Question about Canon PIXMA MP130 All-In-One InkJet Printer
Error 5100 keeps popping up when im trying to print. How do i fix it?
  • Canon Master
  • 4,338 Answers
Try opening the scanner part as if you were changing the ink cartridges. To the left of center, about 1/3 of the way toward the back is a switch activated by a small plastic piece hanging from the bottom of the scanner. Push down on the switch (it was very easy to activate it on mine), then try doing a copy. That made a successful copy for me, then I closed it up and it seems to be working (after I changed the low ink cartridges it was even readable). Hope this helps.
Try the following if the switch activation fails to fix it:
• Use the Nvram access trick:
Press Menu, then Scan, Copy, Scan toenter Service Mode
Press the + button until you arrive atNVRAM ACCESS, press OK
Use the + or - buttons to reach ABS-MLEVEL, press OK
Set the level on zero and press OK
Use +/- to reach ABS-P, press OK
Set this level to zero and press OK
Press STOP to exit the menu
Switch off and restart the printer.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Nov 11, 2010
Canon pixma mg2120 error 5100
I just bought this Canon PIXMA MG2120 PRINTER about 2 weeksago, I've been able to print untillast night, it's giving me error message 5100, what do I do to fix this?
Jul 15, 2012 | Canon Office Equipment & Supplies
When asking to print the response im getting is
Check whether something got struck inside the roller,Remove the catridge and fix it again.
Hope this helps
Siju.D
Nov 05, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Last week i tried to print but it didn't work and appeared 5100 error. i have the pixma mp 170 printer... i don't know how i can fix it
Hello
The manual states that the error code 5100 is a result of:
Service error 5100 is displayed
Cause: Movement of the FINE Cartridge Holder is blocked.
Action: Clear the paper jam or foreign object that is preventing the FINE Cartridge Holder from moving, cancel printing from your computer, then turn OFF the machine and turn it back ON again.
You might see something blocking the printer head, check inside to see if there is a paper jam, staple, or some other object blocking the print head.
If this does not work, try resetting the device:
  1. Turn the printer off.
  2. Hold the button Resume / Cancel (red triangle in the circle), click POWER - indicator lights green.
  3. Release the button Resume / Cancel, keeping POWER.
  4. Click Resume / Cancel 2 times, keeping POWER, and then release all the buttons.
  5. When the indicator light Green - click Resume / Cancel 4 times!
  6. Turn the printer off button POWER.
Hope this can help you.
Best regards
Andrea
Oct 20, 2009 | Office Equipment & Supplies
My Pixma ip1980 service error 5100
5100 is a Carriage Home Position Error.
try cleaning the plastic strip that runs the length of the carriage, it may be contaminated.
Use alcohol and a swab.
Aug 12, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
ERROR 5100
you have a carriage error thats what the error code refers to.
can depends on a lot things but usally not worth fixing if its done lots of prints
canon tech
Apr 09, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Error 5100
Use the link below to fix the error
http://www.fixyourownprinter.com/forums/laser/25975
2nd solution :
o to the canon website (listed below) - under Tech Support - click on Technical FAQ's (this will pop up another small window)
then click on Search by Key Word
next - type in error 5100 and click on the circle next to - Include all words and hit Search
next - click on the link with your answer "how to.... "
this should show the answer
http://www.usa.canon.com/consumer/controller?act=SupportDetailAct&fcategoryid=238&modelid=11865
Oct 20, 2008 | Canon PIXMA iP1600 Printer
SERVICE ERROR 5100
please suggest me service error 5100, when i start to print it appear service error 5100. what happen ?
Jul 05, 2008 | Canon PIXMA iP1600 Printer
CANON PIXMA IP1200 resetting
My converted iP1200 is currently blinking green, yellow, green, yellow on the power lights after start up and print request. The pop-up prompt suggests turning off the printer and turning it back on. Error 5100 is always seen.
Please Help Me...
rakibfuture
Mar 30, 2008 | Epson Stylus Multifunction Inkjet Printer/...
Error 5100
Maybe you haven't put your ink carterages in properly, I had the same problem and fixing their position solved it
Oct 08, 2007 | Canon Pixma iP6000D InkJet Photo Printer
Canon PIXMA MP130 All-In-One InkJet Printer Logo
old marine
old marine
