Question about Philips 32PF5320 32 in. HD-Ready LCD Television
Have a phillips tv, model 32PF5320/28 turned it over face down to plug a HDMI cable. there was something under the screen that i did not think about moving. now a 4th of the screen is white and there are lines on it. What are my options?
  • Philips Master
  • 1,229 Answers
You have damaged the screen and there is no cheap repair. Replacing this screen is just as costly as buying a new TV. Sorry this happened. The screens are fragile and very expensive. Thanks for asking and show a few hands of support.
Posted on Nov 11, 2010
I have a Toshiba tv that is connected to Direct tv and I want to know how to connect my new Phillips dvd player to it my tv?
Flat screens normally have 3 different inputs from tv. Regular is tv coax cable, then audio/picture by using special rca cables, then last HDMI. You can use any of those inputs except hdmi because you already are using that input. You may be able to buy a hdmi splitting device that will allow both the tv and the player to input to the single hdmi input. Check Radio Shack or Wal-Mart.
May 12, 2014 | Toshiba HD-A30 HD-DVD Player
How to connect dish tv to my laptop? It has inbuilt tv tuner.
Your Lenovo laptop can be hooked up your TV if you have a model that is capable of TV output. Newer models with HDMI ports can easily connect to newer TVs that have HDMI input jacks. For older laptops or TVs, you will need other adapters or cables. The most common of these is an S-video jack, which has a small round connector with several pins arranged in a circle. For S-video connections, you will need to hook up the audio from your laptop to your TV separately.
Things You'll Need
HDMI cable
USB-to-HDMI adapter
OR
S-video cable
Audio cables
HDMI Connection
Turn on your Lenovo laptop and HDMI-enabled TV.
Connect one end of your HDMI cable to the HDMI port on your laptop. Lenovo's IdeaPad series has these ports. If you have a ThinkPad or other Lenovo model, connect a USB-to-HDMI adapter to your HDMI cable, then plug the USB end of the adapter into any USB port.
Press the "FN" and "F7" keys on your keyboard. This will switch the laptop's display to the TV. You can then use your TV screen as a monitor or use the laptop's DVD drive to watch movies on your TV.
S-Video Connection
Turn off your laptop and TV. Connect your S-video cable to the laptop on one end and the TV on the other.
Plug audio cables into your audio out jacks on the laptop. If you do not have stereo audio output, you can use the headphone/speaker jack. Add a splitter adapter to split the sound into stereo instead of mono (single speaker). Plug the other ends of the audio cables into your TV.
Turn on the laptop and let it boot up. Then turn on the TV. Right-click on your desktop screen, then select "Properties."
Click the "Settings" tab, the "Advanced" button, then "ATI displays" or "Display device" or the similarly worded option, depending on your system. It is not the "On screen displays" option in any version.
Click on the option that suits your system, such as "TV" or "LCD." Click "Apply," then "Yes" to confirm, if necessary. Click "OK" to exit. Your display should be visible on the TV screen. If not, try pressing "FN" and "F7" to toggle the display to the external screen.
Sep 13, 2011 | Lenovo IdeaPad Y560 Laptop
Hi guys I have a Phillips Plasma TV 42PF5521D/10 model UK version bought in 2008 Guess what untill now i only used the HDMI ports to connect a Home Media Center PC to watch HD content. So last...
hi First, remember the old HDMI reset tech tip. Unplug all HDMI cables (one end will do.) Then remove power from all things in play. No, not just turned off but remove the AC. Wait 5 to 10 minutes, hookup re -test thanks
shaun .
Mar 09, 2017 | Philips 42PF5521D 42 in. HD-Ready Plasma...
No picture thru hdmi but picture thru RCA plugs
I had this exact same problem, or rather my friend did after I borrowed his PS3. You see when I borrowed it, the console configured the HD output to work with my TV, If this happened to you, there is a fix, With the HD cable connected, turn off the power to your PS3 and then turn it back on again. But when you turn it on, hold down the power button until you see something on the screen. When you hold down the power button of the PS3 when you are turning it on, it completely resets the video settings to the most basic settings (480p I think) so that it'll work on any TV or monitor. Once you can then get something on the screen, you can configure the video settings to match the TV you are hooking up to.
Jun 04, 2010 | Sony Playstation 3 (PS3) Console
On my television screen when plugged in with a hdmi cable it says on the screen out of range what should i do? thank you
Most likely the video setting are incorrect for your TV
Turn off the power to your PS3 and then turn it back on again. But when you turn it on, hold down the power button until you see something on the screen.
(When you hold down the power button of the PS3 when you are turning it on, it completely resets the video settings to the most basic settings (480p I think) so that it'll work on any TV or monitor.)
Apr 20, 2010 | Sony Playstation 3 (PS3) Console
How do i get on the HDMI input channel?
Hello Jeff. I just have a basic question for you. Was the Blu Ray player turned on when you first plugged it into the tv? TV's are becoming so complicated that they are becoming less user friendly. Try setting your tv to the first HDMI input using your tv remote's input button. Then unplug the HDMI cable from the tv, make sure the player is turned on then plug the HDMI cable into the left most input if horizontal or top input if vertical. Hopefully if you do that and have the input selected, it should work for you.
Also: Whi9le attaching the cable, I find it helpful to have it in a position where I can see the tv, because when a device hooks up the screen usually flashes or turns blue or something similar.
Hope this helped
-Chris
May 01, 2009 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
TV will not turn on unless unplugged and wait one hour then plug
Well, sounds like they may be changing the source from T.V. to HDMI or component/composit mode which is bassically for a C player or other connected source like a VHS or Xbox etc.
Allthough if this where the case, you should be able to use the remote to change the source back to the T.V. Antenna or cable if you have it.
WHen it goes blank or seems to be off, does anything you do turn it back on without having to unplugg it first?
If not, it could be bad, you will need to try hooking it up some where else for a while and test it without that person there and see if it the T.V. a bad outlet or the person is actually doing something.
If you think the T.V. is bad or faulty, at this early in its life, I would take it back under warranty before trying to fix it yourself.
Feb 11, 2009 | Philips TV Tuner Video Capture PCI Card -...
Connect TV to dvd player
hdmi, S-video or jack are the most common cables delivered with the dvd, you can plug an amplifier between tv and dvd for a dolby system.
Turn on the DVD player, the TV and Set your TV on "AUX" or "Ext" with the remote.
Dec 23, 2008 | Philips TV Tuner Video Capture PCI Card -...
Philips 32PF5320 32 in. HD-Ready LCD Television Logo
252 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
