Question about Hampton Bay 24002 Ceiling Fan
Need a capacitor - Hampton Bay 24002 Ceiling Fan
What is a capacitor
Posted on Jun 29, 2008
  • 20 Answers
Depending on the type and ratings you need: Home Depot/Lowes, Radio Shack, or Grainger.
Posted on Jun 17, 2008
How can I find comfotmaker maybe 1987 cannot find serial # NEED CAPACITOR MFD & VOLTS
If you need new capacitor you have to buy capacitor MFD and VOLTS same old need serian and anything.
Jul 15, 2014 | Heating & Cooling
Samsung t240 - discharging capacitors?
The main 400v capacitor is the one to watch out for. If you carefully handle the power supply board and avoid the area around the power plug you should be good. To properly discharge the capacitor you would need to use a very large resistor and wire to short out the capacitor but if you do it the wrong way you can damage the board beyond repair. Below is a picture of the T240 power supply board with the 400v capacitor circled in red. If you need to get the other capacitors that need to be replaced on the board, which is the most common problem then you can get a parts it here:
I hope this helps,
Sep 20, 2012 | Samsung SyncMaster T240 24 inch LCD...
I need capacitor
Turn power off at disconnect box. Should be outside by the a/c condensor. is this a run capacitor or start capacitor? if it has two brown wires it is a run capacitor if it has 3 wires such as red, black and brown it is a start capacitor.
Even with the power off the old capacitor may hold a charge. To discharge Take a tool with insulated handles such as a screwdriver and touch all post at the same time. Remove the two or three wires usually both brown one may have a white stripe or three wires make sure to make note on what terminals each color came off of on a start capacitor. On a run capacitor only two wires do not need to mark as they can be on either post . Take this to a HVAC parts supplier in your area. The information on the side of the capacitor will insure you get a proper replacement. have them test the capacitor they should do this for free to insure the capacitor is bad. Reinstall secure wires and turn power supply back on.
Mar 01, 2012 | Heating & Cooling
Turn power off.
Pull the leads off the capacitor.
Read off the capacitor the microfarad rating. (example 5 mfd or 5/30 mfd)
If the capacitor is oval it will have two sets of lead connections.
If the capacitor is round it could have three sets of lead connections.
On the oval capacitor, with a multimeter set on mfd, place one meter lead on one set of lead connections on the capacitor and the other lead on the other set of lead connections on the capacitor. Make sure you have a good connection. Read the mfd reading on the meter. It should be within 5-6% of the stated mfd of the capacitor.
On the capacitor with three sets of leads you will need to look at the top of the capacitor by the lead connections and find which lead is "c", which is "HERM", and which is "fan". Place your multimeter lead on "c"(common) and "herm" lead and take the reading, then take your leads and place on "C" and "fan" and take the reading. Compare these readings with the rated mfd stated on the side of the capacitor.
Sep 02, 2011 | Heating & Cooling
I have a Mach3 unit with 1 capacitor 35uf 370 VAC and a fan capacitor, unit trips breaker after cooling RV when system starts up again, shouldn't there be a run, start,fan capacitor? only have 2...
You need to check the Amp draw at start up of the compressor. Also if you have a meter that can check the compressor capacitor, it needs to be checked. If the capacitor is ok and the compressor starts at a higher Amp draw than the rating on the capacitor, you will need a start capacitor.
Jun 04, 2011 | Coleman Mach III Air Conditioner
Where can I find directions on how to replace the capacitors in the Akai LCT3201AD. I can order the parts, just need to know how to do it. Thanks!
hi, to replace the capacitors need to take the board out, by removing the screws and disconnecting the wires braids. You need bread, tin and absorbs tin. You should take the tin from the legs of the capacitors, until it can release the capacitors outside the board. Next, you put the new capacitors in place. Should pay attention to put the capacitors, by proper polarity of plus or minus. It is important to be precise with the value of capacity and try to put a capacitor with a value of slightly higher voltage, temperature resistant to 105 degrees.
Mar 15, 2011 | Akai LCT3201AD 32 in. LCD Television
I just bought a new compressor for my a/c but the store sold me the wrong capacitor. I need a dual capacitor but don't know how to read microferets to get the correct capacitor. Can you help me?
Do you still have the original capacitor for the unit. They probably gave you the size you need for the compressor. It should have the microfarads printed on the capacitor. The symbol resembles a strange looking u. Then look at the capacitor that came with the unit and get the microfarad rating for the fan. Now you will have the too readings you need to get a capacitor. The fan motor may also have the size capacitor you need printed on the data plate. Let me know if you need more help.
Jul 03, 2010 | Heating & Cooling
USB Problem
for front usb port to be working you must give the 4 pin power cord connection to the front usb header ....
and about the back usb i think dome capacitor is gone so it is not working just have check with the capacitor and if it need get changed with new capacitor ...
if you dont have idea about this matter just visit the technician ...
he will do it..
for the usb be to work it need some power so it is provided by the capacitors as the current goes through capacitors so if the capacitor is gone it will not work as there will be no power supply from the capacitor if it is dead ...
so you need to replace the capacitor ...
so if you dnt have idea just take your motherboard to technician he will have the check and replace the capacitor ...
any doubts reply me
i am always here to assist you
thank you
Apr 16, 2008 | Intel D101GGC Motherboard
Hampton Bay 24002 Ceiling Fan Logo
95 people viewed this question
Top Hampton Bay Dryers Experts
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
