Question about Vestax Handy Trax Turntable
I have a Vestax CDX-16 CD mixer, when i turn on the power about 5 sec later the CD Doors both open. When you place a CD in the drive and closed the door the CD does not spin, the display reads 1 rEAd then ejects and opens the door ? what am i doing wrong, or do i need to have the unit serviced ? regards Mike
2 Suggested Answers
SOURCE: vestax cdx-05s
The problem is with the tiny grey switch that tells the CDX that the platter is engaged. Take the face of the unit off by unscrewing the screws of on the circumference of the bottom of the unit, then locate the copper T shaped piece touching the spindle of the platter. Unscrew the little circuit board (this houses the on/off soft switch for the scratch mechanism) covering the bottom of the T and the T itself. Try powering the unit up and play a CD with the scratch mode activated. Push the grey soft switch to see if the music stops and move the platter back in forth to see if it scratches. If so, all you have to do is bend the copper T trigger to a position where it hits the soft switch just right; off when you don't have the platter pushed down, and on when you do. If the scratching doesn't work when you push the grey switch down, you have a problem I don't know how to fix. Hope this helps!
Posted on Jun 18, 2010
I have a CDX-602 CD Player. I was on a gig the other night I placed a cd in the tray. I pressed the button to close the tray and a cord was wedged so that the tray would not close. Naturally the tray...
The gears have probably come out of sync, meaning the tray is riding on the limit switch. You need to remove the deck, dismantle and re-sync the drawer mech. Check the limit switch isnt bent, it's quite flimsy
Aug 21, 2010 | Philips Gemini CDX-602 Dual CD Player with...
My CDX05 kept skipping last night, it happened on 7 different CDs. The CDX was tilted up though, would this cause the problem?
If it was kept in a dusty place yes!
I would thus try cleaning the lens with a good CD lens cleaner product, that should get rid of any dust problem.
Apr 07, 2010 | Vestax CDX-05 Turntable
How do i replace faders for the vmc 004
Hi you will have to open the mixer, make sure the power cord is not plugged in. The fader screws in from the back and the wires may be soldered. so you will have to unsolder the wires and re solder them to the new fader and replace and screw new fader in. Close mixer ..
Jan 31, 2010 | Vestax Vmc004 4-Channel DJ Mixer System
Vestax cdx-12 , left hand cddrive doesn't recognise discs imediately , sonetime not at all
In that case, the lens is weak. You need to change the lens entirely.
I wish you the best of luck.
Nov 05, 2009 | Vestax Cdx05 Table Top CD Player CD Player
Samsung HLN5065W freezes in black / White screen
Picture freezing that is the symtoms of depected DMD modules...
Just click below for electronics store you can order online;
Partstore.com.
Vance Baldwin Electronics
http://servicemanuals.vstore.ca/
http://www.electronix.com/catalog/
Hope this may help;
Regards,
VOTIT
Aug 21, 2008 | Samsung HLN5065W 50" Rear Projection...
Vestax PMC 05 PRO MIXER master output is not working
More than likely the output PCB might be faulty, or the signal amp might be damaged. In either case, not an easy fix. As for service in the UK, try HARD TO FIND RECORDS - they have a pretty good service dept.
- OPTiC
DJ Pro Audio
www.djproaudio.com
www.1200s.com
www.repairnyc.com
Jul 25, 2008 | Vestax CDX-05 Turntable
Pitch control center now 3.2% off center
maybe you should try a firmware update .follow the links on the vestax website about product support .
Dec 08, 2007 | Vestax Cdx05 Table Top CD Player CD Player
Vestax Handy Trax Turntable Logo
Top Vestax Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve
Are you a Vestax Audio Player and Recorder Expert? Answer questions, earn points and help others
