Question about Insignia Pilot MP3 Player
HELP ME I plugged in my player and windows says, "Windows successfully loaded the device driver for this hardware but cannot find the hardware device. (Code 41)"" Could you explain this to me and am I able to fix it?
You need set the settings on the player to file and folder in the usb mode
Posted on Dec 07, 2008
  • 8,596 Answers
Code 41Windows successfully loaded the device driver for this hardware but cannot find the hardware device. (Code 41)
Recommended resolution
A driver was loaded but Windows cannot find the device. This error occurs when Windows does not detect a non-Plug and Play device.
If the device was removed, uninstall the driver, install the device, and then click Scan for hardware changes to reinstall the driver. If the hardware was not removed, obtain a new or updated driver for the device.
If the device is a non-Plug and Play device, a newer version of the driver might be needed. To install non-Plug and Play devices, use the Add Hardware wizard. Click Performance and Maintenance on Control Panel, click System, and on the Hardware tab, click Add Hardware Wizard.
Let me know how this works.
-Tha Mp3 Doctor
Posted on Jun 18, 2008
SOURCE:
MY tsst cORP cdw/dvd ts-h492a QUIT reading cd's. Got erroe code 41. Need help!!!!! Unable to locate Driver.
Code 41 = Windows successfully loaded the device driver for this hardware but cannot find the hardware device.
Your optical unit has died, replace it.
Jul 14, 2010 | Compaq Computers & Internet
Sony Walkman NWZX1060B X - hardware device not found
Just open Device manager and click the walkman device that has the code 41 then uninstall the driver. . . then reconnect the walkman it will install back and able to access again . I tried it once and it works
Nov 09, 2009 | Sony Audio Players & Recorders
My CDR/DVD doesn't work. I have a yellow ! over the hardware device. Using the Windows Add Hardware Wizard it shows that Windows has successfully loaded the device driver for the hardware but can not...
Hello, if looked this error code from Microsoft self, just have a lokk and see if you have tried all of these.
This problem occurs if you install a driver for a non-Plug and Play device, but Windows cannot find the device. Here are some things that you can try to resolve this problem.
If the Troubleshooting Wizard does not resolve the problem, do one of the following:
  • If the device was removed, uninstall the driver, connect the device, and then click Scan for hardware changes to reinstall the driver.
  • If the hardware was not removed, the driver files might be obsolete. In this case, update the driver from Device Manager. In the device Properties dialog box, click the Driver tab, and then click Update Driver to start the Hardware Update Wizard. Follow the instructions to update the driver.
  • If the device is a non-Plug and Play device, you may have to install a newer version of the driver. To install non-Plug and Play devices, use the Add Hardware wizard. Click Start, and then click Run. In the Open box, type hdwwiz.cpl.
If that doesn't work, i tried this program once at a frined of mine with the same problem as you have now and it worked perfectly.
Link below:
http://microsoft.pcerror.info/errorcode/code%2041.html?gclid=CMKowK-575wCFdYB4wodDjz1kg
Really hope hat this can help you.
Sep 13, 2009 | Dell OptiPlex GX520 PC Desktop
I have a dvd writer model LG GSA-E60L an when i install windows xp tells me that it is not digtally signed and also it comes up with error41 cant find hardware wont let me install and also i cant find my...
Code 41
On the General Properties tab of the device, click Troubleshoot to start the Troubleshooting Wizard.
Jul 08, 2008 | Computers & Internet
Laptop wont recognise dvd drive
Here is the explanation and solution for the error code 41:
Code 41
Windows successfully loaded the device driver for this hardware but cannot find the hardware device. (Code 41) Recommended resolution
Good luck.
Apr 07, 2008 | Computers & Internet
Redgroove digital mp3 player voice recorder
PC does not recognize player - sure you used the right driver?
Code 41Windows successfully loaded the device driver for this hardware but cannot find the hardware device. (Code 41)Recommended resolution
Feb 12, 2008 | iRiver iFP-895 MP3 Player
It won't connect
Seems like the Operating System (is it Windows XP) may have encountered errors loading the native drivers for your player when in MTP mode, or the Windows Media Player version on the PC your plugging your player in is Windows 9 or below. The minimum requirements of the E250 is Windows XP Service Pack 2 and Windows Media Player 10 or above. Falling short of this minimum requirement may cause your player not to be properly recognized. But assuming that the PC you're using the player with meets all the requirements, try to re-load the native driver by plugging your player to the PC and doing the following: Step 1: Right-click on the "My Computer" icon, then select "Manage". This will open the "Computer Management" window. Step 2: Left-click on "Device Manager" Your player comes in two modes -- MTP and MSC -- and is how Windows XP recognizes your player depends on which mode it is set in. To access the modes on your E250, use the menu and navigate as follows: Menu >> Settings >> USB Mode If your player is currently in MTP mode, then try this: (1) Left-click in "Windows Portable Device". You should find your E250 indicated there. Check for an error indicator on the left side of that icon. The error indicator would be yellow-colored icons displayed as "!" or "?" (2): Right-click on the E250 and select "Scan for hardware changes" or "uninstall". Both would have the same effect If your player is currently in MSC mode, then try this: (1): Left-click in "Universal Serial Bus Controller". You should find a "Mass Storage Device" there (make sure that the E250 is the only device plugged in to your PC at this time). Check for an error indicator on the left side of that icon. The error indicator would be yellow-colored icons displayed as "!" or "?" (2): Right-click on the "Mass Storage" and select "Scan for hardware changes" or "uninstall". Both would have the same effect Step 3: Unplug your E250 and plug it back in. This would force Windows to re-load the driver. 90-99% of the time, it would re-load the native drivers correctly. I hope this works.
Apr 13, 2007 | SanDisk Sansa e250 MP3 Player
Synching problems....someone please help
Hi Nikki. Seems like the Operating System (is it Windows XP?) may have encountered errors loading the native drivers for your player when in MTP mode, or the Windows Media Player version on the PC your plugging your player in is Windows 9 or below. The minimum requirements of the M240 is Windows XP Service Pack 2 and Windows Media Player 10 or above. Falling short of this minimum requirement may cause your player not to be properly recognized. But assuming that the PC you're using the player with meets all the requirements, try to re-load the native driver by plugging your player to the PC and doing the following: Step 1: Right-click on the "My Computer" icon, then select "Manage". This will open the "Computer Management" window. Step 2: Left-click on "Device Manager" If your player is currently in MTP mode, then try this: (1) Left-click in "Windows Portable Device". You should find your M240 indicated there. Check for an error indicator on the left side of that icon. The error indicator would be yellow-colored icons displayed as "!" or "?" (2): Right-click on the M240 and select "Scan for hardware changes" or "uninstall". Both would have the same effect If your player is currently in MSC mode, then try this: (1): Left-click in "Universal Serial Bus Controller". You should find a "Mass Storage Device" there (make sure that the M240 is the only device plugged in to your PC at this time). Check for an error indicator on the left side of that icon. The error indicator would be yellow-colored icons displayed as "!" or "?" (2): Right-click on the "Mass Storage" and select "Scan for hardware changes" or "uninstall". Both would have the same effect Step 3: Unplug your M240 and plug it back in. This would force Windows to re-load the driver. 90-99% of the time, it would re-load the native drivers correctly. I hope this works.
Mar 05, 2007 | SanDisk Sansa m240 MP3 Player
Insignia Pilot MP3 Player Logo
143 people viewed this question
Top Insignia Audio Players & Recorders Experts
Alan Matzke
Alan Matzke
Steve Allison
Steve Allison
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
