Question about Homelite Mighty Lite Lawn Trimmer
Can you tell me where the air intake is - Homelite Mighty Lite Lawn Trimmer
    President:
  • Homelite Master
  • 1,545 Answers
See page 16 of this Homelite manual.
http://dl.owneriq.net/e/e795beb6-5dd6-4dbd-a82f-57b8d1a69355.pdf
You will need Adobe Reader installed on your computer to read this. It is a free download and a safe program to use if you don't already have it.
Posted on Nov 11, 2010
How does the air ratio work on a 2003 Dodge Neon 2.0 litre
Intake air flow meter and air intake temp sensor give ECU information; then coolant temp sensor has big influence on fuel mix, throttle position sender tells ECU what driver wants, then O2 sensor(s) do fine trim to fuel mix.
Jan 22, 2015 | 2003 Dodge Neon
Gm trouble code list
Code 113 means the signal from the intake air temp sensor is higher than normal. The sensor is telling the computer the intake air is above 200 degrees. Could be a faulty sensor or wiring problem.
Jun 28, 2013 | 2002 Saturn L-Series
Air Temperature Sensor
Most of the time, they are located in the air tube from the intake to the air filter. Or mounted in the air filter box itself. Sometimes they are mounted in the intake. But not knowing what motor you have makes it a little hard to tell for sure. But if is a 2002, it wil be behind the grill on the left side.
Dec 05, 2012 | 2002 Ford Ranger Regular Cab
What is the name of the valve in the air filter housing
the valve in question should be one of two.... if it is rather small and just kind of sticking in the housing with no real bolt downs or brackets it would be the intake air temperature sensor ( tells the computer what temp the incominng air is)... if it is larger and located after the air filter box in line with the intake boot, it would be the mass air flow sensor. meters the air flow intake and reports to the computer.
Aug 18, 2012 | 2002 Toyota Sienna
What does a bad air intake temperature control valve do on a 2003 Oldsmobile alero
The IAT ( intake air temperature ) sensor tells the engine controller (ecm) what temperature the incoming air going into the engine is. The ecm uses that information to help determine fuel mixture based on air density.
It is also used for certain emission testing the ecm does at engine start up.
Dec 03, 2011 | 2003 Oldsmobile Alero
Wont accelerate past 20 mph
Sound like the Air Mass sensor is gone. Get the car to a diagnostics center they will tell you for sure.
Apr 20, 2010 | 2003 Hyundai Tiburon
Can you tell me the situation of the intake air sensor on the mr2 turbo please
its in the air intake pipe between the air filter and the manifold
Jul 09, 2009 | 1991 Toyota MR2
Volvo v40 18si
should be a little single wire connected to the air filter box. located on the clean side of the air filter. if not it will be between the air filter box and the throttle plate usually located on the air duct hose going from the air filter box to the throttle plate.
Apr 10, 2009 | 2001 Volvo V40
Check engine light on a 2002 Acura RSX
Just hit the reset button, i have a 03 Civic Si same motor as base RSX mine came on everytime when i kept disconnecting the plug, never came back on. (i have a short ram intake)
Jan 30, 2009 | 2003 Acura RSX
Homelite Mighty Lite Lawn Trimmer  Logo
29 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Jay Finke
Jay Finke
Are you a Homelite Garden Expert? Answer questions, earn points and help others
