drop by your local car stereo dealer and ask them NICELY to reprogram the time for you...then, a NICE person would but the guy lunch, what $10? Good Luck
Go to the Pioneerelectronics website and the instruction manual is there in pdf format you can view and print. You will have to select in dash navigation system and just click on any one then click on older models.
hello there.here the manual direct download link. http://www.retrevo.com/support/Pioneer-AVIC-D2-Car-Videos-manual/id/475bh745/t/2/ In the above link you can directly access the manual online.Just select any option or you can directly view the entire manual by clicking 'view all'.we are glad we could help you.thank you for contacting us.please do keep posting further queries.thank you once again.
what i did is, i went into the destination window and pressed the settings tab, then i pressed the hardware information after that i pressed the 3d calibration and then i cleared the section where it said hybrid 3d. after a while it worked fine.
If your pioneer AVIC car navigation unit does not register your touches or the wrong button is “pressed”, you need to re-calibrate your screen’s digitizer.
1-Hold the Eject button down until the face of the unit drops all the way 2-Using a pen hold down the reset button (just above the joystick) and the navigation disc eject simultaneously. 3-Release the reset button. 4-Release the dvd eject button next. The display will read “press reset” 5-Push the joystick up two times. 6-Push the joystick down twice. 7-Press the joystick in. 8-The service menu will appear after a short pause. You can navigate the service menu using the joystick. 9-Chose the first menu option and press in on the joystick. 10-Trace the screen with a stylus. 11-"P.ADJ" is the back button 12-Chose the second menu item in order to calibrate the touch screen. Use a stylus again and tap the "+" sign on the screen. (You may have to touch slightly off center if the digitizer is damaged. In which case things will still be off but it will be much better.)
you can open up the unit if you are savey enough and clean the ribbon with an alcohol pad. it worked for me and ever since i did that the door hasnt frooze up on me.
This is from the Pioneer Electronics Website;
Touch the source icon and then touch
?AUX? to select AUX as the source.
When the source icon is not displayed, you
can display it by touching the screen.
If the auxiliary setting is turned ?OFF?, ?AUX?
cannot be selected.
I would assume you just need to disable the AUX button.
Best of Luck.
