Set Calendar:
Press Mode to see calendar
Press Mode for 3 sec to set year. Year appears, blinks...change with up or down buttons
Press Mode ..month appears...blinks. Change with up & down buttons. Repeat for day. Press Mode to finish
Jun 14, 2008 | RIM BlackBerry Pearl 8100
How do you set the clock/calendar on the Canon MP25DV?
The trick is to hold down the time set button (=) until the time flashes and once the new info is entered, press time set and it will stay.  same with the date.  You kinda need to play around with it.  Thats how i learned.
Mar 24, 2008 | Canon P200-DHIII Calculator
How to set the time and Date-Step by step please
I found this and it seems to work Solution #2posted on Nov 17, 2006 By greeneyes Rank: Guru Rating: 94.81%, 27 votes on the bottom of your calculator is a reset button, with a paperclip or a pen press that button. Then, press the calendar, clock key. next, press the equal sign key until the date is flashing type in the date using 11172006. press the equal sign again and the date is set. Next press the calendar, clock key again the time should show up (12-00-00)press the equal sign again until the time starts to flash. enter in the time using 0903 (9:03) press the equal sign again. Time is set. to display the date and time when not using the calculator, press the calculator, clock key 2x's. to go to compute mode press the red CE/C button.
Sep 03, 2007 | Canon P23-DHV Calculator
RIM BlackBerry  Pearl  8100 Logo
410 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
Andrew Wright
David
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
