What happens when you change the monitors to the different ports? Does the violet monitor stay violet when it is plugged into the other video port?
I am guessing that the monitor that is violet is using a VGA connection
The most common cause of a monitor displaying a pink or violet color cast is that one of the RGB conductors in the VGA cable is broken, or the plugs are not firmly seated in the sockets, leading to one color not firing on the monitor. Try a different cable. Try plugging it in with DVI instead.
All branded car stereo system color cods are same.
FR-speaker:brown,brown with black.
FL-speaker:white,white with black.
RR-speaker:violet,violet with black.
RL-speaker:green, green with black.
Yellow:battery.
Red:key main ( acc).
Black:ground.
Blue and blue with white: amp remote or power antenna.
Thanks.
see connection colors below and let me know if you have questions.
2004 Nissan Sentra wire colors aftermarket radio wire colors
Car Radio Constant 12v+ Wire: Pink, yellow
Car Radio Switched 12v+ Wire: Blue, red
Car Radio Ground Wire: Gray, black
Car Radio Illumination Wire: Red/Green, N/A (tape off factory wire)
Car Stereo Dimmer Wire: Red/Yellow, N/A (tape off factory wire)
there is no factory amplifier wire, blue (tape off radio wire)
Left Front Speaker Positive Wire (+): Pink, white
Left Front Speaker Negative Wire (-): Blue, white/black
Right Front Speaker Positive Wire (+): White, gray
Right Front Speaker Negative Wire (-): Black, gray/black
Left Rear Speaker Positive Wire (+): Light Green, green
Left Rear Speaker Negative Wire (-): Violet, green/black
Right Rear Speaker Positive Wire (+): Blue, violet
Right Rear Speaker Negative Wire (-): Pink, violet/black
white/blue
white orange
white green
white brown
white slate
red blue
red orange
red green
red brown
red slate
black blue
black orange
black green
black brown
black slate
yellow blue
yellow orange
yellow green
yellow brown
yellow slate
violet blue
violet orange
violet green
violet brown
violet slate
**Keep all pairs together and you should be fine***
there pretty simple red+ goes to keyed power wire. yello is the same keyed power wire.black ground. speake wire will be like two green two violet one will have black stripe that is the negitive solid color is positive green and green violet ant violet white and white blue and blue youll just have to figure out thr front and rear. blue wire is for amp remote turn on wire your speaker wires may be different colors but same idea
the iat is part of the maf sensor located in the air filter duct or housing. 6 pin connector. pin one color violet/gray is for iat. pin 2 is c-signal rtn yellow/violet. pin 3 maf yellow/violet. pin 4 maf rtn blue. pin 5 ground black/yellow pin 6 circuit breaker fuse 76 blue/brown
You might have "color filter" settings. Turn the digital filters off. Here is what manual at p72 says.
"You can take pictures using digital filters. The filters consist of color filters such as red, blue and green, a soft filter that produces a fuzzy effect. Color filters Eight colors, black-and-white, sepia, red, pink, violet, blue, green and yellow, are provided for the color filters. When you select a color filter in the Digital Filter mode, the display on the LCD monitor is filtered with the selected color, and the pictures are taken in that color."
