My computer was making loud noises, then shut down and won't restart. Could it be the fan went out?
    Brigadier General:
  • 4,044 Answers
It could be the cooling fan to the power supply but it sounds like that went completely out and blew the Zenor Diode or something in the power supply. You can test the voltages coming off the power supply to make sure. If that is what happened you are better off simply replacing it. You can get them at Best Buy for about $40 and it is a simple 4 screws to remove in order to trade them out. Make sure you have the correct connectors for the motherboard. If the Power supply is good then you lost the CPU fan. If the CPU fan went out and the computer will no longer start up you may have cooked the CPU. Again, this is something you can replace fairly easily. The fan should run about $12 to $20 depending on what model you get and what type of CPU it has to mount to. The hard part will be the CPU itself. If it has overheated to the point of burning a connection inside the CPU will have to be replaced and while it should not be soldered on the board the heat sink will be very difficult to get off and when you put the new heat sink on to the old CPU or a new one you will need heat sink compound. Runs about $1 a tube. If the CPU just overheated and shut down the PC should restart once it has cooled if nothing else till the CPU heats back up. Usually takes a couple of minutes but not long. This is actually good news if this is what is happening as it means the CPU is most likely operational and that is the expensive part to repair in an over heat situation. The problem does sound like a blown power supply though. If you have to replace the heat sink and CPU fan once you get the old stuff off and as much of the old heat sink compound off as possible make sure you apply new compound to the CPU. You do this by applying a small amount to the center of the CPU and pressing the heat sink into place, this should spread the compound evenly and thinly over the CPU area and form a bond between the heat sink and the CPU to transfer heat between them. The fan normally attaches to the heat sink and locks down on the CPU. Connect the Fan power wires into one of the power supply sockets and everything should come on when you power on the computer. While you have the case open you should take the opportunity to use canned air to blow the dust out of the case and air circulation holes. Heat and Dust are not your friends in computers. Good luck with your repair.
Posted on Nov 11, 2010
    Problem Solver:
  • 18 Answers
Yes most likely the processor fan is bad. Most computers will shut down if the processor gets above the max temp to avoid damage to the processor.
Computer won't boot
OverheatingWhen the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
Apr 26, 2012 | Computers & Internet
It's making an extremely loud noise it may be the fan but i'm not sure :)
Good day. What you can do too resolve this issue is to clean your fan from dust.. Usually the fan sucks in dirt while keeping your system cool, overtime this dust clogs your fan causing a loud noise. You can also check your hard drive because defective or hard drives that have problem causes scratching noise as well. Hope this information help you a bit. Have a great day.
May 29, 2011 | Dell XPS 200 PC Desktop
I have dell 3300mp,when I turn the power on it makes a very loud noise. It does not make the sound in standby or cool down. It does work and display a signal okay, but it is very loud. Sound like a fan?,...
The main fan that cools the lamp is mostly high speed when the unit is running. when it shuts down it slows the fan down, until it stops in standby. So the noise is only really loud when it is showing a picture.
try setting the fan to eco mode (slower running) and see if the noise is acceptable. If it is still too loud then you will have to replace it. Have a look at the fan and see if any of the plastic blades are missing.
Mar 26, 2011 | Dell 3300MP Multimedia Projector
Excessive fan noise at start up
Check if fans are covered wit dust or wires block the airflow,
if stil u get the sound then you have to replace the fans
Jul 10, 2010 | Packard Bell iMedia 6826 (P481000502) PC...
I have a VGN-CS115J for just about over a year now. The warranty just recently expired. The laptop shuts down automatically without warning. A few days before it shuts down automatically, there was a loud...
If you say that fans gives out loud swirling sound, i can suggest you update your bios because it is the one responsible for minimizing the noiseand making the fans swirl.
Possible that system is shutting down because fans might be shutting down as well.
You can also try to blow out some air on the vents because that is usually where your fans are, this will help clean out fans.
Questions: Does your computer restarts when it shutsdown automatically? if it is there might be a bluescreen error going on and bluescreen can either be a problem with software or hardware. A lot of troubleshooting needs to be done to isolate. Do the first solution that i have given you then answer my questions for further troubleshooting
Jun 02, 2010 | Sony VAIO VGN-CS115J/P Notebook
Over heat cooling fan load noise remove and replace
A bearing more than likely has went bad causing your fan to stop properly cooling your unit. Replace with a compatible fan and you should be all set. Hope this helps.
Jun 03, 2009 | Sony Computers & Internet
Shut down problem
Try getting in through Safe Mode by tapping the F8 key while the computer is booting.
If you can get in.
Right click on My Computer, select Properties, click Advanced, click on Settings for Startup and Recovery. Make sure there is NOT a check in the Automatically Restart box.
Apr 18, 2008 | Acer Aspire L100 PC Desktop
Loud CPU fan
check your cables. it may be in the way of the fan's fins. also clean your fan for dust.
Sep 16, 2007 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Computers & Internet Logo
153 people viewed this question
David Payne
David Payne
