Question about Whirlpool Duet 3.8 cu. ft. Front Load Washer
I have a Whirlpool Duet HT. It is making a knocking sound about halfway thru the spin up cycle. It doesn't make the knocking noise when it is spinning during the wash cycle, when it first starts spinning in the spin cycle, or when it reaches max speed in the spin cycle. The knocking is only in between start-up and max speed. I have verified that it is level right to left and front to back. We have owned it for two years and are familiar with its sounds. It is usually rather silent except when the load is too small or out of balance. I have checked the four shocks and they are all working correctly. What do you recommend? Thanks.
  • 1 more comment
  • Boyd Adair Nov 11, 2010
    It appears to have a little play between the basket and the outer tub. Not much but about 1 cm at the most. I don't hear the bearings but it could very well be loose. Almost feels like a loose bolt in the back of the basket. What you are describing sounds like the logical problem. How do I fix it? I am rather mechanical and can fix most things with general instructions. I do also have the schematic from appliancepartspros.com but I am not sure if I would need to replace the drum drive pully, outer tub, basket, or just the bearings. Also, how long do you think it would take to completely wear out and what happens when it completely wears out. Grinding or worse? Thanks for your help.
  • Boyd Adair Nov 12, 2010
    My email is boyd.adair@gmail.com I would love to have a copy of the installation instrustions. I read in the manual that the tub and basket have a 10 years warranty so maybe I can get them for free. The bearings are clearly part of the tub but I don't know how much you have to push Whirlpool to cover the items. It appears to be an all to common problem with these units. I have only had it for 2.5 years and we don't use it that much. My wife is pretty careful with it. My basket shaft is probably still good since this problem just started occuring a about five loads ago and the basket doesn't appear to have any woble when at top speed. I would guess that any warranty over 1 year from the manufacturer is parts only so I would have to fix it myself (and trade them in) or have someone come out and fix it. Any advice.
    Absolutely, he knows his stuf.
  • Whirlpool Master
  • 2,605 Answers
Hello Boyd,
Welcome to FixYa.
Unfortunately it quite likely is a bearing. The rear outer tub bearing are common problem`s in these frontload washers.
If you think you are capable, **Turn the washer breaker off or unplug it altogether...safety first** Now, first check the basket "play" from the front. Open the door and move the inner basket up and down...just the basket part, you want to feel if the bearing has any wear on it causing the knocking you described. From the back you can pull the panel off and inspect the bearing for signs of water leakage and spin the belt off and give the pulley a spin. This is where to focus for leakage or noise from the bearing... I have a Whirlpool Duet HT.  It is making a - macmarkus_42.jpg
You can usually "feel" a grinding bearing if it is bad, but you`ll also hear it without the motor operating this way.
Hope that help`s. Let me know how you make out or if you find anything...keep me posted.
Thank you and good luck. Regards,
Macmarkus :)
Posted on Nov 11, 2010
  • Mark MacDonald
    Mark MacDonald Nov 12, 2010
    Hello again,
    I'm going to move forward in reverse here...in a sense. I'm going to address your last inquiry first..."how long do you think it would take to completely wear out and what happens when it completely wears out. Grinding or worse?"
    As the bearing wears more progressively the out of balance factor will become increasingly obvious as will the knocking and perhaps scenario's when the items inside are not spun out at all.
    The worst case scenario when the bearing wears to the point of damaging the inner tub seal as well, then you've got rust and grease all over your clothing...it's impossible to put a time table on this sort of thing happening. There are many factors that play into it, water hardness, detergent usage, actual usage, load sizes etc etc.
    To answer your question regarding what is involved to repair it...it is quite involved. If you want to post your email address I can send a complete service manual for the Whirlpool front load washers. It explains pretty well "how to" in the manual, for sure much better than the illustration you're going to get at appliancepartspros I can assure you.
    Any questions you may have from there I can guide you through since I've done quiet a few and have many pictures I've taken along the way for this exact purpose...I know lots of guys can do it if given the tools/guidance. The biggest hurdle is the cost of the parts sadly.
    The basket is presently ( Nov.11/10 ) $208USD at repairclinic.com...shop around. The most common part #W10250573...double check with your actual model number.
    The biggest problem is that when the rear bearing goes out in the rear wall it is going to cause the "spline/shaft" on the inner basket to be damaged/scored" as well...unless it's caught in time, you won't know until you can inspect it visually.
    i.e.
    As you will see in the service manual it is much easier to remove the complete assembly as shown here...
    The rear bearing is sold as part of the complete rear tub, unless you can find an alternate bearing and seal wholesaler and match them up...I haven't found one, but admittedly not looked much either.
    This is the rear tub assy and what's included with the most common number 285984. It presently retails for $215USD at same as above location.
    i.e.
    Let me know if any of this isn't clear or anything else you don't understand please.
    Regards,
    Macmarkus :)
  • Mark MacDonald
    Hello Boyd,
    I just got home, hence the delay in my reply.
    I would certainly contact Whirlpool in regards to this being covered under warranty. If your manual states 10yrs. on the outer tub and inner basket, I would interpret that as the bearings as well...they are not provided separate from the outer tub, so that's married it to them in my opinion...for what it's worth.
    I will send you the manual as soon as I am finished sending this reply to you, I just wanted you to know asap I wasn't avoiding your earlier reply.
    Let me know if you have trouble receiving the service manual, and good luck with Whirlpool.
    Regards,
    Macmarkus :)
Whirlpool duet steam washer knocking noise when in spin cycle.
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems
Washer noise when spinning
heatman101
Feb 13, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Loud knocking and vibration during spin
Check out this tip I wrote about that...
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
Apr 07, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Knocking sound, violent spin cycle led to not
my problem to just 3 days ago from yours! bearings are out, $600 getting a new one.
Jan 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have WP Duet HT front laod washer. Model #-GHW9250ML1 Type 199 080 SC/WG Problems - 1. while the tub is spinning it makes a knocking sound. When the tub slows it knocks louder. What is the problem and...
COULD BE LOOSE BASKET OR REAR BEARING LEAKING OR SIMPLY SUSPENSION SHOCKS BROKEN ,, EVEN SHOWS 1 MINUTE JUST ESTIMATE TIME NOT READY TO SHUT DOWN NORMAL ON DUET MACHINES
Nov 29, 2008 | Washing Machines
Whirlpool Duet sport ht drain and spin seem to be working, but when rinse cycle is selected there is short quick knocking sounds and no action ultimately resulting in an F 30 on the display.
suspect dispenser ..remove top panel dispenser on left side if dispenser arm is binding replace all arms and cams and dispenser motor ..seems to be only fix even whirlpool can't seem to narrow it down to one part
Oct 25, 2008 | Whirlpool Washing Machines
Duet HT has Knock in Spin cycle
well id be leary myself and honestly not at the machine but the tech(s) that are looking at it. i would put back in for another call request a different company if possible.Theres probably 7-8 authorized Whirlpool service Companies in my area alone. acn demand that the tech call the Technical assistance line if unsure of problem.I cant see telling a cust "normal noise don't worry about". these units spin very quietly.On a side note they were installed correctly??? strange to get 2 with came problem..
Mar 13, 2008 | Whirlpool GHW9400 Duet Washer
WHIRLPOOL DUET GHW9100 FRONT LOAD
Take the top off the unit,and check the springs..there are 4 on top and 4 on the bottom..make sure they a attached..and tighten
Jan 10, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Front Load Duet Dryer
Holding the End Cycle button for a few seconds worked! Yes
Aug 20, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
548 people viewed this question
Dan Webster
Dan Webster
Sal De
