Question about GE Spacemaker JVM1640SJ Microwave Oven
GE Microwave Spacemaker over the range
I have a GE Spacemaker microwave that is 8 years old but is in a cottage and only use 3 months a year. It worked fine until we returned this year and it was dead. However, after playing with the pad, it turned on and would cook on the 30 second mode. However that lasted only a few days. I have to call a repairman as I have no clue about the repairing the oven. My question is do you think it is a problem that can be repaired at a reasonable cost or should I go for a new one (so very costly). Thanks for any advice you may have. I sure do appreciate it.
  • Winkers Jun 24, 2008
    Thank you for your help in this matter!
  • GE Master
  • 9,098 Answers
It sounds like you may have either a defective keypad or control board.
Is the cottage kept heated in cold months?
Is there any rust on the microwave chassis underneath or on other appliances or surfaces inside the cottage?
This would be evidence that there is condensation settling on the controls or keypad of the oven.
We can normally repair a control panel assembly for $39.95 and if it needs a new keypad, that can add anywhere from $50-$100 to the total, depending on the part cost.
Please feel free to contact me directly if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on Jun 22, 2008
GE micro died
The main fuse is the probable cause, magnetron, "heart of the microwave oven" the inverter board, "if 7 years old or less" and the keypad control board can be a factor.
Apr 21, 2012 | GE Profile Spacemaker Over-the-Range...
Have Spacemaker Microwave--JVM1630WB 004. started cooking ,heard a POP!! , and it did not cook the food. smelled like burnt wires or capacitor. No fire. fuse did not blow. Any suggestions ?
I had the same thing happen to my 20 year old Frigidare microwave (it was 8 years old at the time). Same POP!, same failure. Though I'm handy with electrical, I don't mess around with the innards of a microwave. There are lethal doses of electricity stored in some capacitors even when the device is unplugged. I took mine to an appliance repair shop that works on microwaves. In my case, a high-end capacitor had blown. The repair cost me $80.00. $5.00 for the part, $75.00 for the labor. My microwave is still working 12 years later.
My solution is not pleasant. If you call a tech out to your house, his charge for labor and parts will probably be more than the cost of a new microwave. Taking it to a repair shop is cheaper, but you would want an estimate first which in itself will not be free of charge.
New microwaves have come down in price over the years. Countertop models for as little as $100.00. Over the range models starting at about $250.00.
Whatever you decide, this is going to cost you some money. Your microwave is dead. Good luck and hope I've helped a bit.
Jan 02, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
I plug in my microwave and it works for a few minutes then a error message reads key pad shorted the model number is jvm1740dm1bb
That is the worst microwave that you can buy. GE give you 1 year warranty, after that they send you a maintanence plan $50/month. They change mine 3 TIMES during the warranty period, after that works for 6 months and brake again. Always the problem was the KeyPad. The guy that they sent never told me a real reason for that, so I think is manufacturing defect. I put my GE JVM1740DM1BB to the trash.DO NOT BUY GE AGAIN
Dec 15, 2010 | GE Spacemaker 1.7 Cu. Ft. Over-the-Range...
GE spacemaker not heating
the magnatron has gone bad and maybe still under a warranty need to check with ge.if it is not then in most cases it is cheaper to go buy another microwave than to have it replaced.
Feb 23, 2010 | General Electric Microwave Oven
Microwave oven just quit. Have checked fuse and plug. Have had no earlier problems. Do these ovens just ''wear out''? It is 8 years old. It is a GE Spacemaker. (November 2002) GE Spacemaker Serial...
yes they wear out. usally the first part to quit is the unit inside that creates the microwaves called the "magnetron" over time they will wear out, and so will the circuitry that runs the entire microwave, some will last 8 years like yours, some only a year or 2. 8 years is pretty good for the life of a microwave. but yea, its time to get yourself a new one. good luck to you
Jan 15, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I own a GE over the range microwave, model #HVM1540DN1BB The touch panel doesn't work at all. I can't even set the clock. I even umplugged it for a couple of DAYS, and still nothing. I called GE, and they...
This model from GE is a ****..they replaced the keypad once wihtin first 2 months..now just after warranty..same issue again. Never buy GE products. The replacement key bad is $44+shipping in many onlne parts store..I am giving it one more try..next time this happens..GE will be out my door!!
Dec 10, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Ge spacemaker xl 1400 microwave stopped heating & there is an odor like melting plastic Can it be repaired. Is it worth it to repair. Unit is 8 years old.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
fgkjf
Dec 07, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Touch control failed on GE Spacemaker Microwave HVM1540
If you want to order a touch pad, (it has the micro computer built in it!) and fix it that way, you'll still have a 2-3 year old machine.
I would say it would be quicker and cheaper to buy a new one.
Jun 25, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
My GE spacemaker microwave doesn't heat up foods. There is a slight bit of heat generated but not much. All timers, lights, etc. work normal. It is a GE model jvm1440. It is about 3 years old. The problem...
IT COULD BE A NUMBER OF THINGS RANGING FROM DIODES TO CAPACITORS TO YOUR MAGNATRON OR THERMOSTAST OR TRANSFORMERS. IT'S DIFFICULT TO DIAGNOSE WITHOUT SEEING THIS MICROWAVE. YOU MAY BE BETTER OFF GETTING YOURSELF A DIFFERENT ONE.
Apr 11, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Ge over the range microwave
well randy you might want to check the diode and cap with a meter first before getting the mag tube. if both of those parts are fine. replace the tube.
Apr 19, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
116 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
