Question about HP Color LaserJet 2600n Printer
First it was putting magenta stripes down each page, now they are joined by blue and yellow stripes. It looks like you melted crayons together and drew a big fat set of lines down each side of the page.
  • 2,296 Answers
1. There are some options in the menu to clean the printhead, refer to user manual for the instructions.
2. If that won't fix it, check the cartridges to see if there is any toner leaking out of them.
3. If none of the above fixes it, you might have to replace the print head.
Posted on Nov 11, 2010
My printer is low on yellow and magenta and is printing a stripe of each color on the papers edge.
Hi.
On the drums for each colour there is a purple/blue/green slider for cleaning the corona wire. If there is a stripe of colour anywhere on the page going from top to bottom check these sliders. They need to be where the arrow on the slider meets the arrow on the drum casing.
As for low toner on the Yellow and Magent - Replace the cartridges.
Jul 17, 2014 | Brother MFC-9325CW Wireless All-in-One...
Melted crayon all over my car upholstery
To remove melted crayon from upholstery:
1. Scrape away melted wax from the upholstery as much as you can using a blunt knife. 2. Put a brown paper, or butcher paper (glossy side down) on top of the affected area then using the tip of a hot flat iron, melt the crayon until it stick to the paper. 3. Let the paper cool then lift it away gently from the upholstery. 4. Dab a small amount of denatured alcohol to remove any remaining stains then finally clean the affected area with sponge and water.
Hope this help. Goodluck!
Jul 19, 2011 | Crayola Classic Color Pack Crayons...
Need to know speaker wire colour config for 1994 4runner (toyota) as well as power and earth wires
A Right Front Speaker (+) Green Gray B Left Front Speaker (+) Pink White C +12 Volt Ignition Wire Gray Red A B C D K L D +12 Volt Battery Wire Blue w/ Yellow Stripe Yellow E Right Front Speaker (-) Blue Gray w/ Black Stripe E F G H I J M N O P F Left Front Speaker (-) Purple White w/ Black Stripe G Ground Wire Black Black H Power Antenna Wire 1 Blue (join wires 1 & 2 I Power Antenna Wire 2 together to this blue wire) AS VIEWED FROM MATING END OF CONNECTOR Do Not Use J K Right Rear Speaker (+) Red Purple L Left Rear Speaker (+) Black Green M Right Rear Speaker (-) White Purple w/ Black Stripe Do Not Use N Do Not Use O P Left Rear Speaker (-) Yellow Green w/ Black Stripe
May 29, 2010 | 1994 Toyota 4Runner
Dont know if you can help but....I just bought an older model pick up(1989 toyota)it had no radio in the dash, I have a Kenwood CD player i want to install but I dont know the color codes of the wires in...
Nice radio installer link HERE
Check out the lower wiring guide.
J Do Not Use
N Do Not Use
O Do Not Use
Dec 14, 2009 | Car Audio & Video
Im lookin fer the radio wiring diagram for my 1996 geo prizm because someone cut the standard clip for the stock radio out
Under the center console/dash you should has two connectors.
LARGER CONNECTOR
C Right Front Speaker (-) Blue Gray w/ Black Stripe
D Left Front Speaker (-) Purple White w/ Black Stripe
E Ground Wire Black Black
F +12 Volt Ignition Wire Gray Red
G Power Antenna Wire 1 Blue (join wires 1 & 2
H Power Antenna Wire 2 together to this blue wire)
I Do Not Use
SMALLER CONNECTOR
J Right Rear Speaker (+) Red Purple
K Right Rear Speaker (-) White Purple w/ Black Stripe
L +12 Volt Battery Wire Blue w/ Yellow Stripe Yellow
M Left Rear Speaker (+) Black Green
N Left Rear Speaker (-) Yellow Green w/ Black Stripe
Dec 02, 2009 | 1996 Geo Prizm
Our Phone wiring is underground and the connector box on the outside of mthe house was done in1978. My problem is that I hit the wires and some of them were knocked loose from the terminal and now I don't...
green wires and red wires.......... that is line one. also solid blue and blue with a white stripe is also line one..... so tie the greens and blue w/white stripes together and tape off (if not screwed down to block), and do the same with the red wires tied together with the solid blues.
yellow and black is line two.....and so is solid orange and orange w/white stripe. then just fill in the blanks as stated above.
its simple, think of the wires as speaker wire in a way to simplify what you are looking at. multiple Pairs (+/-) wires color coded. if the wires came off of the screw down posts, just match up the colors like stated above on the posts and screw them back down.
Nov 13, 2009 | Uniden 5.8GHz 2Handset Digital FHSS...
Faded stripe down the printed page
I found a solution that worked to eliminate the faded black stripe down the page thanks to a post by slamfix in another forum. The problem is related to ink build up on the blade edge of the black developer assembly in the imaging unit (the imaging unit contains 4 separate developers - yellow, blue, magenta, and black). The solution involves taking out the imaging unit, removing and cleaning the blade edge of the black ink developer until smooth. It took me about 15 minutes to complete and was fairly straightforward.
Detailed instructions with pictures can be found at http://losingambition.com/clp300imagefix/
Apr 04, 2009 | Samsung CLP 300 Laser Printer
Ink in blue slot is not dissolving
If your printer still can print but with no cyan color then you most likely have a bad printhed. If your cyan ink is not melting it's because it is not using any ink . Get into the "print quality" menu and print the test page. If you get black, yellow, and magenta but little or no cyan then your printhead is bad. Whith these machines cyan is the first color to have poblems starting with weak or missing jets.
You can try to run the "eliminate light stripes" to see if it will help.
Run it about 3 to 5 times. If still not working right, turn the printer off for at least 4 hours and then test again.
Hope this helps,
Dan
Oct 28, 2008 | Xerox Phaser 8500/DN Printer
Stripes down left margin
Hi, I have the same problem, which has just been diagnosed as a defective developer drum by a repair specialist. The new part is $120.00. Should have the serviced unit back
SR
Oct 16, 2008 | Ricoh Aficio CL3500N Laser Printer
HP Color LaserJet 2600n Printer Logo
278 people viewed this question
Seeker5211
Seeker5211
