Question about GE Ovens
My GE oven won't light - GE Ovens
  • GE Master
  • 43,501 Answers
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Posted on Nov 11, 2010
Oven won't heat
major electrical problem. call a repair man asap!
May 19, 2013 | GE Profile JT912 Electric Single Oven
Ge oven jtp18 elements won't heat
The limit switch in a Ge oven usually works or is blown. I would look at the oven sensor located at the back of the oven. It should read approximately 1k ohm at room temperature.
http://www.on-timeappliance.com/ovenrepair.html
Mar 26, 2012 | GE Profile JTP18 Electric Single Oven
Ge profile oven lock button won't go off
  • 1.Press the "Clear/Off" button on the control panel to reset the oven. This will clear the lock setting and unlock the door.
    2.Allow the oven to cool to room temperature to avoid turning the lock on again during this heating cycle.
    3.Reset the oven to the temperature you require to finish cooking by pressing the correct temperature control on the control pad.
    or
  • 1.If your GE Profile microwave won't turn on, unplug it, then plug it back in. A power outage may have occurred due to a power surge. Check your home's fuses and circuit breakers.
    2.Set the clock of your GE Profile microwave. Certain models will not operate until you set the clock. Select the "Clock" key and type in the correct time.
  • 3.Hold down your microwave's "Off" button. You may have accidentally hit the control-lock feature on your GE Profile microwave. Hold down the "Off" button for three seconds to turn the lock off.
  • 4.If the sensors of your GE Profile microwave are not working correctly, remove the food from the machine. If the sensors detect food-surface temperatures over 200 degrees Fahrenheit, it will not work properly until the area cools down.
  • 5.Contact GE Support if you are unable to resolve the issue on your own. Call the GE Support hotline or browse the help library on the GE website. You can also schedule a service visit on GE's website.
  • Nov 22, 2011 | GE Profile JK915 Electric Single Oven
    I replaced a heating element but the oven still won't light
    is this gas or electric?
    you are using terminology of both, but not specifying which it is..
    if gas you could get a thermocouple at your local hardware store or home depot..
    If electric, test the switch with a multi-function tester
    Best regards
    Ck
    Aug 18, 2011 | GE Ovens
    We have a GE XL 44. The oven won't heat up at
    sounds like a bad control panel , I bet it is a touch button type if it is get all the info off unit and order control panel here http://www.appliancepartspros.com/
    Jul 27, 2011 | GE Ovens
    Hello I just bought the house and my GE oven door won;t close all the way in. Could you please help?
    there is a latch in the top of the door that locks in clean mode . need to get it out of clean mode
    Sep 03, 2009 | GE Profile JT912 Electric Single Oven
    GE oven will bake but not broil
    I trhink more than likely you have a faulty element, you need to test wether you have power to the element with a voltage tester or meter
    Nov 22, 2008 | Ovens
    Ovens Logo
    44 people viewed this question
    Top GE Ovens Experts
    William Miller
    William Miller
    Dan Webster
    Dan Webster
    Are you a GE Oven Expert? Answer questions, earn points and help others
