Hey, i have just bought Simpson 36P450 4.5kg. Top loader washing mech (well i think thats it as the writting arround the two knobs has fadded to nothing) just need to know what they say because one of them is for the temp and the other is for the type of wash.
  • 147 Answers
SOURCE: Simpson 36P450 Washing Machine continuously
It cant drain if you oulet hose is higher than the water level. Raise your drain hose up above your water level. I was pmel (calibration) in the air force..Love it.Went to school at port huneme (navy) school
Posted on Oct 25, 2008
SOURCE: washing machine lid switch
used my noggin and saved $20-00
Posted on Dec 29, 2008
jsrock516
  • 5911 Answers
SOURCE: how to take apart a Whirlpool top loader washing machine
If you have not taken the exterior washer casing off, the first steps will explain how to accomplish this:
1. Unplug washing machine.
2. Remove console. This can be accomplished in one of two ways depending on which type of console you have.
a. If the console has removable end caps, the caps lift off by prying on the top from the back of the washer. The cap will pull off towards you as you are facing the unit from the front of the washer. There will be a screw under each end cap that you will need to remove.
b. If the console does not have removable end caps, you will need to slide a putty knife under the front corner of each side and push in while lifting up. There is a retaining clip under each side that has to be released.
3. Once the console has been released it will lift up and fold back over the back of the washer in its resting position. Use care not to stress the small plastic hinges that hold it on. They can break easily.
4. Under the console will be two large brass colored clips. Take a large flat blade screwdriver and place it in the groove of the clip on the washer top. With the screwdriver firmly in the groove, push away from you towards the back of the washer. This will release the clips.
5. Disconnect the lid switch connector plug. This is the white colored plug on the washer top under the console.
6. Remove the washer casing. Open the lid of the washer. Using one hand, grip under the front rim of the washer opening. Do not grab the wash tub, just the casing. Tilt the washer case from the back first towards you, slide forward slightly, and then lift up. The entire case comes off exposing the wash tub and components.
Once the casing is removed, you should have full access the the washer interior components. Since you have mentioned you taken the "internal post" off (I'm assuming this is your agitator), I will spare the steps in involved in accomplishing that task.
Next, follow these series of steps:
1. Remove the tub ring. This is the cylindrical donut shaped ring attached to the top of the wash tub. This ring needs to be removed in order to accommodate the removal of the inner spin basket. The tub ring comes off by placing a screwdriver under the series of the tabs that hold it in place and GENTLY prying them up until they release. Be careful not to break off the tabs, or crack the wash tub.
2. Remove the spanner nut that is under the agitator. This holds the inner spin basket to center post.
3. With the spanner nut removed, the spin basket should lift straight up and out. Sometimes the basket will stick to the center-post and may required some "coaxing" to get it free. This can be accomplished by grabbing the rim of the spin basket and prying up on one side, then the other, in an attempt to rock the basket side to side.
Searspartsdirect.com has excellent exploded view diagrams that you can use as a reference. Simply type in your model number and look under the "Agitator, Basket and Tub" heading. The tub ring gasket, I mention below, is listed as item 6. Appliancepartspros.com also has these same drawings.
Some things to consider:
If you remove the tub ring, it is recommended that you replace the seal on the ring before reassembly. Once the tub seal is broken, it can leak if the seal is not replaced.
When reinstalling the exterior cabinet, follow these steps:
1. Re-install washer case. With the lid of the washer open, place grasp case under front rim and place it on the washer frame. While looking down through the washer lid opening, make sure the front lip of the case is placed UNDER the washer frame and rocked back onto the frame to ensure that the small cleats on the frame fit into the slotted grooves on the washer case base. If you do not get the case seated correctly it will rattle and vibrate while the washer is in operation.
2. Make the back of the washer fits into the washer casing on each side and reinsert the brass clips. Place the clip into the slot on the back of the washer first, and then forcefully push it into the opening on top of the washer. It will snap back into to place.
3. REINSTALL LID SWITCH CONNECTOR. It is easy to forget. If you do not reconnect it, the washer will not work correctly.
4. Reinstall console.
If you have questions, or need further assistance, please let me know. I hope this helps you.
PS What is the reason for removing the spin basket? Anything else I can help you with?
Posted on Jan 17, 2009
SOURCE: Simpson Esprit 450 Washing machine
I'm having the same issue, did you get any resolution?
Posted on May 04, 2010
SOURCE: simpson esprit 450 washing machine top loader
your drive belt is brobably loose or broken
Posted on Aug 10, 2010
Simpson 550 top loader. How do I remove agitator and clean under the bowl
Pull top part of agitator off an there should be a locknut visible 10mm I think,remove locknut an agitator should come free,it may need a few light taps to release,pretty sure its the same as my 750...hope this helps an good luck.
Dec 27, 2016 | Simpson Washing Machines
Simpson esprit 550 top loader washer
Have you tried the motor control switch.
Its located below the selector switch.
Its white aprox 5 x 7cm with Electrolux AMD103 stamped in it.
The wires that are plug in it goes to the selector switch.
Apr 30, 2016 | Simpson Washing Machines
Hi, I am Hoping for a Service/Repair Manual for a Simpson Espirit 450 Top Loader. I think it has Shorted out and needs rewiring or a fuse replaced(If they have Fuses)
I went google and typed in-- workshop manual for simpson espirit 450 top loader washing machine -- and got several pages one of which is www. manuals. club
I suspect that you may have to pay for the manual but on their page there is a listing for user manual, installation manual, service manual, parts list and schematics
try and see if you get what you want
there may be a loose connection to the program board or a faulty program board but I doubt that you will need a rewire or anything drastic like that
Dec 07, 2015 | Simpson Washing Machines
Simpson Enduro 801
turn the timer to a setting and pull out on the knob once
Apr 09, 2015 | Simpson Washing Machines
How do i replace a programm switch on a simpson 750 esprit washing machine
Normally, you would push in on the knob to set to a cycle then pull out on knob to start machine. Am i correct? So when you push in to set the cycle it just spins?
Jan 27, 2013 | Simpson Esprit 750 Top Load 7.5kg
I have a SIMPSON ENCORE 555 heavy duty washing machine. It will do a normal wash cycle, but when it comes to the spin cycle, it doesn't distribute the washing around the drum and hence won't spin. any...
Hi just read your posting.Now does the washing tangle around the agitator?In your posting you mentioned the washing not distributing around the drum.Could you confirm that your machine is a top loader for me,because the word "drum and distribute" are terms for a front loader.If your machine is a top loader which I think it is then the problem could be your brake arm or spin coil is not operating.Please reply and let me know if the clothes are tangling around the agitator.Looking forward to your reply.
Sep 07, 2010 | Washing Machines
New Simpson Top loader washer very noisy/rocking
sounds like you havent undone the transit bolts- theyre on the back of the machine, 2,3 4 maybe five quite large obvious bolts, around the drum but on the back. they are to keep the drum steady while in transit to stop the machine bouncing around in the van - you are unlikely to have damaged it - Undo these bolts - they should be mentioned in the manual-
Jan 20, 2010 | Washing Machines
My simpson top loader will not complete cycle.
More likely than not it is your control regulator gone out. This is where your rotary knob is.
Dec 07, 2009 | Washing Machines
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
