What wires beside the sata hook to the hard drive and I changed the ac/dc cased power supply and it has one les set of wires than the origanal that could posible hook to the hard drive.
  • 32,281 Answers
You can get a "Y" power adapter if you find there is not enough power connectors.
These power adapters makes two power connectors from one connector. If you do not have enough SATA power connectors the you can get a 4 pin to SATA power adapter.
Posted on Nov 11, 2010
    Problem Solver:
  • 13 Answers
You may need to purchase an 'adapter' but this isn't an adapter like you plug in to a laptop or phone charger. It is a 'molex to sata' adapter. These can usually be found at places like Fry's Electronics, Best Buy stores and local computer shops. You should not need to pay more than about $6 for this item and you may be able to find it for as little as $2-3. While you're there, you might want to pick up a power 'y' splitter, so that you have more outlets available. BUT, you must be careful not to attach too many devices to one 'rail' which is one section of wires coming out of your power supply. Too much power drawn can cause performance problems and can even damage your power supply or system components.
    Problem Solver:
  • 18 Answers
Well you have the sata cable. It connects to the motherboard. You also have the power cable from the power supply that connects to the drive. As for 1 less set of wires on the power supply. Not a big deal unless you need it. Does the power supply have the same or higher output wattage as the one you replaced? Does it have sata power or just the molex 4 pin only? If it has the 4 pin only you can get an adapter for a couple bucks to convert it to sata power. Make sure the new power supply has sufficiant power for the system.
Macally G-S350SUA power supply
  • I have the same Macally hard drive enclosure and I misplaced my power supply also. I used an old IBM Thinkpad power supply. These are common and cheap. The Macally enclosure states 12V DC input, and the Thinkpad PS is rated at 16V but it works fine. The plug and polarity are correct.
Oct 11, 2012 | Macally G-S350SUA 3.5" Hard Drive...
I have a Hitachi internal hard drive that i would like to use as an external hard drive to boot from my e-sata port, i have a Toshiba portege and i curently use two hard drives to boot from, one for work...
yes you need power to the external hard drive whether ide or sata possibly depending on your hard drives power supply
12V+5V AC sata Adapter Power Supply HDD HARD DISK DRIVE
hope it helps
Mar 27, 2012 | Hitachi HTS541612J9SA00 120 GB SATA Hard...
Trying to make my seagate barracuda 7200.9 slave
1) Open your computer case
2) On the back of the drive where the connectors are, you have jumpers. These small plastic tabs change the function of your hard drive. All hard drives have a special setup procedure. The information about jumper settings is on the top of the hard drive.
3) Remove plastic tabs and put them according to "Slave" instructions.
4) Connect drive to middle connector of the cord.
5) Connect power supply cord.
6) Secure the drive in place and close computer case.
Also make sure that the main drive is not set as slave.
Apr 10, 2011 | Seagate Barracuda 7200.9 80 GB Hard Drive
I have a good power supply, but the unit will not power on using AC or USB power source. Can I move the hard drive to another unit to recover my data?
If the hard drive has a SATA fitting and Power SATA fitting like a normal hard drive ( or the 4 pin molex and an 40 pin ide fitting) yes you should be able to
Mar 30, 2011 | Vantec 1 Bay NexStar 3 USB 2.0 External...
I plugged in the wrong power cord to my p/n 9nk2ag-500. Is there a way to fix? or self extract files? I keep hearing about a SATA gadget that can convert any externat HD to a USB powered, will this bypass...
yes if the hard drive is not damage
you can use a external sata case to read your hard drive.
remove the casing off the seagate freeagent to get to the hard drive.
you need to get a 3.5" external sata case.
you can get one from newegg.com or at your local fry's
this is what i have
http://www.newegg.com/Product/Product.aspx?Item=N82E16817153066&cm_re=thermaltake_sata-_-17-153-066-_-Product
which supports both 3.5" and 2.5" sata hard drives.
Mar 20, 2011 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
I have several computers at home, and none og them can recognize this portable device. Hitachi 250 GB Mod: SDM/250RW
1) Power:
It may be the problem that occurs with a lot of USB powered devices jrherrer. Not enough power provided.
The USB cable plugged into the computer, provides signal wires for transferring information back, and forth, and also provides 5 Volts DC for power. (Two D cell flashlight batteries produce 3 Volts DC)
http://en.wikipedia.org/wiki/USB
[ Below shows the Signal pins, and the Voltage pins of the USB B Mini style connector, (Male), used to connect to the SimpleDrive Mini external harddrive,
Pin 1 is for the 5 Volts DC Positive (Wire color - Red)
Pin 2 is for the D- Signal (Wire color - White)
Pin 3 is for the D+ Signal (Wire color - Green)
Pin 4 is not connected. (Or sometimes joined to Pin 5 with a Resistor)
Pin 5 is for the Ground (Wire color - Black)
Just added info in case you wanted to know ]
From what I see the SDM/250RW has a USB port on the side, and a DC Power Jack, used for an AC adapter, also.
(Round port with a pin in the center)
http://www.hitachigst.com/tech/techlib.nsf/techdocs/0C876B7AB91B23988825773F006BEA02/$file/SD_Mini_DS_final.pdf
From what I see stated from Hitachi, and sellers on the 'net, the AC adapter may not be provided.
Many of those who provide a review state that both the USB cable, and the AC adapter is needed to provide enough power. Seems to be a power hungry external harddrive
It's a 2.5 Hitachi SATA laptop harddrive inside that external case. (The Harddrive is 2 and a half inches across in Width. Common size used for laptops)
When using an external device powered by a USB cable there are general guidelines to follow,
A) The USB cable should not be more than 2 feet in length
B) Connect the device directly to your computer, instead of through a hub, or other device, unless the USB hub has it's own power.
2) USB cable:
Could be a faulty USB cable, although I imagine you have tried different ones by now.
3) Interface Circuit Board:
The Hitachi SATA 2.5 harddrive inside the SImpleDrive Mini SDM/250RW, plugs into a small circuit board located inside that external case.
Components on the circuit board may be fried, or the Harddrive may have come loose from the interface.
Loose from the interface
To explain;
The back of the harddrive has connector pins sticking out.
The interface has socket holes which the pins insert into.
Faulty circuit board
The external case of the SimpleDrive Mini SDM/250RW can be carefully opened up, and the Hitachi SATA 2.5 harddrive extracted out.
Another inexpensive external case for a 2.5 SATA harddrive can be procured, and the Hitachi harddrive put in it.
Example of a 2.5 SATA external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3743049&CatId=2781
Nov 22, 2010 | Hitachi SimpleDrive Mini 250GB USB 20...
When I turn on the drive, the front pushbutton continually flashes red and blue, and the drive is not seen by the computer. It had worked fine up until now.
Its sounds to me like the external unit has died. This seems to be a common problem with this manufacturer after about a year of use. In most cases the actual hard drive will be fine but it will have to be removed from the case in order for the data to be accessed.
Oct 31, 2009 | Acomdata HybridDrive E5 Hard Drive
Part No. 9W2874-582
Sata drives use both 5V and 12V power. The standard SATA connector found on most current power supplies carries both. If you're trying to rig up some temporary power just hit your local PC shop and ask for a Molex to Sata adapter that will connect your old power supply to the new drive or pickup a USB to SATA adapter kit as they usually have there own Sata capable power adapter.
Hope this helps FixYa,
Chris
Oct 21, 2009 | Seagate 500GB Maxtor Diamondmax21 SATA2...
Wanting to install a mp6212 cd player in my tool box at work
for proper operation, you will need 12V.
Some vehicles wont start unless there aer 8V.
Minimally 8VDC, but 12V recommended for proper internal amplifier operation. Purchase a used PC Power supply, and wire directly to the hard drive power pug. Inverters are also available.
BTW Amps are a measure of AC Current, not DC. DC is measured in Volts.
An Electrical appliance rated to work on AC will not work with DC, and vice versa.
You will need an invertor of some type to change the signal and wavelength.
Dec 26, 2008 | Jensen VM9510 Car DVD Player
I have 3in1 USB 2.0 to IDE & SATA Cable but nothing to show me how to use this kit
SATA 3.5" 2.5" IDE 3 IN 1 TO USB 2.0 CABLE ADAPTOR KIT
1 external connection kit
1 internal connection kit
The internal connect kit consists of 1 red USB connector cable
and 1 internal white male molex connector to SATA female power connector
( 1 yellow wire , 2 black wires , 1 red wire )
the external connect kit
consists of a 3 pin power adaptor (with a tiny plug to save space) feeding a power supply which powers either IDE thru a Molex connector or SATA through a supplied adaptor. Supplied also are data connectors to link the IDE or SATA hard drive with a USB port. Use this adaptor set to retrieve data from a hard drive when it is not mounted in a computer.
Selah :-)
Sep 14, 2008 | Computers & Internet
Computers & Internet Logo
54 people viewed this question
David Payne
David Payne
