I had problem with my HP laptop as i start power it gives light signal but nothing get display on the screen. i try to fix problem but i could not do it as nothing display by screen and don't know which system have a problem. so, i would like to get the solution for the above mention problem
  • 29 Answers
Remove battery and power plug hold power in for 50 seconds the leave battery out hook backup power lead and try turn on. My tech team and I can help lots with PC stuff it would begreat if you could ask any PC questions you have here so we can discuss itproperly http://www.mypcmates.com
Posted on Nov 11, 2010
No vidio display screen show nothing att all. The computer starts but I see nothing.
If you shine a flashlight at the screen and look it from an angle and can see your displayed screen faintly then the inverter board is bad and it needs to be replaced.
You can hook up an external monitor to your laptop in the meantime to use your system.
There is also the posibility your screen is no good. I'm thinking it will be the inverter board though.
Oct 17, 2010 | HP 530 Notebook PC
No screen on starting laptop
remove the battery from bottom, plug into ac power pack, and try it that way
Jun 01, 2008 | HP Compaq Presario V2000 Notebook
Monitor flickers and faint bands scroll down the
could be fixed by ajdusting the refresh rate....
you could try this (xp pro sp2)
please rate if useful, good luck
Open Display in Control Panel.
On the Settings tab, click Advanced.
On the Monitor tab, in the Refresh Frequency list, click a new refresh rate.
To open Display, click Start, click Control Panel, click Appearance and Themes, and then click Display.
  • The default refresh frequency setting is 100 Hertz, although your monitor may support a higher setting. Check your manufacturer's documentation for information regarding the settings your monitor supports.
  • A higher refresh frequency reduces any flicker on your screen, but choosing a setting that is too high for your monitor can make your display unusable and cause damage to your hardware.
  • Changes to the refresh frequency affect all users that log on to the computer.
Oct 27, 2009 | HP w1907 LCD Monitor
HP (dv2000) laptop will not boot up at all
It appears to be a video card/mainboard problem very common with the symptoms you have described. Try to connect the laptop to an external monitor (see the associated buttons too). No video signal on the external monitor could indicate a damaged video card/mainboard. Not worth it to be repaired and the replacement is expansive. Check the price on a professional repair store. There are new laptops on the market more powerful than yours for about 500-600$. So you can make a choice. Less common, could be a memory problem.Try the laptop with a good previously checked memory (or if there are 2 bars in your laptop, try them one by one). If you do not get any video signal on the external monitor have the laptop, first diagnostic is most probable.
In both cases, if you get a video signal on the external monitor it means your screen is defective (also expensive to be replaced).
Oct 04, 2009 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Power on but no display internal or external
REMOVE THE RAMs FROM UR LAPTOP. IF THEY ARE TWO IN QUANTITY THEN PLUG IN ONE RAM AND CHEK DISPLAY,
Sep 12, 2009 | HP Pavilion dv9000z Notebook
Screen black computer laptop not starting ,hp pavillion entertainment pc,power lights on but screen black screen black computer laptop not starting ,hp pavillion entertainment pc,power lights on but screen...
hi,
if nothing(even hp logo ) is not coming on the display then please try this.
1.remove the battery and then press the power button for 30 sec.Again refix it and check.
2.If windows sound is there then this mught be the issue with display.
3.If there is no windows sound might be the issue with RAM so please get it checked.
May 29, 2009 | Microsoft HP Pavilion DV6276US Notebook PC
Hp dv9000 will not start up. blue lights are go
you get a black screen right, nothing at all then no bios, no logo, nothing at all?
Do you get any beep codes and if so in what order?
did you try different ram?
First try to plug your laptop to an external monitor. If it works, you screen is bad, if it doesn't you probably need a new motherboard.
Dec 23, 2008 | HP Pavilion dv9000z Notebook
Black screen on start up hp dv6600
have you check the display on external monitor, check it by connecting to vga port of your laptop,
if there is a display then its the problem of your laptop screen
Oct 14, 2008 | HP Compaq Presario V6000T Notebook
Power button has light turning on and off with no other signals !!
try,,holding the delete key down as it is starting up,,,will the computer boot into Bios?
do you see any information on the screen when you start the computer at all?
Aug 19, 2008 | HP Compaq Presario C500t Notebook
No Display
First make sure everything else is getting power and operating okay, and that it is only the LCD display that is non-functional.
If you get no video signal or power at all, even at boot time, you probably have a dislodged ribbon cabling or power connection. Usually when LCD monitors go bad they show colour banding or all white, etc., but usually continue getting power.
As a last resort, try disassembling the lower case (with the power disconnected and the battery out of course) to expose the LCD monitor mounts, and then following the wiring from the screen into the laptop and check for anything loose or disconnected. You could also have a loose ribbon cable going into the LCD array, which will require disassembling the LCD cowling and mounts.
If you are handy and comfortable with electrics and find nothing loose, put the battery in and test the power line going to the LCD backlight, which should be getting above 7V (I think). Below that and you either have a bad video controller or bad wiring/solder joints somewhere. Otherwise, if the unit has been dropped or had a hard life generally, it could also be the connections between the LCD connector bus on the monitor array and the array itself. As a last resort, try unplugging and reconnecting all ribbon and connector cables, cleaning the exposed brass coloured runners lightly with rubbing acohol or even a pencil eraser.
Good luck...
Oct 16, 2007 | HP Pavilion dv2120us Notebook
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
