Question about Canon PIXMA MX300 All-in-One Printer
The alarm button flashes on my Cannon MX300...then a code in lower left of panel reads 5100. As I do not have a book of directions I am absolutely LOST! please help. Marg
  • leelandscm Nov 11, 2010
    I'm not sure what button to use...is it on the mX300 or are you referring to the computer?
    I have tried the stop/Rest Button
  • 4,281 Answers
For that you need to RESET printer settings to factory defaults. Then that error will be fixed. Press the button repeatedly to display [DEVICE SETTINGS]. Press the left or right arrow to select [RESTORE DEFAULT], then press the button. Press the left or right arrow to select one of the below options and then press . TELEPHONE NO DATA SETTING DATA ALL DATA Press the left or right arrow to select [YES] at the confirmation screen, then press . Then all settings defaults then restart printer then check. Also make sure ink cartridges are fine and there is not any paper jam inside the printer. Let me know if you need further assistance. Thanks for using FixYa.
Posted on Nov 11, 2010
Do you have directions for armitron mens pro sport watch 49/1000
Hi robinmsavage,
I will be glad to help you with your concern regarding your Armitron Wristwatch, what exactly would you be experiencing? cause I only put info on how to set time and date on the Watch.
Please see below steps:
  • Your Armitron Watch will have Four Button on the side of the watches rim.
  • Button on the upper Left is MODE.
  • Button on the lower Left is LIGHT.
  • Button on the upper right is DATE.
  • Button on the lower right is Alarm.
See Steps below:
*Setting the time*
  • Press and Hold down the Mode Button til the Hours flash
  • Then push Alarm Button to set the Hours
  • Press and Hold down the Date Button till the Minutes flash, then push Alarm Button to set the minutes
  • After setting the minutes on your watch, Press Date till you get the month flashing push Alarm to set the month
  • Press the Date again till the Date flashes, then push Alarm to set date
  • Press the Date again till the Date on your watch flashes, then push Alarm to set the date
  • After setting everything push the Mode Button again just once to set everything or finalize your settings on the watch.
I hope that this will be of help regarding your query on how to set the time on your Armitron watch, I also included the setting of the time and date just for further details.
Thank you for choosing Fixya,
mvincentc
Apr 21, 2011 | Armitron Chronograph Sport #204345BKBK...
How I change the time Armitron WR165
Thank you for contacting FixYa.
Light = A - lower left button
Mode = B - Upper left button
Date = C - Upper right button
Alarm = D - lower right button
Set time time / date
Press and hold B (Mode) untill alarm hours flash
Press D (Alarm) to advance these
Press B (Mode) again, seconds will flash,
press D (Alarm) to advance these
Press C (Date), minutes flash, press D to advance these
Press C again, hours flash, press D to advance these
Best regards. Jewel
Sep 18, 2010 | Armitron Watches
I need solution asap on alarm check printer 5100 on my canon mx300
http://iusermanual.com/printer/canon-pixma-mx300-printer-manual.htm
here's a link for the manual
good luck
Jul 29, 2010 | Canon MX300 Office All-In-One Printer
My cannon mx300 is giving me an alarm code 5100
5100 means either the carriage is not moving freely back and forth or there is grease or ink on the encoder strip. You can clean that clear plastic strip behind the carriage with a Q-tip, but also check on the right and left side for paper scraps stopping the carriage.
Nov 23, 2009 | Canon PIXMA MX310 All-In-One Printer
Cannon mx 310 error 5100 Says chck printr with alarm light flashi
heres the problem from service manual: error 5100, a error occured in your encoder signal, it list 4 things in the serice manual.
carriage unit. carriage motor, logic board, timing **** film.
ok my first thing i would look at is the film that runs directly behind the print head i would think it is dirty. just turn on printer and get print head to the middle and turn off machine, gentle move print head to one side and gentle clean the film strip with a cloth with a little metho on it, move print head to other side and clean other part of ****.
i reckon that will fix your problem its a common problem they tend to get a bit of grease on the timming ****.
Canon Tech
May 30, 2009 | Office Equipment & Supplies
Alarm flashes...nothing works
when i did print job.. now nothing is functioning.. the alarm keeps flashing and displays 'check printer ' 5100, i have unplugged many times
Apr 16, 2009 | Canon MX300 Office All-In-One Printer
Faxing with Cannon MX300
Go to the Canon website and ask for the manual and you can download the manual for your printer
Nov 17, 2008 | Canon MX300 Office All-In-One Printer
Setting tha alarm
Press MODE (lower left) button until "ALARM" appears in the display. Then press SET (lower right) button. T1 should flash to indicate you are setting an alarm for Time 1. Press MODE to cycle through the alarm settings. Press ALARM (upper right) button to advance the hours, tens and minutes to the desired time. When the far right of the display is alternately flashing "T1" and then "AL" you can change the chime and alarm tones by pressing the ALARM (upper right) button. The alarm is on if the middle symbol (lines) on the left of the display is shown. The hourly chime is on if the lower symbol (bell) on the left of the display is shown. When you are done, hit MODE (lower left) again to return to normal time display.
Dec 21, 2007 | Timex Expedition 40141 Wristwatch
Canon PIXMA MX300 All-in-One Printer Logo
66 people viewed this question
Clive
Clive
old marine
old marine
