Question about Mitsubishi WS-65907 65" Rear Projection Television
Mitsubishi WS 65819. Had convergence problems. Pulled center board and had convergence ICs professionally re-soldered. Put board back in and now tv will not power on. No blinding green light or anything. What can I do.
  • Mitsubishi Master
  • 5,138 Answers
Your post is showing 2 different model # which one is yours the WS65819 or the WS65907?
Posted on Nov 11, 2010
I have a 65inch mitsubisihi and having convergence problems need help on instructions to put in stk-392-570 chips to fix the problem. WS-65819
Here is a youtube video I found that was quite helpful to repair my WS-65819 this weekend: http://www.youtube.com/watch?v=63TbxQaNkVo
There is a part 2 that deals specifically with the soldering of the chips. Hope this helps
Sep 26, 2011 | Mitsubishi WS-65819 TV
Mitsubishi WS-65819 has convergence bows on top and bottom of the screen. The ic's stk 592-570 seem to be soldered tight to the circuit board. Wondering if the ic's are gone bad. Can you give be some...
Yes the ICs and Pico fuses need to be replaced. You can get the convergence repair kit for your model from www.tvrepairworld.com which has the ICs and fuses plus the CD with repair instructions.
Feb 15, 2011 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi WS-65819__Convergence bows at top and bottom of the screen. Pops in and out and if I take off the front speaker grills and Picture tube cover and place a fan in front of it to keep it cool, it...
Correct, convergence output chips are getting heated and causing problem. Replace them to solve tv issue.
Also check dry solder connection nearby these chips, resoldering these solder connections will cure dry solder joints problem as well.
Thanks.
Dec 24, 2010 | Mitsubishi WS-65819 TV
My picture flips to and from a balanced convergence to one that seems to arc? Any thoughts on a repair?
Tv have a convergence problems,it dead.Tv have colors lines R,G,B mis alignment,have a colors shadows pictures or 3D look alike.The tv convergence board have 2 STK convergence ICS and some or all it resistors are dead.These parts on the convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Oct 28, 2010 | Mitsubishi WS-65819 TV
I have a 65 in Mitsubishi rear projection TV that started showing a blueish Ghost effect in the picture as if out of alignment with the guns or something. Is there anything I can do to check this out or...
This tv have a problems known as a convergence.This problems the tv convergence board,must have the 2 STK convergence ICS some or all it resistors be replaced to solved the convergence problems.These problems are 3D pictures,colors out alignments,colors have shadows,pictures of colors mesh it all together.The shop will cost u $300-350 for parts and labors.
Jul 01, 2010 | Mitsubishi WS-65819 TV
Turns off as soon as I turn it on. ws - 65819
I had the same problem. The repairman said the Convergence ICs were bad, located on the big aluminum heat sinks on the center board in the TV. He replaces both, and a couple of fuses (that look like resistors).
The tv worked fine for a couple of days then did exactly the same thing. They are coming back out to fix it next week. If there is anything different, I'll post an update.
Nov 22, 2008 | Mitsubishi WS-65819 TV
Mitsubishi WS-65807 blinks '22'
Jim,
yes the convergence Ics are what cause the two picos to be open they are both 5 amp picos. You can get the picos, the convergence ICs and the factory service manual for your model at the following link.your model is known as the V17 chassis for service manuals and you should require two STK392-570 Convergence ICs. Heres the link they provide free instalation instructions.
http://servicemanuals.vstore.ca/
Oct 02, 2008 | Mitsubishi WS-65807 65" Rear Projection...
I replaced the pico fuses and the convergence IC's. fuses poped right away code 22 . Further inspection of the board showed the coolant had leaked out of the center projector and fried the board. Not willing to pay $300. Passed it on to someone else
Oct 01, 2008 | Mitsubishi WS-65907 65" Rear Projection...
STK IC info
the convergance amplifiers are STK392-570 there are two of them they both must be replaced they are located on the power board. they are on the lagest heat sink on that board. yes, they need to be soldered to the board. they look like this:
70a4bc9.jpgthere also may be some resistors and fuses that failed. if you are not a tech do not attempt this repair if you do you may end up with further issues or dammage to you or the set.
May 25, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Arched or bowtie effect
You have bad convergence Ics they are mitsubishi part # 267P150010 Generic part is STK 392-570 and they are at locations Ic8c01 and Ic8co2 on the deflection board. If you can solder you can take these out replace them and fix your problem for about 100 dollars. Best of luck
Josh
Feb 08, 2008 | Mitsubishi WS-65819 TV
Mitsubishi WS-65907 65" Rear Projection Television Logo
161 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
