Question about Lexmark X1270 All-In-One InkJet Printer
The printer was not printing at all. I changed the cartridge and still nothing. Any ideas?
    President:
  • 2,923 Answers
Try to re-install the driver. Make sure that the printer is set as the default printer after installing, and make sure that it's set online.
Thank you and good luck!
Posted on Nov 11, 2010
Cannon Pixma 610 will not print with the magenta ink. I have used the cleaning utility close to 30 times and still nothing. Changing the cartridge did not help either. Any ideas?
When you said you used the cleaning utility 30 times, it reminded me that cleaning can only be done a few tims before ink is depleted.
When you said that you changed the cartridge and got nothing, it reminded me that one should remove the clear tape on the cartridge before installing the new cartridge, or else no print out will be seen.
If a new cartridge is installed and it still does not print out magenta, then the printer may require service at canonusa.com:
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp610?pageKeyCode=25
Feb 02, 2011 | Canon MP610 Photo All-In-One Printer
I have changed the ink cartridges, cleaned the nozzles and the printer prints nothing. it hasn't been used for a few years, i assume this is the problem but i don't know what to do to get it printing. any...
Ok, since you already tried cleaning the nozzles still there's no ink from the cartridge, you can try this one:
get the ink cartridge
soak the half of the cartridge in a luke-warm water for about a couple of mins.
then dry the cartridge
put it back to the printer and try to print again
see if there's any ink coming out
if still none
the cartridge needs to be replaced.
Feb 24, 2010 | Epson Stylus C66 Photo InkJet Printer
My HP 7350 Prints Almost Nothing
You should try going into the properties and running the head cleaning that will fix ya right up
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Aug 27, 2009 | HP PhotoSmart 7350 InkJet Printer
Epson pro 4800 r prints grey not blank and says to set cartridge
I am having the same problem If anyone has an answer or whether judy you have found an answer.
If I do a greyscale strip to print my black is coming out as a dark grey. the bead off of the greyscale strip would appear that the pbk photo black is not actually printing.
This has been a problem for a few months but as I haven't been doing much printing didn't notice it just thought something was odd. Now I look at previous prints and the blacks are black I print it out now and it is a dark dark grey. Nothing has changed in my profiles or my workflow. I have tried hours of profile paper printing option changes and workflow adjustments but nothing changes, If I print 100 percent black from a file it comes out 95% grey I have tried it from three computers to clarify. It appears is a 4800 problem.
Perhaps it is not recognising that it is a PB catridge.
I have no idea.
I have tried adjusting the settings from the printer but there is no option to clarify catridge from the printer.
This is odd, if anyone has any idea.
Mar 26, 2009 | Epson Stylus Pro 4800 InkJet Printer
Will not print
 ARE YOU USING BROTHER INK??? I MEAN BROTHER OEM INK.? WHAT YOU CAN TRY IS TAKE A PAPER CLIP AND INSERT IT ABOUT 1/4 OF INCH INTO THE AIR HOLE ON THE CARTRIDGE, SOUNDS LIKE WHEN THE SEAL WAS TAKEN OFF, THE ADHESIVE FROM THE SEAL STAYED ON THE CARTRIDGE BLOCKING THE HOLDE. GOOD LUCK SR BROTHER TECH
Dec 01, 2008 | Brother MFC 7300C InkJet Printer
Large black strip printing problem
There is issue with cartridge drum change that drum (It's in blue or green colour). the second option is change the cartridge.
Your issue will be fixed.
Nov 30, 2008 | HP LaserJet 1020 Printer
Lexmark z23 will not print
go to the printer properties---there select printing preferences ---there select lexmaxr solution center-----in that option select printer cartridge replacement option----in that follow the replacement instructions.and select the cartridges.as it is new.and its proper appropriate number.then only it will print properly. selecting the cartridge is very much necessary.
Sep 12, 2008 | Lexmark Color JetPrinter Z23 InkJet
Cannon multipass 390 print problems
I have the exact same problem, cleaned heads, replaced cartridge, nothing prints, no ink at all no colors or black.
May 08, 2008 | Canon MultiPASS MP370 All-In-One InkJet...
The printer won't print/just changed black cartridge
Uninstall the printer, reboot and reinstall using your printer software/driver cd.
Dec 18, 2007 | Lexmark Z715 InkJet Printer
Lexmark X1270 All-In-One InkJet Printer Logo
13 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
