Question about Samsung Washing Machines
Purchased Washing Machine from E-Zone, Kalyan vide Advance Receipt No. 2092000577 dated 03-Nov-2010 (model-WA82V4GEC). When I checked up with Customer Care Centre I was told that there is TATA PHOTON offer on the purchase of this Washing Machine (BP No. 8418058615). I approached the dealer with the paper advt. They instructed me to collect the same from Tata Indicon Gallery by paying Rs. 999/-. I am totally confused. Please confirm is this correct procedure. Also reconfirm that the offer is applicable for this model - WA82V4GEC. VK Rajendran (9969311382)
jsrock516
  • 5911 Answers
SOURCE: washing machine broken, kenmore model 110.92274100
If the washer does not spin ONLY when it gets to the spin cycle, you may have a broken lid switch. Here' how you can determine if the switch is working properly or not. Open and close the washer lid and listen for a "clicking" sound as the lid opens and closes. If no click is heard, chances are your lid switch has come loose, the lid strike (small plastic piece on the lid that depresses the lid switch contacts when the lid closes), or your lid switch is broken all together. If you make the determination that you need to replace the switch, follow these steps:
First of all, unplug your washer. you'll need to remove the console in order to get to the lid switch. the washer may have release tabs under the console at each front corner. Simply slide a putty knife straight in from the front at each corner and push in while lifting up. You should feel the release tabs push in and the console will pop up. If not equipped with this type of console, you may have a console that has removable end caps. They can be removed by gently prying up on the top of them from the rear on each side. You may have to use a small screwdriver for this. The caps should pop right off. Once removed, you will need to loosen a screw under each cap. And, still there are some of the older models that have screws holding the console in place from the back. Once you have the console loosened, carefully lift it up and lay it back over the rear panel of the washer in its resting position. Be careful not to damage the small plastic hinges that hold it in place. Now you will need to perform the following steps:
1. Under the console you will find the lid switch connector. Unplug the switch from the connector.
2. There will be two brass colored clips. you will need to remove these to remove the machine casing. Place a flat blade screwdriver straight down into the opening on top of the washer and into the groove of the clip. Push the screwdriver away from you while holding into the groove and the clip will release.
3. Open the lid of the washer and place your hand under the front rim of the opening (DO NOT grab the wash tub). Now pull the case from the frame by lifting from the back first.
You do not have to remove it all the way from the frame, just enough to gain access to the switch. All there is to the switch is a couple of screws holding it in on the side of the tub opening and a ground wire attached to the casing. Remove the connector plug, by pushing in on the release tabs on either side and pushing it down through the opening in the washer casing. The wire harness will be held in place by clips under the washer rim. It's a pretty easy repair job. Some models will have the switch located on the right-hand side of the lid rim opening, while other models will have the switch located on the left-hand side near the lid hinge.
Once you've completed your switch installation, make sure you get the case back on the frame correctly by following these steps:
1. While looking down through the lid opening, place the front lip of the machine case UNDER the washer frame and start leaning it back onto the frame. There are four small cleats that must fit into four slots on the case or the washer will vibrate. Make sure the frame is seated properly, lean forward from the front of the washer, grasp both sides of the rear panel and pull towards the case. The rear panel should be seated and flush with the casing before inserting the retaining clips.
2. Insert the brass-colored clips into the slot on the washer rear panel first, and then push straight down into the opening on the top of the washer with some force. If you have the case seated correctly, the clips will snap back in.
3. Make sure you plug the connector from the console back into the lid switch receptacle BEFORE you reassemble the console. This is easy to forget.
Now...the oil leaking from the gear case may be an unrelated problem. The gear case IS filled with a honey colored oil. Sometimes they leak. This does not always indicate a problem unless the problem gets progressively worse, or you notice slow spin or no spin related problems. If the amount of oil is a small amount it may not be anything to worry about. However, if you are noticing large puddles, you may need to think about replacing the gear case.
I only mentioned the lid switch first, because this is a simple problem that can often be overlooked, AND appear to be a more significant problem. BOTH components, if bad, can exhibit very similar symptoms. If you check the lid switch and it is working properly, you could very well have a gear case going bad. If you need to replace it, I would recommend replacing the motor coupling as well. Here's a list of part numbers:
Gear case - 3360629R $73.88
Motor Coupling - 285753A $15.49
The parts can be found at searpartsdirect.com under the heading "BRAKE, CLUTCH, GEARCASE, MOTOR AND PUMP". You can also find these parts at repairclinic.com. The gear case on the Sears website is a rebuilt one. The gear case at repair clinic is a new one and costs a bit more. Just type in your model number in the search menu and a part index will be available.
If you make the determination that the gear case is bad, I can give you follow-up instructions on how to replace it. It is a simple repair that you can do with a little guidance. You can also save a bunch in added labor costs.
Good Luck and let me know if you have any further questions.
PS Additional part numbers (if needed):
Lid Switch - 285671 $29.99
Lid Strike - 350733 $10.48
These parts are available also at the Sears website under the heading "TOP AND CABINET".
Posted on Mar 01, 2008
SOURCE: LG Washing Machine All-in-One
Some magic happened today!
I got the thing (wd-12331ad) to dry without having to run a wash first!
Also, I seemed to get it to do a spin only run...
The way to get it to dry :
(for a set time - I've not managed to get any of the auto-dry settings to work)
from machine being off:
> press the power button.
> press the "Dry" button 'til "Time" lights up
>>> press "Dry" again to get the desired duration
> press the spin button 'til the spin speed shows blank/ the RPM light goes out.
> press "Start/Pause"
It will then dry for the number of minutes specified!
Not perfect, I know but that's serious progress from where I was before; having to re-run a wash cycle to get it to dry anything...
Something to note:
- The machine worryingly sounds like it's starting to fill with water when you start the "Just Dry" program which scared me at first. BUT it stops after a second or so (I think it's just cleaning out the detergent tray so it doesn't bake any leftover powder)
For "spin only" from machine being off:
>>> if you press "Start/Pause" now you get a 13 minute 1200 spin cycle
>>> press the spin button again and then "Start/Pause", it seems to drain itself for 1 minute
>>> pressing spin repeatedly, cycles through the spin speeds.
Things I don't know:
- I don't know if you can combine spin and heat.
- I don't know whether the auto-dry programs are available
- I don't know what other programs are available from the "Dry"/"Spin" buttons
...So if anyone does any experimenting, please let us know the results, you never know, we might end up with a half way useful set of instructions! I'm starting to think the machine's not half as bad as it seems when following the manual alone.
Hope that helps.
Will
Posted on Jul 12, 2008
appldoctom
  • 311 Answers
SOURCE: Whirlpool Washing Machine, Product- F65, model7234,water overflow
top loader?usually its because your water valve is not closing because minerals have gotten into the water valve.but water would come into washer even when unpluged.another thing can be if when over flowing and u unplug it and it stops fillig/over flowing.your presure switch hose will have come off the water level switch or a mouse chewed a hole in it.its a clear tube thats running from your water level switch.i hope that helps god bless,tom
Posted on Jan 01, 2009
ajinkyapai
  • 126 Answers
SOURCE: Tata Photon offer for aspire one netbook
go to http://www.tataphoton.com/
or call on 9225000121
Posted on Jun 15, 2010
SOURCE: KleenMaid Washing Machine shop manuals/repair instructions
There are manuals available but these only tell you about the parts of the machine and the different cycles etc. Its a workshop manual that you need and these are not discussed anywhere on the net, Im not sure these were ever produced.
Posted on Sep 12, 2010
Win 1894, s/n 857903, in 32-40. How common is this?
in 32-40 fairly unusual it would appear. Lots of information for you here.
What year was my Winchester manufactured Serial Number Reference
www.winchesterguns.com/support/faq/date-your-firearm.html
  1. Cached
  2. Similar
Winchester Firearms Manufacturing Dates by Serial Number and Year ... totally accurate database of serial numbers from 1866 forward that we are aware of.
[PDF]Winchester Firearms Manufacturing Dates by Serial Number
www.winchesterguns.com/.../winchester.../serial-number.../Winchester-Manufacture-...
  1. Cached
totally accurate database of serial numbers from 1866 forward that we are aware of. ... 94 -. 95 -. 96 -. 97 -. 98 -. 99 -. MODEL 1866. 2. 12476 TO 14813. 15578 .... 32-. 1087836. 62-. 2551921. 03·. 291506. 33 -. 1089270. 63 -. 2586000. 04 - ... 40 -. 1142423. 70-. 3381299. 11-. 599263. 41 -. 1191307. 71-. 3557385. 12 -.
Winchester Model 94 - Gun Collections Online
guncollectionsonline.com/winchestermodel94.htm
  1. Cached
  2. Similar
Winchester Model 94, Winchester model 1894, 30-30 caliber, lever action ... The post-64 Winchester model 94 begin with serial number 2,700,000. ... .38-40 Winchester, and .44-40 Winchester, .410 shotgun, 30-30 caliber (30 WCF), ... began with Serial Number 1 and the Winchester Model 94 Serial Numbers run more or ...
Model 1894 (Mod 94) - Winchester Dates of Manufacture
oldguns.net/sn_php/windateslookup.php?file=win1894.dat
  1. Cached
  2. Similar
Winchester Model 1894 (Mod 94): Covering numbers: 1 - 5103249. Please enter a serial number and click the submit button.
Serial Number info for Winchester Model 94 - The Firing Line Forums
https://thefiringline.com/forums/showthread.php?t=322230
  1. Cached
  2. Similar
Nov 27, 2008 - 25 posts - ‎17 authors Is there a place on line to research and find dates and serial numbers on The Winchester Model 94 30 30 ? ccookin is offline ... Winchester 94 32-40 21 posts 13 Mar 2013 Original winchester model 1892?? 10 posts 19 Jul 2010 Winchester 30-30-model 94 Pre or Post 1964? 25 posts 12 Nov 2004 More results from thefiringline.com
Winchester 1894 date of manufacture. - Shooters Forum
https://www.shootersforum.com/winchester-94.../66444-winchester-1894-date-manuf...
  1. Cached
  2. Similar
Jun 22, 2010 - 5 posts It seems that date of manufacture numbers are probably off as much as two years in this time frame. .... Winchester's production of the Model 94 averaged about 35,000 units per .... 32-40 Rifle - serial number 692, 12-14-1894
Blue Book of Gun Values - WINCHESTER RIFLES: LEVER ACTIONS ...
bluebookofgunvalues.com > Gun Values > WINCHESTER
  1. Cached
  2. Similar
WINCHESTER RIFLES: LEVER ACTIONS - 1860-1964 gun model and pricing information. ... lever latch, adj. sporting type rear leaf sight, serial numbers are in three digits only. ... .32-20 WCF, .38-40 WCF, or .44-40 WCF cal., iron frame with sideplates, .... 1940-1964 mfg. without saddle ring, barrel is marked Model 94.
Model 1894 ' Winchester Collector
winchestercollector.org/models/model-1894/
  1. Cached
  2. Similar
.32-40 - introduced in 1894 ... As serial numbers approached the one-million mark, the official model ... The Winchester Model 1894 Saddle Ring Carbine
Win 1894 857903 in 32 40 Google Search
Nov 15, 2016 | Computers & Internet
Engine wont accelerate past 2500 rpm
03 Saturn Vue RPM doesn't go past 3,000 RPM Normal or Abnormal ...
www.saturnfans.com > ... > Models > Saturn Vue > Vue Tech
Apr 9, 2010 - 8 posts - ‎5 authors 03 Saturn Vue RPM doesn't go past 3000 RPM Normal or Abnormal? ... If the engine won't rev over 3K in Park, there's your answer - its engine ... 99 SL1 Won't accelerate
Nov 25, 2013
03 3.0L P0421 & 431, plus pending 300, 301, 303
Nov 10, 2013
Sudden loss of power and shaking at low RPMs
Aug 4, 2010
2002 3.0 AWD...SES Light and won't accelerate
Mar 10, 2009
More results from www.saturnfans.com
Nov 07, 2015 | Saturn 2003 VUE 4 CYL
I purchased a sanyo flat screen t.v in sept 2010 from wal=mart in nov it stopped working. lost all paperwork receipt warranty ect..ect.it wont power on and it was manufactured in july 2010. I dont have...
If I were you, armed with the fact that the machine was made in July 2010. It is , by default, within warranty.
Contact Sanyo, not a shop or service centre, Sanyo can authorise a repair/replacement of this machine.
Most unfortunate and I am sorry to hear about it but Sanyo will fix it for you.
Mar 23, 2011 | Sanyo Televison & Video
Hi, I have applied for the post of ATC Manager on Aug03'2010. I want to know the exam date of the same. Please let me know.
dear friend,
Details as follows:
Last date for receipt of application : 16.08.2010
Last date for receipt of payment through Credit/Debit Card : 16.08.2010
Last date for receipt of payment through DD/PO : 12.08.2010
Date of exam:1st week September
Good Luck!
Read more here: http://entrance-exam.net/forum/general-discussion/aai-2010-jr-ex-atc-exam-date-34044.html#ixzz1BGZTRNCv
hope this will do
enjoy & cheers
Jan 17, 2011 | Computers & Internet
I MISS MY KERALA PSC BARCODE.THEN WHAT I DO ?
sir, i forgot my register number . I have barcode with me. but exam result in register number. how can i get register number from my barcode number
May 28, 2010 | PSC Magellan SL
FI Code on Sears Oasis Washer
Called the recall dept. for Sears. Have an appointment set up for two weeks.Gave them my serial number and model number. The said if the parts show up prior to the two week time frame...call them and we could re-schedule the appointment.
Aug 15, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Getting Eastern Time Zone to register Model X3-03
Set your home in the time zone you want. see if this works.
Jan 15, 2009 | Nextar X3-03 Car GPS Receiver
Washing Machines Logo
123 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
