Question about Nokia 3110 Cellular Phone
My problem is when my mobile are swech on 3tims light on and of after swech of signal.
  • 213 Answers
THIS IS SOFTWARE FAULT
SO FLASH UR CELL
{SOFTWARE}
ANY REPAIRING SHOP OR SERVICE STATION
IDRISH 911
Posted on Nov 11, 2010
Displa not working some time
Posted on Nov 12, 2010
  • archanavinay Nov 12, 2010
    how to jailbreak iphone 3gs without wifi & connectivity for new sim
Turn signal lights don't work
The first place to start are fuses, check your owners manual for location, typically left side of dash.
The emergency (hazard) flashers and turn signals are on separate fuses and run through the hazard switch. If all the lights work when the hazard switch is on then the problem will likely be a blown turn signal fuse.
Other possibilities are the hazard switch itself is bad, the turn signal switch is bad or a broken wire, all of which require a meter (or test light) wiring diagram and knowledge of the circuit to test it - better to have it done.
Robert Grove
Mobile Mechanic Malibu 310 651 8020 Auto Truck RV Mobile Repair...
Aug 09, 2014 | 2002 Chevrolet Impala
Wallpapers lgx330
CHANGE YOUR BATTERY FIRST.
Mar 12, 2014 | Cell Phones
I have power to the swech box but none to the hard drive
How do you know you have no power to the hard drive?
If you are positive there is no power coming out the power supply to your hard drive but you have power elsewhere, then you probably need to replace the power supply.
Nov 01, 2013 | Computers & Internet
Our Samsung remote control ARH-428 will not work. We have changed batteries however we can not make it operate our air-conditioner
If even with new batteries not working means transmission signal problem. May be with remote or receiving signal problem with indoor. Check your remote with camera mobile and press on/off switch. If it's ultra light flashes, it's o.k. Then repair receiving signal in PCB.If no ultra light in remote, replace remote.
Dec 27, 2010 | Heating & Cooling
WINDOWS AND LOCKS AREN'T WORKING ON PASSSENGER SIDE OF 1996 JEEP CHEROKEE LIMTED 8 CYLINDER
you have to tropleshoot the problem first check your swechs,driver and the passenger side when you do that if not working,check,the motor in side the door and make up-and dwon the window if that motor is working check the passenger side swich,it is the swich or moter
Sep 22, 2010 | 1996 Jeep Grand Cherokee
The fan will not run i have replace the temp swech and the relay and the fan and thesen unet.if i cross wire the relay it will runs all the time what can it be help
F you have battery power and ignition power at the relay, and the circuit is good from the relay to the fan. then the fan is turned on bt the high pressure A/C switch or the ECU. If the circuit (ground ) to the ECU is good you probably have a bad ECU.
Sep 14, 2010 | 1984 Chevrolet Corvette
My laptap screen went dark/ off no light or pectuer on the screen but the coputer com on the on/off swech light com on
Thanks for choosing fixya.com
It could be a few things, most likely it may be the backlight. The backlight is a small long bulb that sits at the bottom or top of the lcd screen to light it up so you can see whats on the screen.
Sometimes tilting the screen back in the right light you can see a very faint image on the screen.
The other option would be the board that converts the signal has malfunctioned on the computer. Both will require someone to check the laptop and possibly take the screen apart. If the laptop is under warranty you might be able to send it in for free to be fixed.
Otherwise a local shop should be able to help you with the issue.
Replacement bulbs range in price depending on the laptop anywhere from $50 up to $200 depending on how much the shop is going to charge for installation.
Hope this helps, feel free to ask further if needed.
Jei
Dec 17, 2008 | Gateway Computers & Internet
Data retrieval
is it sweching on then try with pc suit that u can download frm motorola site.reply me if i can help u more.
Dec 02, 2007 | Motorola Mobility RAZR V3x Cellular Phone
Nokia 3110 Cellular Phone Logo
59 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
Damen Wong
Damen Wong
