Question about Whirlpool Washing Machines
Can a brand new top load whirlpool washer model wtw1500vq2 overflow or does ithave automatic shut off?
  • 25 Answers
DEPEND WERE IS THE OVERFLOW IF ITS ON THE DRAIN HOSE ATTACHED ON THE WALL U MAY CHECK THE DRAIN PIPE CAN BE CLOGGED. ANOTHER THING ITS THE WASHER HAVE A WATER LEVER PRESSURE SWITCH PROBABLY BE DAMAGE.
Posted on Nov 11, 2010
Whirlpool Cabrio top load washer bleach and detergent will overflow.
Change the bleach dispenser.
Also make sure the tubes are not slightly clogged from residue build up of mildew.
Dec 01, 2014 | Whirlpool Washing Machines
New whirlpool wtw6500ww cabrio washer has overflowed with water every load I ran today. What am I doing wrong? It ran over with every size load.
There is a clear hose that goes from the tub to the pressure sensor on the control board. It tells the washer when to shut off the water. It is probably either punctured or disconnected, or the pressure switch needs to be replaced. If it's new its probably still under warranty and you should have whirlpool fix it.
Jan 30, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
My washer overflows. it wont stop putting water
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (110.########) and you'll see a list of major sub-components with diagrams and parts.
(The 110 means that it was manufactured by Whirlpool, you also need to enter the 8 digit model number)
Also see the Whirlpool / Kenmore Service Manual for these washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It has testing procedures as well as a good description of how the washer works.
It sounds like a defective water level switch or water inlet valve.
See the following for how to release the console and cabinet on these machines in order to get to the switch for testing.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131
Basically, what happens is:
When the washer is turned on, the water inlet switch is closed allowing water to flow thru the inlet valve. When it senses that the machine is to the level selected by the water level dial, the switch opens shutting the inlet valves.
If the switch or valve is defective, water will continue to enter the machine.
The Whirlpool Service Manual has testing procedures (basis continuity tests with a multimeter) for both the switch and valve.
May 10, 2010 | Kenmore 24032\24036 Top Load Washer
Fills up with water and wont stop
if it still fills , with power off, the valve is letting by water and has become faulty,if water stops with power off,check for smudged powder at the lower part of the pressure switch pipe giving a false read to pressure switch,other than that the pressure switch has become faulty,look at the pressure switch pipe first for blockage,hope this helps
May 07, 2009 | Whirlpool WTW5200S Top Load Washer
Bad Preasure valve comes to mind first and formost it acts like a level sensor balanceing the size indicated for fill.
Feb 10, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Water flow into washer will not shut off
It could be the valve or the fill sensor. You can Google the washing macine brand and it will give you a diagram of what parts the washing macine has and does Also try RepairClinic.com. .
Jan 19, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
48 people viewed this question
Dan Webster
Dan Webster
Sal De
