Question about Epson LX 1170 Matrix Printer
Paper gets jam - Epson LX 1170 Matrix Printer
One paper printing after a plain paper will jumped
Posted on Sep 15, 2012
    Problem Solver:
  • 14 Answers
Check the paper feader ... and check the gear of paper feader...
Posted on Nov 11, 2010
Hp 5660 photo paper jam from placing in wrong tray.
HP Printers - 'Paper Jam' Error ' HP® Customer Support
https://support.hp.com/ca-en/document/c04348351
This document troubleshoots how to clear different types of paper jams from error ... 5542, 5544, 5545, 5546, 5547, 5548, 5640, 5643, 5644, 5646, 5660, 5664, ...
Solved: HP Envy 5660 - Paper jam message - HP Support Forum ...
https://h30434.www3.hp.com/t5/Inkjet-Printing/HP...5660-Paper-jam.../td.../4673198 Nov 4, 2014 - 4 posts
Solved: Our HP Envy 5660 printer is 2 weeks old. It was purchased at an ... An error message popped up reporting a paper jam issue. Followed ...
help HP printer Envy 5660 Error "load photo paper in tray" - HP ...
https://h30434.www3.hp.com/t5/LaserJet...HP...5660...photo-paper-in/td.../5285421 Oct 5, 2015 - 2 posts
A new Envy 5660, can't get it to print 8x11" size, keeps error message, "load photo paper in tray", need to know how to set printer to print on regular size paper. ... I see you are trying to print to your HP Envy 5660 but you keep getting an 'Load photo paper in tray' error message.
HP ENVY 5640, DeskJet 5640 Printers - A 'Paper Jam' Message ...
https://support.hp.com/ca-en/document/c04759464 There are three different areas where paper might become jammed. Clear any jammed paper from one area, and then try to print again. If the error persists, ...
Paper Jam Or Tray Problem - Hp Envy 5660 Instruction Manual [Page ...
https://www.manualslib.com > ... > Instruction manual HP Envy 5660 Manual Online: Paper Jam Or Tray Problem. Paper has become jammed in the printer. Before you try to clear the jam, check the following: Make ...
Fixing a Paper Jam on the HP ENVY 5540 Printer - YouTube
? 14:06
https://www.youtube.com/watch?v=mrjGs1ahOjw
May 17, 2016 - Uploaded by HP Printer Support
Learn how to clear a paper jam hp 5660 photo paper jam Google Search
Jun 20, 2017 | HP Office Equipment & Supplies
Docuprint paper jam
Paper jam is a common issue for printers.I am going to explain how to resolve paper jam in the following ways:-
Step By Step
1. Verify that you have a paper jam. Sometimes the printer will send you a message that there's a paper jam. Sometimes you get the message from the crinkling, squealing sound the printer makes as it jams.
2. For most consumer models there will be only one sheet of paper threading through the machine at a time and a straightforward path from the paper feed to the output tray. In that case, you will want to search visually. Look to see if there are pieces of paper sticking out where you can see them. For larger commercial printers, where the paper path is more convoluted, you will need to consult the paper jam status message for hints of where to look.
3. Remove any paper from the paper trays that you suspect might have caused the paper jam. If a sheath of paper might prevent you from getting at the jammed paper, then remove that too.
4. Most consumer printers have an access door in the front that you can open to get at the jammed paper. With laser printers there's usually a toner and drum unit that slides out for improved access. If you still can't see the jammed paper, check if there's an access hatch in the back of the printer.
5. Gently remove any crumpled paper you might find. Gently tug on any pieces of paper that may be stuck or crumpled between rollers. It's possible that yanking the paper too hard in the direction opposite the normal direction of travel could wreck the printer rotors or some other delicate part. Whenever possible, pull the jammed paper in the direction of normal motion through the printer and avoid using excessive force.
6. Avoid ripping the paper as you remove the jam. Pull the paper slowly with both hands. Any shredded piece of paper stuck in the rollers will cause yet another paper jam. While you're at it, check for foreign objects that may have caused the paper jam in the first place, such as a paperclip or a pen cap.
7. Laser printers sometimes get the paper jammed so deep in the fuser unit that you can't reach it with your fingers. In those cases you want to avoid poking at the paper with sharp metal objects. Scratching the rollers could permanently damage your print quality. Removing an accordioned paper jam may involve disassembly of the fuser unit by a trained professional.
Dec 17, 2013 | Office Equipment & Supplies
I have a Epson stylus CX9400fax a piece of paper is jammed way inside the machine, I can't even see it to try and get it out! I've tried turing the machine on/off numerous time (still not expelling the...
If paper is jammed, a Paper jam message will appear on the control panel display.
Follow these steps to clear the jam:
  1. Gently pull any jammed paper out of the output tray or sheet feeder.
  2. If the paper is stuck inside, turn off the Epson Stylus CX.
  3. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus CX back on.
    alert_note.gif Note: Be sure to check the far left of the carriage area when checking for jammed paper. Paper that is jammed there may be hidden from view.
If paper jams inside the Automatic Document Feeder, clear the jam as follows:
  1. Open the Automatic Document Feeder cover and remove any jammed paper.
  2. If necessary, lift the document cover and remove any paper that has jammed inside.
  3. Press OK to clear any messages on the display screen.
Jun 02, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Keep getting an error that says paper jam. can
Dell P703w Printer
May 02, 2010 | Dell P703w Printer
Getting the error on my HP 4345mfp - TOP OUTPUT BIN, PAPER LATE JAM. 5017-Oct-2009 02:02 PM18209913.09.0048.081.2TOP OUTPUT BIN, PAPER LATE JAM 4917-Oct-2009 02:00 PM18209613.09.0048.081.2TOP OUTPUT BIN,...
my experience says jamming in duplex area using card stock. this may occur if default is duplexing. set default to single side and / or try same job using plain a4 80gm2
Oct 20, 2009 | HP LaserJet M4345 MultiFunction Printer
Jammed paper message
I get a Jammed paper message on the read out, I have cleaned out all the paper and pressed stop/cancel button but it still keeps saying that there is a paper jammed in it.
May 04, 2008 | Samsung SF-330 Plain Paper Inkjet Fax
PAPER JAM MESSAGE, BUT CAN'T FIND ANY JAMMED PAPER
look at the paper tray,some of your sensor are jammed,try tyo find out where is the sensor on paper try
Feb 29, 2008 | Panasonic Panafax UF-585 Plain Paper Laser...
Cannon copier pc940 paper jam
canon i960 -three flashing orange lights (paper jam error) but no paper is jammed. The print cartridge1.gif will not slide to center either-- I have tried to get the printer into service mode, but cannot get there because the orange lights never stop flashing.
Dec 06, 2007 | Cannon Canon i960 Photo Printer
Frequent paper jams.
Heavy cardstock and certain types of slick or coated paper can cause frequent paper jams. To better isolate the cause of your problem (machine or paper), try a new ream of regular 20 lb copy or laser paper.
  • Don't Overload
    Overloading your paper tray can cause paper jams. Your manual may say that your input tray can hold 250 sheets -- but if you keep getting jams, try loading 225 sheets instead.
  • Check the Paper
    Check the minimum/maximum paper weights that your printer can handle. Paper that is too thick, or too thin, can cause jams.
  • If you still get paper jams after this may be its time to clear the internal of the machine..You might want to have a look at the following link..
  • http://lasertoners.blogspot.com/2005/10/laser-printer-jam-fix.html
Nov 04, 2007 | Samsung ML 1710 Laser Printer
Epson LX 1170 Matrix Printer Logo
80 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
