hi, if it 's stays three pause three then the error "Left Motor wiring fault" , now I suggest you remove the lead from the controller and refit check the connections are clean and tight.
The three lights flashing is the Dell error code, you can download a table of error codes if you google it.You have to count how many times each light flashes. a Three digit number error code. Then you can fix the computer.
see on your remote control there will be three empty space in button columns if you open your remote control circuit board then you find there three hidden keys by pressing one of them the aging error will desapear
No Beeps
Short, No power, Bad CPU/MB, Loose
Peripherals
One Beep
Everything is normal and Computer POSTed
fine
Two Beeps
POST/CMOS Error
One Long Beep, One Short Beep
Motherboard Problem
One Long Beep, Two Short Beeps
Video Problem
One Long Beep, Three Short Beeps
Video Problem
Three Long Beeps
Keyboard Error
Repeated Long Beeps
Memory Error
Continuous Hi-Lo Beeps
CPU Overheating
One common error that many PS3 players experience at some time is the
beeping error that some call the "three beeps of death". What happens
with this error is the PS3 will beep three times in short succession,
and then suddenly shut down. Sometimes the unit will restart and play
normally after about ten minutes, while for others, it will refuse to
turn on at all.
If the three beeps error has happened to you, you are likely
wondering if this a serious problem, needing to be sent in for repairs,
or whether it is a problem that can be fixed at home. Unfortunately,
there is no easy answer for this question because there are potentially
multiple causes of the three beep error. If you are lucky, you may only
experience this error once or on rare occasions and you may just choose
to ignore the problem and deal with the rare shut downs that may occur,
as unpredictable as they are.
However, if the three beep error happens repeatedly, you have a more
serious issue that is going to need some proper troubleshooting and
repairs. One of the most simple fixesfor the three beeps of
death problem involves resetting the PS3 hard drive. In other cases,
however, the problem may be the result of dirt and dust building up
inside the unit, causing it to overheat. By properly cleaning your unit
both internally and externally, you may be able to resolve the problem.
In the most serious cases, however, you may be facing a motherboard
issue that is in need of professional repair or replacement.
The error is actually a catch all for three problems or a better way of putting it three problems can generate this error Sylvania requires that you call them with the error code to get an answer on which of the three errors it could be, However I can tell you from working on these units that the issue has to do with recording laser power.
