Question about Rockwood AMP-5556 Car Audio Amplifier
How much power do the ROCKWOOD AMP-5556 put out in each Chanel?
  • 23 Answers
Rockwood AMP-5556 - Amplifier - 4-channel - 200 Watts x 4
Posted on Nov 11, 2010
How do I install a Rockwood AMP-326 amplifier? I'd like to bridge it.
Rockwood was a very low level brand. Alot of their amps were not brigeable. If bridge able the bridge terminals should be marked (usually the positive of 1 channel and the negative of the other channel). Under no circumstances bridge to less than a 4 ohm load.
Jul 17, 2016 | Rockwood Car Audio & Video
Rockwood amp 5556 car audio amplifier no sound
Check an make sure your fuse is tight the one coming off the battery for your amp if that dosnt work try grounding your amp to the battery to make sure the ground is good
Nov 08, 2012 | Rockwood AMP-5554 Car Audio Amplifier
I plug in rockwood detanator VII and it goes to protections mode
Generally if an amp goes straight into protection, the amp is not grounded well enough. Either you should find a new location to ground the amp to or unhook the power wire from the battery, remove the ground wire from the chassis of your vehicle. Strip the paint from the chassis, since it doesn't conduct electricity, and remove any corrosion or copper shielding from the ground connector. reground to a solid metal location Can be grounded to the brace behind the back seat or to the seat belt bolt for best results.
An amp draws a lot of power, there it needs to be grounded well.
Hook back up your power wire to the battery and see if your issue is resolved.
Jul 18, 2010 | Car Audio & Video
Shashij_2001@yahoo.com
TURN THE BALANCE CONTROL IN THE MIDLE
Jul 06, 2010 | Yamaha P4500 Power Amplifier 2-Channel
I got amp 4 chanel i fix power wires but it is not
every amp has this wires power in/usually. red color; ground/black ; amp. turns On/blue or blue/white, if you have more of this wires them this are for speakers input. (from your stereo system)
Jan 04, 2010 | Vehicle Parts & Accessories
Rockwood 479X
i would recomend 8gage just to be safe
Oct 13, 2009 | Rockwood AMP-479 2 Channel Bridgeable...
I have a rockwood Amp-479X, need directions to install
Hello william_pric,
Look on the speaker output terminals to see if there is an indication, usually a line between the positive (+) on one to the negative (-) on the other, with the word "bridged". If the bridging terminals are not indicated, you can always try one of the positives and the other negative. If there's no sound, it must be the other two terminals. Just be careful that you don't short the terminals, and don't crank the volume up without the sub connected. Some amps don't like an infinite load.
For an input to the amp from a stock OEM radio, your best solution is to use a "line out converter", connected to the rear speaker wires. The PAC SNI-45T shown in the link is one such device. This one includes a "remote turn-on" lead for the amp. You could use a cheaper LOC and just run 12V from an accessory lead on the truck. In this case, the amp will turn on and stay on whenever the ignition switch is in the "on" or "accessories" position. If this is objectionable, mount a SPST switch somewhere convenient and wire the turn-on wire through it.
Hope this helps.
Apr 28, 2009 | Rockwood AMP-479 2 Channel Bridgeable...
Rockwood AMP-5556 Car Audio Amplifier Logo
257 people viewed this question
Top Rockwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Rockwood Car Audio and Video Expert? Answer questions, earn points and help others
