Question about HP Compaq 6710b Notebook
How can i break up the Password of BIOS my LaPTOP Compaq 6710b I have purchased used Laptop
    Scholar:
  • 102 Answers
Its not possible to break BIOS password in case of a laptop, you have to go to HP service center for this. You can do this in desktop very easily by just taking out the CMOS battery and then reinserting it.
You can DO the same in your laptop also to remove the password but its highly risk cos once you opened your laptop your warranty will break if your system is under period. SO i wont suggest you to do it by yourself, better go to service center..
Posted on Nov 11, 2010
How do i connect compaq 6710 b laptop to my tv
by using HDMI cable ......there is an HDMI slot available in laptop as well as tv . purchase HDMI cabe and u will b able to connect ur laptop with ur tv.
Nov 24, 2012 | HP Compaq 6710b Notebook
An old laptop compaq nx6310 how to break a bios password
If you or the owner can prove ownership, HP/Compaq will unlock the BIOS for you. I use this method with Evo and NX models.
May 10, 2012 | HP Computers & Internet
I have laptop hp compaq 6710b, it cannot boot & hard disk not detecting.
Step1: Go to the BIOS and select first boot devise as hard disk. If you get same problem or hard disk not detecting. Replace the hard disk. Step2:If BIOS is not showing replace the RAM and check it..
Thanks..
Feb 10, 2011 | HP Compaq 6710b Notebook
Someone put a power on password and i dont know what that is how do i get that password or what can i do
The most common way to remove the password is to reset the BIOS. Disconnect the laptop from it's power and remove the battery. If you have the right tools, you will be able to remove the back plates underneath the laptop. (Usually a star point screwdriver). Under one of the back plates you will find the BIOS battery. A flat coin shaped battery. Usualy located near the RAM or CPU.
1. Remove the battery with a small flat point screwdriver.
2. Press the power-on button of the laptop. (this is just to discharge the
motherboard components completely)
3. Insert the small coin shaped battery again and return the back plate.
4. Insert the laptop's battery again and power up the laptop.
This may resolve your problem.
Nov 07, 2009 | HP Compaq 6710b Notebook
Can anyone help me on how to reset the Bios password to default on an HP Compaq 6710b Laptop? I have an HP Compaq 6710b Laptop. It is booting but it cant go beyond bios boot and i cant enter setup as it is...
A. By Using the Motherboard Jumper:
In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In this case we use another method.
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
B. By Using Software:
I have found that BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access to forgotten BIOS/CMOS passwords in just seconds
BIOS/CMOS Password Recovery Tool Service: http://www.biospasswordrecovery.com/
Oct 16, 2009 | HP Smart Buy Notebook
How do you remove the power-on password for windows Hp compaq 6710b?
Sadly, you must pull the laptop apart and reset the BIOS...well unless you know the password, then just remove it through BIOS.
Jul 16, 2009 | HP Compaq nx6110 Notebook
I have a Hp Compaq 6710b laptop my daughter has put a bios password now i am unable to use this laptop please help me
This site will solve your problem. http://www.tech-faq.com/reset-bios-password.shtml
My suggestion is to remove the CMOS battery from the motherboard and plug it back in. This is NOT the laptop battery that you plug the power cord into.
Other than this, the software on the site I posted the link to can be burned onto a CD and then booted from on startup, these will either give you the password or take off the password completely for you.
Please rate, thanks!
Apr 17, 2009 | Computers & Internet
My compaq 6710b laptop keep on losing date
It could be multiple things. I cannot post the full guide here because it is too long for the characters allowed in the post but the link to it is here. http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=3356620&prodTypeId=321957&prodSeriesId=3356620&objectID=c00047347
iI know it is for a differen t make and or model but it is all the same, it is usually one of these problems. I have used this page to help with multiple different computers and it has alwaysed fixed the problem.  hope this helps
Dec 05, 2008 | HP Compaq Business Notebook NX9010
Unlock compaq laptop 6710b that was given to me without software
compaq computers backdoor password is compaq....
If a password for a windows system you need a password reset program.. I have one and there is some on the net... good luck.....
Oct 30, 2008 | Compaq Computers & Internet
HP Compaq 6710b Notebook Logo
380 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
