On many, but not all, dvds the tv picture has four rows of short white lines, intermittently. The dvds play perfectly on other equipment. Looks something like this: - - - - - - - - - - - - - - - - I have played, without problem, the dvds on the same model dvd (sony) player on a different tv. The problem is possibly with the tv (but the lines do not appear during tv reception and not on playing some dvds). Any ideas?
  • pbreslaw Jun 17, 2008
    The dvds that do not play properly are of varied types
  • 2,318 Answers
There could be some interference getting into the DVD video source when playing the DVDs.
What is the model of TV that gives you those lines?
What type of cables are you using?
Posted on Jun 17, 2008
  • 1,879 Answers
If the issue shows only on the other TV, possible that that TV's input port is faulty
    Guru:
  • 1,894 Answers
Do all those faulty DVDs belong to same category?
  • dewan nafees ahmed Jun 17, 2008
    i mean like all belong to DVD-r or DVD+r or something like that?
    do they give any similarity?
How to repair and locate vertical ic on apex tv
See attached photo of a typical chip--usually one row of pins (single in line package) and has the Generic part number right on the front--with the number on yours you can Google a pin out which will show what pins are voltage in, output etc.
Some are ones with two rows of pins staggered and offset.
Locate it also by looking for it to be attached to a metal plate for cooling--also when replacing it the white heat transfer grease on the back of it must be replaced with fresh grease--the white heat sink kind used in computers and electronic equipment of all kinds.
Not a bad idea if you had foldover on top of picture to look at the filter caps right around the chip--one will be a feedback cap--usually a 220uf or higher (uf is microfarad and the cap will have two pins with one a plus and the other a negative marked on them--if that cap is open the set will have nearly a full picture but have folded over lines at top of screen---if that fails it shortly gets the chip.
This is a typical one and yours will likely differ in the number of pins--7-13 pins is normal.
Apr 05, 2012 | Televison & Video
I have a go video DV2140 that is only a couple months old and suddenly is started playing DVDs in black and white. I've tried different DVDs and they are all black and white now. The TV itself is color...
Bring it back to the place of purchase since the item is under warranty, this is a manufacture defect and you are in your perfect right to have a replacement.
Mar 14, 2012 | Toshiba Televison & Video
White flickering line across top of screen
Set the screen format using your TV's menu. Do not set the format of the screen using your provider's receiver. I had this prob with a few channels with a dish provider when I set the format with the remote from the dish provider. I picked up the TV's remote, went into the menu, set the format, problem fixed.
May 15, 2010 | Vizio GV42L 42 in. LCD Television
Sony rdr vx410 dvd player playing some dvds in black and white
  • DVD's are standard definition video sources. Number of lines output is 576 lines, whereas your HD TV set has 720 or 1080 lines. This difference may result in a poorer image. However some DVD players are able to “upscale” picture to obtain a very good picture. Check if your DVD player has the following connectors: YUV, DVI or HDMI. For more information, refer to the instruction manual of your DVD player.
  • Some HDMI or DVI featured DVD players also have an internal processor that can upscale pictures from a DVD to 720 or 1080 lines to provide an excellent picture from a standard definition disc to your HD TV set. Those settings are available from the setup menu of your DVD player. Please refer to the instruction manual of your DVD player.
  • If your DVD player does not have those connectors and only has a SCART connector, or S-VIDEO, or composite, there is not much to do to improve the picture quality. Just make sure that you are not using the cheapest cables and that the picture settings of your TV set are correctly adjusted.
  • Some high end TV sets have a picture improvement engine that can soften a noisy image. Make sure that it is activated from the setup menu of your TV set. Please refer to the instruction manual of your TV set.
  • If people and objects have weird white outlines around them. This may suggest that your TV sharpness is set too high. Make the correct sharpness adjustments from the setup menu of your TV set.
  • Make sure you use good quality cables and that your cables are not too long (less than 5 meters long).
Jun 15, 2009 | Sony RDR-VX420 DVD Recorder/VCR
Black and White Image
Yes there is video format for our TV and dvd players. NTSC & PAL...
NTSC SYSTEM SELECTED IN TV & DVD PLAYER PLAY PERFECT NTSC CDS & DVDS, BUT IF PAL CD OR DVD IS INSERTED SUCH PROBLEM COMES.
EVEN IF, THE DVD PLAYER SETTING IS KEPT AS PAL, AND WE INSERTING THE CORRECT CD OR DVD AND ALSO IT SHOW BLACK & WHITE PICTURE, ETC.... so please check your video system in TV, DVD PLAYER and check the CD or DVD you are inserting is of same video format you have set in DVD player.
Apr 23, 2009 | Cyberhome CH-DVD 300 DVD Player
DVDs all play in Black & White
Could be because it is set to NTSC. Needs to be set to Pal.
Mar 27, 2009 | Panasonic Televison & Video
Dvd playing blue picture
if it is hooked up with componant, thats the red blue green cables for video, and red white for audio, then you probabily eather dont have the red pluged all the way in, or you have the red audio, and red video---reversed, make sure to check them on the dvd player, and on the tv, if there correct, try using the composit input, that is the yellow red and white
Jan 11, 2009 | Samsung Televison & Video
Burning dvds
It could be either a problem with the burning software maybe you are burning the disks to fast maybe the dvd rewriter is on its last legs. or have you recently changed what dvd disks you use.
Jan 26, 2008 | Computers & Internet
Scrambled Picture/Snow Screen, has sound, can play DVDs through colorstream
I had this with a rca once. Can you hear a crackeling noise coming from the flyback transformer? My problem was just the wire was loose
Sep 27, 2007 | Toshiba TP50H50 50" Rear Projection...
Sound but no picture
A white like across the screen means that the vertical circuit has stopped working. Look for a small fuse that looks like a resistor near the vertical output IC, replace that fuse if open and resolder the pins on the vertical output IC.
Jul 08, 2007 | Toshiba CZ32V51 32" TV
Televison & Video Logo
89 people viewed this question
Top Televison & Video Experts
Electro Med Services...
