Question about Canon PowerShot A540 Digital Camera
When I now try to use a 4gig memory card it always says the card error or card locked. I have tried card in both positions but it still says it is locked. I have tried with 3 different 4gig cards. What can I do? 2gig cards are hardly even available now. Thank you.
  • Rob Donnelly Nov 11, 2010
    Have you had success with 2GB cards?
    Problem Solver:
  • 13 Answers
You may be restricted to using only SD cards, and many 4gb cards are actually SBHD. My sister had this problem with her camera and by putting in a new 2 gb SD card, her camera worked fine. You may need to shop online in order to find an SD card, but they're widely available online. It costs about the same for 2 2gb cards as one 4gb even though they aren't as convenient.
Posted on Nov 11, 2010
No matter what card we put in the camera, it always read locked and will not take pictures. please help!!
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position. The second most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. There are also other common causes if the above didn't help, with troubleshooting steps for this problem listed here.
Aug 16, 2011 | Canon PowerShot A650 IS Digital Camera
Tip
Memory Card Locked / write protected error.
Hi due to so many questions asked about this here it is. How to deal with memory card locked/write protected error.
SOLUTION 1 - Unlock the memory card.
There is a Lock switch on the left side of the SD card. Make sure the Lock switch is slid up (unlock position). You will not be able to modify or delete the contents on the memory card if it is locked.
SOLUTION 2 - Toggle the lock switch.
If the lock switch is not on lock:
1. Slide the switch up and down. Repeat this 3 times.
2. Let it stay on the Lock position for 30 seconds.
3. Slide the switch up to unlock the card.
4. Try to transfer files into the device.
For non-SD cards: Format the card
The data on the memory card may be corrupted.
WARNING: Formatting will delete all the files in the device. Backup all your data before formatting.
Memory card write protected, memory card locked, memory card will not read, can't use memory card.
on Jan 10, 2011 | Sony Cyber-shot DSC-W50 Digital Camera
My memory card is showing card locked error. how can I overcome this error? I cannot do the formatting of the card for the formatting option is always hided.
Take the memory card out of the camera and look at it. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Feb 06, 2011 | Canon PowerShot SX130 IS Digital Camera
My sandisk memory stick pro duo has shown up file error in my pictures so when i go to transfer them on to my computer it can't get past the error how do i solve this?
Without knowing what the specific error is this is my best guess:
Jan 12, 2011 | SanDisk 2GB Memory Stick PRO Duo Memory...
Hello my camera doesnt accept hp 4gb sdhc card.when i placed card in, it says card error.... Also,i cant format when sd card is in and ''card error'' on screen...(my sd cards are brand new) plese give...
Okay we have a problem, to properly answer this question "we" collectively need to know what make and model the camera is. However one clue to your problem was that you said SDHC and 4gb.
I'm going to give you a diagram on the SD card type lock make sure it's in the correct position (not locked) Also the SDHC is a newer style memory card and 4 gig is a ton of memory for point and shoot cameras.
If the card lock thing doesn't work and you still can't format then I'm going to say that your camera can't handle the memory capacity of the 4gig SDHC memory card.
Don't panic yet, you may be able to go onto the camera manufactorers web site sift through the models and find the firmware updates for your camera. Updating to new firmware editions could open the possibilities of using a larger card.
Here is the diagram hope this is all that is needed.
Diagram
Jan 05, 2011 | Cameras
'memory card error - card locked!'
pull the card out
find the slide button on the side and slide it to the "unlock" position
put card back in
enjoi
Mar 04, 2010 | Canon IXUS 80 IS Digital Camera
MEMORY CARD ERROR
Camera is not recognizing any memory card. The issue is with the camera electronics and not the cards.
Jun 20, 2017 | Sharp Viewcam VL-NZ150U Mini DV Digital...
D-560
Is that card compatible with that camera. They make HD (high definition) cards (4gig and above) that will only work with newer camera's. Of course, i am speaking of SD cards. But the XD may have a similar feature.
That is the exact error i got when i tried to use an HD card in my 5 year old camera.
Try downgrading to a smaller memory card. Also, is that memory card exactly as the one you have had prior to this?
Jun 13, 2008 | Olympus Camedia C-350 Digital Camera
Memory card error
I had the same problem...then I realized this camera can only hold a 1 gb sd card.
Mar 07, 2008 | DXG Technology DXG-305V Digital Camera
Canon PowerShot A540 Digital Camera Logo
62 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
