Question about Bosch Tools & Hardware - Others
Pls confirm the model no. & price of Impact wrench for the givn specs of Wrench. Square drive - 1/2" Working torque range - 34-408 Nm Pneumatically operated
  • Bosch Master
  • 7,733 Answers
Look at eReplacementParts.com and the parts diagrams.
If you need more help come back.Post / thumbs / testimonial are welcome!
Posted on Nov 12, 2010
The ratchet on craftsman microtork torque wrench 44593 does not work
The ratchet pawls have seized and a ratchet rebuild kit is needed.
Jul 20, 2014 | Craftsman Microtork Torque Wrenches -...
Craftsman instructions
You can not use that model for the torque you require. A larger capacity torque wrench will be needed.
Jul 16, 2014 | Craftsman Microtork Torque Wrenches -...
How can i reach a torque setting of 305nm when my wrench only reaches a max of 200nm please any one help i am thinking that it can be done in 2 stages yes or no
It is possible to use a simple torque wrench extension bar, which fits onto the square drive of the torque wrench.
http://www.dmctools.com/Products/torque_conversion_charts.html
At the other end of the extension bar is a male square drive for the socket. This increases the leverage of the torque wrench by a ratio which is the total length of the wrench plus bar divided by the length of the torque wrench only. You multiply the torque reading by this ratio.
Note that NO increased torque is obtained by fitting an extension on the handle end of the torque wrench. The applied torque will still be the same as the torque wrench reading in this case.
Then there is a more expensive tool, a torque multiplier. These are often fitted to the output shafts of winches etc, and consist of a small gearbox which fits on the square drive of the torque wrench. On the other side is a male square drive for the socket.
http://www.tjtools.com.au/torquemultiplier.htm
They are geared in various multiplier ratios from 4:1 to as much as 40:1. On the gearbox casing is a reaction bar which is braced against something to keep it in place as the torque is applied.
They are expensive but you can hire them also.
Mar 16, 2012 | 2005 Ford Falcon
The instructions I have for insalling the tensioner say "The tensioners are equipped with a square hole on the tensioner to rotate the tensioner arm for installation. A 1/2" socket driver wrench...
Yes, you use a long 1/2" ratchet or breaker bar
in the 1/2" square hole to release the belt tension
Don't need torque specs
I doubt you even own a torque wrench
Apr 01, 2011 | 1997 Dodge Dakota
What the maximum working torque for a Ingersoll Rand 1/2 2705P1?
Ingersoll Rand 2705P1 1/2 inch 40-200 ft lb Industrial Duty Impact Wrench
Max Torque 400 Ft-Lb
Pneumatic Impact Wrench, Industrial Duty
Pistol Grip Style
Standard Anvil
Square Drive Size 1/2 In
Torque Range 40-200 Ft-Lb
Average CFM @ 15 Second Run Time 4.2
CFM @ Full Load 23
Max Bolt Capacity 5/8 In
Free Speed 8500 RPM
Pin Retainer Type
Required Pressure 90 PSI
Air Inlet 1/4 In
Min Hose 3/8 In
Overall Length 6 3/4 In
Weight 2.55 Lbs
Country of Origin: USA
CR 4Z942
Mar 28, 2011 | Ingersoll Rand Air Tools & Compressors
Question there are four settings on the air impact wrench 119106 I need to set to specific foot pounds are each of the four setting equal to a specific foot pound per inch (ie: setting one is 50 pounds...
if you dont use hand tools often you should never trust the torque from impact wrench you should always recheck with tension wrench for correct torque specs
or at least hand tools such as breaker bar, spanner, ratchet
depending on what your doing up and diameter of bolt or studd for what application
Feb 06, 2011 | Craftsman 1/2" Impact Wrench
Worn drive on my CP half-inch impact
That impact is distributed by Harbor Freight, though I doubt it is 25 years old. They may have a rebuild kit there, but a new one just like it is around $35.
This one:
is priced at $24.99
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=95310
Mar 25, 2010 | Chicago Pneumatic 1/2" Air Impact Wrench
Wrench support
impact wrenches are often misused by those who don’t know about their special needs. First of all, it is very important to be careful when tightening a nut or bolt with an impact wrench! Cross threading can occur very easily; a novice may also over-torque a bolt or a nut if they don’t know when to stop. To prevent such problems, always be sure to hand-tighten every nut or bolt before using the impact wrench; if you try to start the nut or bolt with the impact wrench, you won’t be able to feel if the threads are crossed. If the impact wrench is not torque controlled – meaning it will stop when the nut or bolt is tightened to a certain torque – you will need to go slowly, and periodically check the torque value of the nut or bolt to make sure you haven’t tightened it too far.
Aug 27, 2008 | Campbell Hausfeld 1/2" Impact Wrench
Tools & Hardware - Others Logo
291 people viewed this question
Top Bosch Tools & Hardware - Others Experts
Awesome12
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Bosch Tool and Hardware - Other Expert? Answer questions, earn points and help others
