Question about Seagate BARRACUDA ES.2 - HARD DRIVE - 1TB INTERNAL - 3.5IN - SATA 3GB/S - 7200R 1 TB Parallel
My hard disk dosent get detected but if i touch it then i can feel motor inside is rotating please help
    Problem Solver:
  • 18 Answers
Could be the sata cable not seated properly or bad cable. check connections. If its the only sata drive connected make sure it's plugged into sata #1 slot. Could be drive, motherboard or bios problem. Next step would be to update the bios. That might help.
Posted on Nov 11, 2010
The bios says 'NO DRIVE". In the peripheral it says hard disk not used. I have ahard disk installed, but it dosent find it! Help
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Nov 08, 2012 | Toshiba Tecra M2 Notebook
I lost power at my house and when the powr came back on my hard drive won't turn back on
how do you know that your hard disk is not turning on? Get the message displayed on the screen when you turn on your desktop first, if it says "boot device failed" or something like that (depends on motherboard model, company and bios version) , check your hard disk is detected or not by bios if not so, open your desktop cup's cover were something made with plastic or rubber on you hand and touch hard disk to see if it is running while pc is on (if running, you will feel something moving inside). If hard disk is detected by bios then it's a case of damaged operating system, just recover or re install operating system. This kind of problem happens for bad sector of hard disk caused by sudden power loss. If hard disk is not detected by bios or running, make sure machine is turned off first, just unplug the power cord of hard disk and plug it back then restart your machine to see if hard disk runs. If not so , go to some repairing shop to check your hard disk.
Jun 24, 2012 | HP Compaq Presario SR1320NX PC Desktop
My 1tera HD is not working.cannot detect by my laptop.same as the other pc. please help. thank you
Welcome to Fixya. If the computer and the laptop can't detect the hard disk try to go to Bios page see if the hard disk is detected. If yes you still have a chance to recover the files inside it however you need a software to do it. If no then the hard disk is bad. Check the warranty of the HD so that you can ask for a RMA or replacement for it.
Thanks for usin
g Fixya.
Feb 22, 2011 | Western Digital Computers & Internet
My Hard Disk is not being detected by my computer and i think there is a problem inside the hard disk as i cannot feel the normal spin inside the hard disk
Fix by an expert required such as www.SaveMyUSB.com
1. Faulty USB port on PC: Try a different computer or laptop
2. Faulty USB cable: Try a different Cable
3. Corrupt memory: Fix by an expert required such as www.SaveMyUSB.com
4. Faulty connections on main circuit inside the hard drive: Physical Fix by an expert required such as www.SaveMyUSB.com
5. Faulty controller chip (worst case scenario) : Direct flash memory read required by an expert required such as www.SaveMyUSB.com
Hope this helps and that it is 1 or 2 as 3, 4 and 5 will cost you money.
Good luck
Jan 01, 2011 | Seagate FreeAgent GoFlex 750 GB USB 20...
I can feel d disk rotating yet PC doesnt recognise the drive
Hi There mosam,
In most cases, external Passport Drives come with their own drivers and install themselves automatically when connected to your puter's USB port. If it doesn't find a driver, then the Passport can't work. Go to the Western Digital Support website and type in the model # of your external drive. Having located the driver for that model, download it by saving it to your desktop. Then run the exe. driver install software. Once having done so, your Passport should show right up and off you go! Very Important...if the driver install program wants you to restart your puter after installing itself, be sure to do so. Good Luck!
Apr 04, 2010 | Western Digital WD Passport 250GB Portable...
My mac says that it cannot detect a hard drive but it is powered up and plugged into usb port. help!
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hello,
Open the external hard drive cover, remove the hard disk inside, and fix it back. Try again and let's see what happens.
If it still does not work, insert the external drive into the computer, feel the hard drive if it spins/vibrate from inside or if it makes a cracking noise.
If it spins/vibrate, it means the hard disk is still working. In that case, you have to get another external drive case/cover.
But if it makes cracking noise, then it means the hard drive is damaged and you need to get another one.
I wish you all the best.
Jan 08, 2010 | Computers & Internet
Hard disk can not detect and giving beep randomly. hard diisk is from seagate and capacity is 80 gb
Hello there..i have experience with same problem like this...there is two problem with hardisk: first with the mechanic platter inside your hardisk ( you can hear noisy sound from inside HDD) 'cause by wrong prosedure when turn off the pc or problem with chipset on hardisk board (you can see the small green pcb board at other side of your hard disk) touch that board...if feel hot yes there is problem.this problem cause by electrical shock from your power supply unit or you not plugin correctly to hdd power socket.
solution for first problem :
send it to nearest seagate 'cause they have all the parts that you need
solution for second problem:
replacle the board with same tipe and size of your hdd..and it will work again and you can safe your data.but if not...nothing you can do it
Best Regrad
SHOGUN 125
Jan 21, 2009 | Seagate Barracuda 7200.7 ST380011A 80 GB...
WD Notebook Essential 80G just quit working
if you are not getting any broken noise from the hard disk its not ded so ushut down the computer first then connect the hard disk to the power and then connect the hard disk to your system in the usb 2 port then connect the start the system if still dosent detect go to manage by right clicking on the my computer icon the go to disk management check your hard disk shows ther if shows forign just right click on the forigen and say import forigen hard disk if shows the drive helthy and dosent show up on my computer then just right click on the helthy place and say change drive letters and choose one of the letters and should show up on the my computer if still dosent see at all then change the usb cable....
if still dosent work remove hard drive from the external case and put it directly to your computer for this u need a sata cable and a sata power if it detects and work this way your data is safe but you casing of the external hard drive has probs ...
thanks
Nov 12, 2008 | Western Digital 320GB MyBook External USB...
Hard drive not being detected
It's possible the circuitboard inside is broken.
Apr 05, 2008 | Maxtor OneTouch III Mini Edition (R01E100)...
Seagate BARRACUDA ES.2 - HARD DRIVE - 1TB INTERNAL - 3.5IN - SATA 3GB/S - 7200R 1 TB Parallel Logo
129 people viewed this question
Top Seagate Computers & Internet Experts
Computer Links
Steve
terminalcon
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
