Canon mx700 printer error code uo51 print head not installed, but i did not touch the print head any suggestions?
IB4G2008
  • 3587 Answers
SOURCE: Canon mx700 rejecting remanufactured ink cartridges
big issue with remanufacturing is how integritous is the fit of the cartridge, and also the interface. When these are re cut, so to speak, tolerances can stack up, and one thing about Canon, is they are a stickler for tolerances. You may have an issue with the cartridge fitting in the carriage, but not interfacing with the system. Happens sometimes..
got backup?
Posted on Feb 15, 2008
worldvet
  • 859 Answers
SOURCE: Canon MP500 Printer head error
Print heads for nearly all printers are rated at 2 years. You may also need to clean the tube from the resevoir at the ink supply to the cartridge and clean the working resevoir on the cartridge as well. If you are up to this challenge there is a how-to at your manufacturer's web site or you can have a tech do it. Most people, when they realize how inky you will be getting choose to have a tech do this.
It is best to use 100% denatured alcohol, from your hardware store, to clean these parts and tubing. But, you must take precautions.
DO NOT USE DENATURED ALCOHOL UNLESS YOU READ AND FOLLOW THE DIRECTIONS ON THE BACK OF THE CAN.
I'm not kidding about the precautions. I do all this stuff outside when there is a breeze in the air and then I stay up wind of my work.
If you have any questions whatsoever just feel free to comment back to me.
Regards,
Worldvet
Posted on Jun 07, 2008
SOURCE: canon i255 printer--print head error
my cannon printer i255 head has a problem and it should be replaced so i need a printer head of i255, please give the price of printer head
Posted on Jul 08, 2009
komguy
  • 2306 Answers
SOURCE: Error msg - Print head is incorrect.
The printhead has gone out, you need a replacement, # QY6-0059-000. Around $50.00
Posted on Aug 03, 2009
xptareq2000
  • 1447 Answers
SOURCE: Canon Pixma MP600 - Error Message U052 ... incorrect print head
U052 mean the FINE cartridge may not be install properly,or the Cartridge may not be compatible with this machine.Install the appropriate FINE Cartridge. If lines are misaligned or the resulting out put is not satisfactory carry out the FINE Cartridge Alignment.
Posted on Nov 27, 2009
Hello, To whom it may concern, I just bought a refurbished Canon Pixma MX700 from Overstock.com and I set it up according to the instructions and it does not print much at all. I have run all of the...
Make sure you have the latest drivers for the printer installed on your computer by visiting the manufacturer's website and getting and installing the latest version. Next, if you've already run the cleaning procedure, try replacing the ink cartridges. Finally, if that doesn't work, the printer may be defective and should be sent back.
Mar 18, 2011 | Canon PIXMA MX700 All-In-One InkJet...
My MX700 canon printer is flashing the on ff green light and the gold alarm light and say error code 6A80. My book says to unplug all power and the plug back in but it is doing the same thing. Thanks for...
The printer head has locked itself and won't move.
I have found a solution for you on the Internet - here are the details :-
I was able to unlock the print head - just with a small piece of foil.
Cut a 3-5cm wide stripe from a sheet of overhead-foil (90um thickness), move it below the print head, and move it to the front and upwards, to the back and upwards. Remove the foil. After switching the printer on - it will work as before and be able to move the head. No need to disassemble the whole MX700!
Leo.
Nov 21, 2010 | Canon PIXMA MX700 All-In-One InkJet...
What does error code 5c00 in a canon mx700 printer mean?
Hi, 5C00 is a purge unit error, the purge is the cleaning unit on the right where the print head parks when shut off. If paper or something is caught in there you get an error, also ink build-up can stop it as well, a damp Q-tip will clean some of the ink away, if it doesn't help you need a new purge assembly.
Hope it helps.
Thanks for using fixya..........
What does an error 5200 mean?
(1) With the printer turned on, unplug it
(2)Open the top and bring the ink cartridge holder to the middle
(3)Raise the gray bar and remove the print head assembly with the cartridges in it
(4) Lower the gray bar with the head missing and close the top with the head out
(5) Restore the power,wait til the printer wakes up
(6) It will tell you to put in the cartridges
(7) Restore the print head, close the top and the printer should resume working.....
it is a printer head error and some solved it that way ..after you do that it will resume the function and work ..
_________________
Jun 01, 2010 | Canon PIXMA MX700 All-In-One InkJet...
Error message 6a80 mx700 printer canon what is this?
Hello
Ok, the error code you are getting refers to a paper jam, which the paper is usually torn from the big piece and stuck, you need to have a good lok to find it.
Most probably the paper was ripped inside, and one piece is stuck somewhere on a sensor. Usualy is the purge unit that clean up the print head, and it's located inside on the right side (printhead parking place).
Take a torch, lift up the scanner unit, with the unit ON, wait for the print head to come in the middle, move it to left to make more room, and check the right side, inside the unit.
Kind regards
Andrea
Dec 13, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Error code 5100 shows onscreen and there are no comments in guidebook
move ink tank to right and turn of then turn on, found in another canon printer fix it.
Jan 28, 2008 | Canon PIXMA MX700 All-In-One InkJet...
385 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
