Question about Sceptre DCL 7A 17" Flat Panel LCD Monitor
The past few days the only way I can get the monitor to start (its a dcl 17)is to continuously press the start stop button (usually for several hours). day before yesterday it worked and I was on it all day yesterday. (left it connected)last nite there was a power outage and after the power came back (after 3 hours) I was UNABLE to get it restarted. When I puss the start/stop button the desk top displayes but only briefly. I then get a black screen as if it were not turned on
How to reset factory setting of monitor lg l1720B
Sounds to me like the button is stuck with pressure on the sensor. try moving button around a bit if it is a flat surface button then the surface is likely distorted and wont release it would have to be replaced at that point.
Sep 06, 2012 | LG L1720B 17" LCD Monitor
Can someone please explain in English why the Philips 170S dispaly monitor's controls are locked and how can I unlock seems my display has stopped working all togother a few days ago. Very...
The first requirement is that you must have video coming from your PC, then you have to press and hold for more than 10 seconds the "MENU (OK)" botton, this must unlock the OSD controls of your monitor.
Feb 10, 2011 | Philips 170S6FB/27 17" LCD Monitor
The main menu appears and disappears without any input. And also a picture of a lock also appears and disappears without any inputs. The picture of the lock is either locked or unlocked
It seems that the problem is the monitor is detecting that the menu button is continually being pressed or the switch is shorted. Try pressing the menu button a few times to see if you can make this stop. Otherwise, the monitor needs to be repaired. Hope this helps.
Jul 03, 2010 | Dell E172FP 17" LCD Flat Panel Monitor
How do I adjust the brightness? It's too much?
By following these steps u can adjust the brightness
Step 1
Press "Menu" on your LCD's display panel (usually below the screen). Various display options will be shown on the screen.
Step 2
Select brightness from the options. This is usually indicated by a sun. Use the "+" and "-" buttons on your display panel to increase or decrease brightness.
Step 3
Select contrast from the options. This is usually indicated by an oval half black and half white. Use the "+" and "-" buttons on your display panel to increase or decrease contrast.
Thank you
Mar 28, 2010 | Sceptre DCL 7A 17" Flat Panel LCD Monitor
Continual pop-ups saying OSD Main Control locked followed by language choice, etc. I have tried the buttons on the monitor with no effect
I held down the OK button for several seconds and the message vanished. On releasing the OK button, the problem reappeared. I intend to put a rubber glue (one that can be removed) which hardens on application, to hold down the OK button in the pressed position. Hope this solves the problem.
Oct 12, 2009 | Philips 170S5FS 17" LCD Monitor
A few moments after I start my computer, I get a blue box in the center of my monitor that displays contrast. It keeps popping up every few minutes, what do I do? I keep pressing the exit button of the...
The contract button seems to be stuck. Try pressing the button hard a few times and see if it helps. If the contract button still keeps poping up and it may be a physical problem with the button there.
Aug 16, 2009 | Dell Computers & Internet
Settings for dcl lcd monitor
Your laptop resolution is greater than the external monitor can handle. From your laptop, try changing the screen resolution to 800x600, if it works, up the ante to 1024x768. You can bring it up again until you find a comfortable screen resolution. You will eventually stop to a point when your external monitor displays about 80% of the laptop screen. That is, back to your original problem. But you get the idea. Cheers!
Mar 27, 2008 | Sceptre DCL 7A 17" Flat Panel LCD Monitor
Monitor won't turn on -- flashes on then off again
This is probably a RAM memory trouble, you have to try with 2 ways: 1) Try with another RAM memory to start your pc, 2) Verify the memory using a DOS software to check it.
Also, you could reset the BIOS using the jumper settings established on the PC Motherboard Manual to try if the BIOS is fail, or update the PC BIOS.
At last, You must check the temperature generated on the devices, if it's warm it means that the Hardware needs to add more fan coolers, or deactivate Overclocking. The overheat cause this fail too.
Click on this site to setup Bios or Cmos :
Or can try in safe mode
Best of Luck ! Please dont for get to Vote.Thank You.
Dec 11, 2007 | Sceptre DCL 7A 17" Flat Panel LCD Monitor
DCLCD 19" flatscreen won't turn on correctly
Same problem here, but after using the plugging/unplugging method it eventually stopped all together. So, I took it to a local monitor repair shop (AM Stereo, Seattle). The problem is a power supply issue where the capasitors go bad. They fixed the monitor by replacing the capacitors for $70. In there experience, all monitors, regardless of brand, tend to use the same cheap capacitors which fail. He replaced them with better quality capacitors which may make this monitor better than it ever was. I'm back in business with a great monitor!
Oct 31, 2007 | Sceptre DCL 7A 17" Flat Panel LCD Monitor
White startup screen
try this test: put pc into hibernate mode and allow full cycle. if monitor ceases problem, then original problem may be with pc's video output only.
Jun 08, 2007 | Hyundai ImageQuest L17T 17" LCD Monitor
Sceptre DCL 7A 17" Flat Panel LCD Monitor Logo
47 people viewed this question
Top Sceptre Computers & Internet Experts
Ricky Ostrom
Ricky Ostrom
Are you a Sceptre Computer and Internet Expert? Answer questions, earn points and help others
