Question about Whirlpool Refrigerators
I have whirlpool top freezer fridge Model # GT2SHMXMS01, seial # 2538372. The refrigerater compartment gets too cold even if the refrigerater temp control is mover almost all the way to to off position
    Genius:
  • 1,044 Answers
It is obvious that your temperature control unit is not functioning well. It may be moving all the way to off position but the contact is remains stuck up in he previous position i.e. it is slipping. If the fridge is under warranty period ask the firm/retailer to replace the temperature control unit since you may not be conversant with the working/settings of temperature control unit.
I would also request you to try this before you take action as above.
Most of the fridges are coming with double temperature control units. One for freezer compartment and the other for the refrigerator compartment. Their working is interrelated. Try varying the settings of the freezer compartment and see the effect.
Posted on Nov 11, 2010
Can you tell me why please?
All the big cooling happens inside freezer compartment. Freezer gives little cool air to fridge compartment. Now when the vent blocks that little cold air cannot go into fridge compartment. Thus your freezer works good but not fridge compartment. Milk goes bad but frozen meet keeps good.....
Vent freeze up either due to defrost problemt, defrost drain line problem, Evaporator fan problem or even can be your damper motor not opening due to unit failure or frozen damper door.
Sep 19, 2014 | Whirlpool GX2FHDXVY Gold Stainless Steel...
Kelvinator fridge not cooling
Try defrosting the fridge. Check the cold plate at the back of the food compartment once the fridge has been defrosted and turned back on again. The cold plate in the freezer (around the walls) will be cold to touch as will the cold plate at the back of the fridge,
Oct 20, 2013 | Refrigerators
Fridge of my Hotpoint FFA90 fridge-freezer freezes
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Mar 11, 2010 | Hotpoint FFA90 Bottom Freezer Refrigerator
Fridge (KBRA22KLSS00) has lower freezer compartment. Fridge is running, & freezer is cold,however upper portion of fridge is not cold. Is there a fan or a control to bring the cold into the fridge...
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Aug 31, 2009 | Refrigerators
My fridge is freezing my cans of beer even tho it is on low? It is a phillips 360L cycle defrost (fairly old)
Here's a diagram with your damper parts. http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=ET1FHTXMB00&productCategoryId=0166000&brandId=1198&modelName=TOP-MOUNT-REFRIGERATOR&diagramPageId=00003&componentDescription=LINER%20PARTS&documentId=W0404055&backToLink=Return%20to%20Sub%20Components%20list
Jul 10, 2009 | Whirlpool ET1FHTXM Top Freezer...
Fridge not staying cold
Inside the fresh food compartment there is a defrost timer hidden behind the temp control panel. Sometimes there is a plastic plug over the hole that you need to put a flathead screwdriver in and slowly turn it clockwise. When compressor stops I want you to wait about 25 minutes to see if the refrigerator comes back on by itself without help. If it does I need you to listen inside the freezer compartment for sa sound of crackling or sizzling noise indicating defrost is taking place. Let me know, Sea Breeze
May 19, 2009 | Whirlpool ED5GHGXMQ Side by Side...
Amana fridge
is the freezer cold. the freezer is acualy the only refrigeratted compartment . it has the evap coil in the rear wall and a fan to cerculate the air . a potion of the air is let into the food compartment . most comonly the freezer defrost system can be the fault. so i would requier answers to the first question. is the freezer compartment working. hope this helped
Oct 19, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Freezer cold but not fridge
too much ice bulid up will stop enough cold air being blown into the fridge.Try turning it off letting all ice melt then turn it back on again and set thermostat at a lower temp.There may be ice you can't see.
Aug 05, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Whirlpool fridge to cold
Both the thermostat and Adaptive defrost control are inside the fresh food compartment on top..
also check you damper it it is closing
let me know
Apr 04, 2008 | Refrigerators
Refrigerators Logo
286 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
