SOURCE: nokia 6085 has a blue screen
I took the front cover off and fiddled with the connector and that was the problem, so I guess I will take it in and have that replaced!
i have repaired this problem time after time you need to replace the flexcable which is located inside the phone between the top and bottom of the phone the problem is that these phones are very poorly made and the cable inside gets crunched up with opening and shuting of the phone its very easy to replace and change and with ebay you can find the cable for around 4 pounds inc postage if you need help opening the phone please email [email protected] i have had around 10 of these phones to fix and only 1 out of the 10 the screen needed replacing change the cable first its cheapest option! hope this helps all!
SOURCE: blank screen on Nokia 6085
Frist U Change LCD Second Change Display Strip Third Change LCD IC In Last Flash Phone.
SOURCE: problem on the main display screen on my Nokia 6085
Sounds like a bad lcd flex cable, i fixed mine by ordering the part from an international parts carrier, but if you are not technically inclined to open up your phone and possibly destroy it, i would not recommend it.
SOURCE: nokia 5310 replaced LCD screen but still no backlight
i changed my nokia 5310 lcd but still no back light
