Headset problem - Computers & Internet
    Sergeant:
  • 358 Answers
Try to Examine 1st the sound in a speaker, after that if the speaker don't have any problem and its sound is ok. Your headset is the problem, Maybe you need to bring it to the shop so they will have the waranty of the headset. Also check if your headset is plug-in in the lime green plug in your PC, also check the volume, try to check the front and back of the Plug-in for the headphone on your PC.
Posted on Nov 11, 2010
How do i program my ps3 bluetooth headset?
You can pair the headset in two ways:
  • Automatic mode (using the supplied USB cable) - Enables the headset's advanced features for the PS3. Using automatic mode, you can pair the headset with any PS3, but only the most recently paired PS3 will be saved in the headset's list of paired devices.
  • Bluetooth discovery mode - Sets up the headset as a standard Bluetooth headset. By using Bluetooth discovery mode you can pair the headset with many other Bluetooth devices.
Jul 22, 2014 | Subsonic PS3 Bluetooth Headset Camo
While the headset works frequently, it will suddenly stop. Nothing I do will allow it to connect again. I hear nothing through the headset after the initial beep that indicates headset mode was enabled. ...
It sounds like the battery is no longer holding a good charge. There is no replacement battery for this headset. If you are using the original 510 headset you can replace it or pair a different bluetooth headset up to the 500A base. Just keep in mind if you decide on a different style of headset you will not be able to charge it in your base. I have included the link for the 510 replacement headset below.
Plantronics Voyager 510 Replacement Headset
Good luck from Headsets Direct!
Jul 14, 2011 | Plantronics Voyager 500A Deskphone Adapter...
I can't connect with my phone
Please follow the detailed instructions below for the proper pairing of the headset with your phone.
CHARGING
Before using, you must first charge your headset.
20 minutes = minimum charge
2 hours = full charge
Light is solid red when battery is charging.
NOTE For the best user experience, keep your headset fully charged.
CAUTION Do not use headset while charging and do not connect the charger while the headset is in use.
POWERING
Press the control button for 2 seconds to power on. Press the control button for 3 seconds to power off.
PAIRING
Step One:
Prepare Phone- Turn on Bluetooth For most phones, go to Settings/Tools menu and select Bluetooth or Connectivity and select "On."
Step Two:
Prepare Headset- Pairing Mode Begin with headset turned off. Turn headset on (hold call control button for four seconds until the light flashes blue) and it will automatically go into pairing mode, flashing red and blue.
Step Three:
Pairing- Add Headset to Phone For most phones, go to Settings/Tools
> Bluetooth > Search or Add a Device, then Select "220Plantronics." For passkey enter
0000. Headset will flash blue when paired successfully. It is now powered on and ready to use.
NOTE: Normally you only need to pair the headset and handset once. If headset has been previously paired with another device, follow pairing instructions below.
If headset has been previously paired with another device, please follow these instructions for pairing a second time. Be sure the headset is fully charged.
1. Press and hold down the call control button for 8 seconds until the headset status
indicator begins to flash blue then red.The headset is now in pairing mode for the next 120 seconds.
2. While the headset is flashing,use the phone menu to search for Bluetooth devices and select "220Plantronics."
3. When prompted for a passkey, enter 0000. Headset will flash blue when paired successfully.
NOTE: The headset can pair to multiple Bluetooth devices, but will only connect to one device at a time. The headset will automatically connect to the last device to which it was connected.
Please don't forget to rate me if satisfied.Thanks for choosing Fixya.Good Luck.
Jun 11, 2011 | Plantronics Explorer 220 Bluetooth Headset...
I have a CS70 NC./ no lifter. What is the set up procedure to use my headset without lifting my phone handset. With the base plugged into the headset port of the phone.
If the Plantronics CS70N wireless headset is plugged into the headset jack on your phone, you will need to push the headset button on the phone and then the call/control button on the wireless headset.
Jun 10, 2011 | Plantronics CS70 Wireless Headset
The headset will not charge. If I hold down the black button on the headset for app 15 seconds, the red light comes on the headset but it will sgo off in just a few seconds. Is there a battery in the...
Yes, the headset has a battery, but it's non-replaceable. If you've had it for some time and your battery is going out, you will need to replace the headset. Below is a link for the replacement headset that you can check out:
Oct 19, 2010 | Plantronics Voyager 500A Deskphone Adapter...
Blinking green light on microphone, headset not working
The blinking light means headset is muted. Un-mute the headset by pushing the small toggle switch on the back of the headset.
You may need to reset the headset. You can do this by first pressing the mute switch on the back of the headset and then simultaneously pressing the call switch on the side of the headset for about 4-5 seconds.
You will need to pair the headset with the base again.
Mar 13, 2009 | Plantronics CS55 Wireless Headset
Headset
try to barrow your friends headset and try it..if it works your headset is broken but if it didn't work your gadget is broken.
May 22, 2008 | Logitech ClearChat Stereo Headset Headset
Headset not working
Sounds like your headset isn't paired with its base. With the headset in the cradle press and hold the button on the left side of the base that has two arrows on it. You should see the blue light on your headset turn on. Its now paired to the base.
If that doesn't work, remove the battery from the headset. (This is the back piece of the headset.) Wait a few seconds and then snap it back on to your headset.
Good luck.
Dec 07, 2007 | GN Netcom GN 9330 Wireless Headset
Nokia 6260
try a master reset on your phone, this will be located somewhere in the settings
May 15, 2006 | Nokia 5100/6100/6300/7100 Series Black...
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
