Question about Intel Computers & Internet
I need to know what order to put the wires from the mother Bord to the floppy drive to the cd Rom\burner to the hard drives
  • joecoolvette
    joecoolvette Nov 11, 2010
    Ok. Fair enough. I need to know what the manufacturer name of the computer is, and the Model Number. It's on the back of a desktop computer next to the Windows Product key, or up on the side of the tower. Post back in a Comment.
  • Intel Master
  • 32,281 Answers
The floppy drive has it own data cable and does not connect to the same cable as the hard drive and CD ROM/R-W drive.
If the hard drive and CD drive are IDE devices, then the hard drive should be the connected to the connector at the end of the IDE cable and the jumper on the hard drive set to Master. The CD drive should be connected to the middle connector and its jumper set to Slave. The other end connector should be connected to the Primary IDE connector on the motherboard.
Posted on Nov 11, 2010
Mercury mother press F1 problem while FDD disable what to do this problem?
f1 is not bord problem. repair operating system. fdd( floppy drive) we can see hard drive/ optical drive/fdd in bios if we have not floppy drive in our computer we should do dodisable it in bios. i f we not do disable it in bios computer take along time in opening period it means bootin to serch floppy drive,
Nov 03, 2009 | Mercury P4VM800M7 Motherboard
Want to add 2nd cdrom
In order to burn from CD to CD you don’t need a second CD-ROM. Nero will save the CD image on the hard drive and then will ask you to put a blank CD and record the image from the hard drive to the CD.
To install a second CD-ROM use the same bus to the hard drive and set the jumper to “slave”. Good luck.
Sep 15, 2009 | HP Computers & Internet
Booting probs
go to boot sequence in the order
CD/DVD
Hard disk
others
Apr 23, 2009 | Compaq Evo N410C Notebook
Os instalation will not load
Hi Dobssand, the most common reason for a CD-ROM (With a Windows CD in it) does not start to load is the motherboard's bios is not set correctly. While in the bios go to the title Boot & enter boot order. This is a common boot order for a PC.
1st boot device = [Floppy disk drive]
2nd boot device = [CD-ROM drive] (Model number of the CD-ROM drive).
3rd boot device = [Primary Hard Disk Drive] (Model number of drive).
Second most common reason is the data cable to the CD-ROM drive is loose or not fully connected either at the CD-ROM or at the motherboard. (Check it).
If you choose not to enter your bios, you can still get the CD-ROM drive to boot the Win CD in this fashion. Load the Win CD into the CD-ROM drive. Power off the system. Than power on the system & start to press the F8 key once every two seconds. Windows "Please select boot device:" window will open. Using your keyboards up & down arrow keys high-light the CD-ROM drive that has the win CD in it & press the enter key. Windows should start to load. If you receive an error message stating windows can not find your hard disk drive. Than you must enter your bios & go to the title Boot. Your hard disk drive is not listed in the boot order section. Worst case! Your hard disk drive may be faulty. Find the manufactures name printed on a large white sticker on once side of the HDD. Go to the manufactures web site & download their drive setup software so you can create a bootable floppy disk. This will allow you to check/test the HDD & format it for a windows installation.
Or is this not the issue you are having?
Mike
Sep 26, 2008 | Computers & Internet
Problem ide
Hi gustabir,
try this first. (If I am understanding you correctly).
Power on the PC, press the Delete key every two seconds untill the boot menu loads. Go to the title, Boot. Set you're boot device's in the correct order. They should be listed as follows.
1st Boot device Floppy drive. (If a floppy drive is connected).
2nd Boot device CD-ROM/DVD drive.
3rd Boot device Hard drive.
(If you're CD-ROM drive is not listed in the bios main menu, than you're CD-ROM drive is not connected correctly). Please check the CD-ROM data cable is firmly & correctly connected), also check the power cable is firmly connected). If you are using more than one CD/DVD-ROM drive on the same data cable, check that you are listing the correct CD/DVD drive in the boot order. To change the drive's order while in the Boot menu, see page 34 in you're manual.
If the above does not address you're problem, please describe the issue/problem again.
If I can help you further, feel free to post.
Suggestions & comments welcomed.
Mike
May 27, 2008 | Foxconn (945G7MA-8KS2) Motherboard
Asus K8S-MS boot problem..
my understanding is that if you do not have other drives in a raid configuration you do not need the raid driver loaded ,have your hard drive plugged into the first sata slot, then format the hard drive ,instal o/s and all should be good.
hope this is of help
Terry
Mar 10, 2008 | ASUS K8S-MX Motherboard
Loading Windows 2000 on a formated hard drive
Try detecting cd rom in bios and boot from Cd rom. and then istall windows.
If not you should have drivers in floppy during installation it will ask for drivers F6 [function key]
Best Regards
rafique
Feb 18, 2008 | Fujitsu Stylistic LT C-500 Tablet PC
CD ROM DETECTION PROBLEM
LEAVE YOU hard drive on primary master port on your main board set as master or single drive ( IF YOU HAVE A STATA HARD DRIVE THEN DONT WORRY ABOUT THAT PART)
SET YOUR FIRST DRIVE AS MASTER
SET THE SECOND AS SECONDARY
use the jumber in the back of the drive to set them the propper setting is labeled on the drive it self
Connect them to the secondary port on your motherboard
so you should have
HARD DRIVE - MASTER OR SINGLE *jumper settiing* connected to the primary port on your main board
DRIVE 1 = MASTER *jumper settiing*
DRIVE 2 = SLAVE *jumpersetting*
connected to the secondary port on your mother board
IF YOU HAVE A SATA HARD DRIVE FORGET THE PARTS ABOUT HARD DRIVES ABOVE
i assumed you had a IDE hard drive
JUST USE THE SETTINGS FOR THE DRIVES and it should work :)
Dec 25, 2007 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
Computers & Internet Logo
46 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
