Question about Maytag Dependable Care LAT9706
CAPACITY OF MY WASHER MAYTAG DEPENDABLE CARE LAT9706AAM
jsrock516
  • 5911 Answers
SOURCE: How do you remove the agitator on a Maytag Dependable Care Washer?
If this is a Maytag Performa or Atlantis model all you have to do is remove the center cap on the agitator by pulling on it and locate the agitator bolt underneath. Loosen the bolt, and the agitator should pull straight up.
If this is a Maytag Dependable Care series there will be 1/4 inch screw along the side of the agitator towards the bottom. Remove this screw and the agitator will pull straight up.
I hope this helps you.
PS If the problem is due to the build up of fabric softener, soak in some hot water to loosen it up. Fabric softener is essentially a form of liquid wax and it is common for it to accumulate and clog the dispenser in this manner. Periodic cleaning is recommended.
Posted on Aug 09, 2008
  • 784 Answers
SOURCE: Maytag dependable care plus washer (Model LAT
The belt turn the pulley, but the height of the pulley is worn out so it didn't push up a mechanism to release the brake and to engage with the clutch to make the spin.
You have to takethe shaft out to study how it works then it makes sense on what I 'm talking.
The pulley cost only $11 but it is a major laboring exercise. It is a good learning to have hands on to this problem. Good luck on replacing the pulley.
Posted on Aug 09, 2009
  • 336 Answers
SOURCE: should I buy a gently used Maytag dependable care
Maytag makes very dependable machines. They are fairly easy to repair and parts are easy to find. If I was in the market for a used washer, a Maytag would be my first choice. Since its used there is no guaranty that the thing isn't going to need repairs. If you can see it run through a cycle before buying it would be a plus. My first washer was a mid seventies model Maytag. I had two minor repairs twice in 15 years and its been working ever since at my buddy's. I hope this helps you.
Posted on Aug 27, 2009
SOURCE: where is the lid switch for reset on a maytag
where is the lid switch for reset on a maytag dependable care washer
Posted on Jan 30, 2010
  • 3 Answers
SOURCE: Old Maytag Dependable care washer - LAT8506
Need to replace the belt going to the transmisssion powered by the motor. these act like a clutch for the unit. It is worn out and needs replaced.
Posted on Feb 26, 2010
Maytag dependable care plus washer. Top Loader works through all cycles, but will not initiate or complete final spin.
Bad lid switch wore out needs replace ment or you have bad pump and takes to long to drain send us a model #
appliancexchange@gmail.com
Jan 30, 2013 | Maytag Dependable Care LAT9706
I have a Maytag dependable care quiet pack 2 speed super capacity 9 cycle Model No. LAT9416AAE
It is possible that you need a new timer which is a part number: 22003362 and is usually about $75-$100 but it is also possible that one of the components of the knob is not functioning properly. The best bet is to take the knob apart (make sure the arrow points to a wash cycle first) and then pull up on the time timer shaft itself. If the washer starts then you know its one of the components of the knob that when bad. If it doesn't then you know you need a timer.
Nov 16, 2012 | Maytag Dependable Care LAT9706
My top load washer smells like moldy, nasty water
use some vinagar let wash
i heard deluted CLR works too, but delute it really good
Apr 18, 2010 | Maytag HAV2557 Top Load Washer
Jan 26, 2010 | Maytag Dependable Care LAT9206
Where is the lid switch for reset on a maytag dependable care washer
Dec 19, 2009 | Maytag Dependable Care LAT9706
Aug 08, 2009 | Maytag Dependable Care LAT9706
My Maytag washer fill too slowly
There's a little screen at one end of the inlet hose that will clog up; remove that and clean it. Don't forget to reinstall it. You can buy a replacement at the hardware store; take the old one along, there are a lot of different sizes.
Jun 09, 2009 | Maytag Dependable Care LAT9706
Maytag LAT9706AAM Washer - Spin Cycle problems
If the timer is advancing but won't spin out, it is possible that the spin contacts inside the timer are faulty. A technician will normally isolate and confirm this diagnosis witth a special power cord hookup to the motor. From the way you describe your complaint, I feel that a timer would correct your problem.
Hope this advice is helpful!
May 27, 2008 | Maytag Dependable Care LAT9706
Washing Machines Logo
314 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
