Question about Behringer XENYX 2442FX Mixer
Computer does not recognize it and the mic does not record into the computer... maybe my connections are wrong..pls help me
    President:
  • 1,138 Answers
I have a 1222FX and here is how I have it hooked up. I have a cord that has an 1/8" stereo plug on one end and two mono RCA jacks on the other. The 1/8" end goes into my line in on my sound card. (not the microphone in ). The RCA jacks are hooked to two cords that I made up that have a RCA plug on one end and a XLR plug on the other. The XLR plugs are wired so that they are unbalanced. Pin one is ground and pins two and three are soldered to the positive. I used shielded cable and the shield is soldered to negative on the RCA jack but left unconnected on the XLR jack. This prevents hum. You may be able to purchase premade cables but I made my own. The XLR jacks are plugged into the left and right balanced or unbalanced Main output jacks of the mixer. On your computer click Start then Control Panel. Click Sounds and Audio Devices. Make sure that Place Volume in Taskbar is checked. Place the volume slider in about halfway position if there is one. Click Advanced and a control panel should pop up. It will say Play Control at the top. You will want your speaker volume about half way also. Make sure line in is NOT muted (checked ) and is also about half way up. Plug headphones into the mixer and get a good sound with the microphone you are using. If it is a microphone that requires phantom power make sure you turn the power to the mixing board on first, then the phantom power. Do this with the main volume control all the way off. When the mixer has warmed up for a minute or so you can bring the volume up to get a good sound. When you are done recording, make sure you slide the volume down again. Then turn the phantom power switch off and then the main power. This procedure protects your equipment. On the Play Control volume panel on your computer click on Options then Properties. You will see that it is checked for Playback. Check it for recording. Make sure that where it says Show the following volume controls, it has Playback volume and at least Line In checked. Now check the Recording Controls. Where it says Show the following volume controls make sure that at least Line In is checked. Click on O.K. and your Recording Control window will pop up. Make sure that Line In select has a check mark. Slide the volume up until you get a good sound through your computer speakers or your headphones if you have them plugged into the computer. If you accidentally close this window, Click on the speaker symbol in your taskbar at the bottom. You will have to switch between Play Control and Recording Control as before. You didn't mention what software you are using so I advise you to read your manuals carefully. The manual for the mixer has a page with wiring diagrams for cables. Here is a link to a site with lots of good info and an invaluable FREE book that you can download:http://www.recordingreview.com/ I hope this helps.
Posted on Nov 11, 2010
How do i update the firmware and is this may be the cause of the USB b not recognizing any memory sticks that we've tried?
usb b is for streaming digital media,not memory sticks,
  • High-power dual DSP engine with improved digital effects and output processing including Feedback Ferret®, 28-band GEQ/5-band PEQ, delay and limiter
  • USB 2.0 "A" connection to record directly to or playback from memory stick
  • USB 2.0 "B" connection for streaming digital out
  • 3-band EQ with sweepable mid-frequency and variable low cut filters
  • 2 stereo channels with dual mic/line inputs
  • 48 volt phantom power
  • 6 Aux sends
  • 4 subgroups
  • 100mm faders
  • Double the processing power of the original FX Series
  • All new switching power supply design is more efficient than the original
  • Silencer™ mic preamp XLR inputs
  • Weight Packed: 45.00 lb(20.412 kg)
  • Width Packed: 25"(63.5 cm)
  • Height Packed: 36"(91.44 cm)
  • Depth Packed: 11.5"(29.21 cm
May 19, 2015 | Peavey 32fx USB 32 Channel Mixer
Does anybody know how to fix built-in microphones on rolland BR-600. When I attempt to record, the only sound that gets recorded is noice (hissing sound), and that only after cranking rec volume and mic...
Most of these have a SETTING in the menus that selects the source from different mics and/or line inputs. If the setting is to the line input instead of mic, and no audio is connected to the line input it will act like you described.
Jun 23, 2011 | Boss BR-600 Digital Recording Studio
The recording level to my Mbox is very low for some reason. I am running Pro Tools LE and I have a shure 87a microphone. Every time I attempt to record a track, the input volume is incredibly low...
Make sure you turn the Phantom power on the Mbox2 on as the Shure 87A requires it being a condenser mic.Make sure you use XLR mic cables. These are just things to check on.
Jan 29, 2011 | Digidesign *mbox2...
I have a lexicon alpha, samsung CO1 condenser mic and a samsung phantom power box, i have all the correct wires but i dont think i am connecting the correctly, HELP ME ! lol
Sorry, but the Alpha does NOT have Phantom power which IS required for a condenser mic.
You will either have to get a mic preamp that supplies phantom power or go to a dynamic type mic if you stay with the Lexicon Alppha.
Jan 17, 2011 | Lexicon Alpha Personal Recording Studio
Need to connect to a sound blaster live sound card for recording using sonar as recording program. hace had it in storage for sometime and can't remember what went where
This particular mixer offers a usb (2 channel connection) that can be simply plugged into the computer usb 2.0. These channels should be available in Sonar from the channel Input/output drop boxes. You may need to restart Sonar, the mixer or both for them to be recognized. You may also need to run the Wav Profiler in Sonar. Typically the Wave Profiler is found in the Options>Audio menu but may be different on each edition of Sonar. The above info is for Sonar 7.
If you are wanting to record several channels at once then I would recommend connecting your Mixer's Direct Outputs from each channel to a corresponding input of the soundblaster if your soundblaster supports multiple channels. And then use the usb outbut from the Sonar to monitor the computer playback of your master stereo channel. Or, you may connect the soundblaster outputs to unused channels of the mixer or to the tape return or auxilary inputs to monitor the computer playback on the mixer.
Alternately you can send the signal to your soundblaster via the buss outputs. This will limit the number of simaltanious output channels to the number of busses on the mixer, but you can send any mixer channel to any buss without unplugging the instruments or mics.
Here's the link to the page where you can download the free pdf manual for this mixer. Page 14 explains the output connections and has diagrams.
http://www.behringer.com/EN/Products/2442FX.aspx
Oct 09, 2010 | Behringer XENYX 2442FX Mixer
How to connect it to computer mic input
Instead of using the mic input on your soundcard try using the auxiliary input. You will need a cord that converts from 1/4" mono to 1/8" stereo. That cord goes from out on your pedal to aux in on your computer. Use whatever you need to go to the input of the pedal.
May 31, 2010 | Behringer Bdi21 Bass V Tone Modeling Pre...
Connect xenyx 2442fx to computer
If you want to record in stereo, the quick and dirty way is to get a 1/4 inch stereo to 1/8 inch plug cable and go frrom the headphone output jack. (Use a Wye connector if you need to listen on the phones)
All the other outs are TRS and XLR balanced and the computer audio (mic) inputs are unbalanced. You would need special cables to connect those.
Feb 08, 2010 | Behringer Xenyx 1002fx Mixer 10 Input 2...
No live sound using Samson CO3U and Windows 7 x64
I don''t think you can solve this problem. The problem is that the computer has to digitize the incoming audio, then echo it out. This conversion takes time and is also governed by the real time clock servicing of the devices. You could try upping the priority of the conversion process, but I don't think you are going to be satisfied with the result either.
You would be happier to use a mic and external mixer where the audio is true real time rather than having the conversion latency time.
Jan 29, 2010 | Samson Audio C03upak Co3u Microphone with...
Problem with computer recognizing Audio Microphone.
Check if you selected the mic as the default audio input on the respective programs.
Aug 07, 2008 | Samson Audio C01upak C01u Microphone and...
Behringer XENYX 2442FX Mixer Logo
140 people viewed this question
Top Behringer Music Experts
Michial Gueffroy
Ben Armstrong
Are you a Behringer Music Expert? Answer questions, earn points and help others
