Question about Gaggia Platinum Swing 2-Cup Coffee Maker
My gaggia platinum is showing an out of service error code [1] and i don't know what to do. Called the service centre all i get is "leave a message".
On my machine remove water tank, remove crip / coffee bin, remove mach and wash. Tip machine on its side (turned off) using a small screw driver go around the coffee grinder and clear it completly, you will need a touch. Re assemble. First run with no beans and wait for the fill bean message, fill with beans off you go. Its only happend twice both with cheap beans
Posted on Nov 21, 2010
  • 3 Answers
When you see that error if you push coffee button does it turn from 1 to 41? if so you could need either a new HAL sensor for the grinder motor or a new grinder motor.
Posted on Jan 11, 2011
Gaggia cappuccino xtwo. What is error code 1?
Im not sure if this will help but I've got some Gaggia Accademia Error Codes, maybe they are the same as the Gaggia cappuccino xtwo.
Hope it helps. https://wll-documents.s3.amazonaws.com/Gaggia/Accademia/Accademia%20Error%20Codes.pdf
Apr 05, 2016 | Gaggia Coffee Makers & Espresso Machines
Gaggia Platinum Vision no power
You are correct it could be any of the possibilities you have mention.
It is worth checking the two thermal cutouts on top of the boiler.
These can be accessed by removing the top cover only.
If you press the center of the resets and you hear a click you have found the fault
Jan 22, 2013 | Gaggia 74845 Platinum vision coffee maker...
My new gaggia accademia won't work. IT shows error code 05. Con Youtube help me?
reset the error code and read your instr. manual. God bless you
proceed according.
If the coffee maker doesn't work at all, make sure power is on at the outlet, check the electric cord , the internal fuse or the thermostat and heating elements replace as needed.
Oct 17, 2012 | Gaggia 10003380 Accademia Automatic...
What does wrench on screen of gaggia platinum vision indicate
I found a failing power supply board can cause the 'wrench' error code even in standby. The board is available for about $65 online and works in many Saeco models as well.
Jul 18, 2012 | Gaggia 74845 Platinum vision coffee maker...
Gaggia Platinum vision says dispensing failed
I suggest the spanner is telling you there is a fault, so you will need to get it serviced or repaired. It is doubtful that you can do anything.
May 06, 2012 | Gaggia 74845 Platinum vision coffee maker...
Can anyone tell me how i descale a Gaggia Vouge Platinum pls
There is a descaling solution that you can buy but i just use white vinegar.
Fill the tank with the vinegar and turn on. Turn the hot water button on.... run for 15 seconds and then turn off. leave for 10 mins and repeat 5-8 times.
Then hold the hot water button on for 6 seconds.
Jan 19, 2011 | Gaggia Platinum Vogue 90800 Espresso...
NEW GAGGIA PLATINUM VISION GRINDER NOT WORKING ANY WAY TO FIX THIS?
If it's new send it to a service centre.
These grinders are failing and can also damage the power supply board.
Dec 29, 2009 | Gaggia Platinum Vogue 90800 Espresso...
What does it mean when the red exclamation mark light is flashing?
Either you need to prime the pump, or the brew unit is not in correctly, the steam knob is not in the right position, the tray is missing.
Sep 20, 2009 | Saeco Odea Go
Gaggia platinum leaking from milk island
The problem is the steam valve leaking.
It does not close fully and leaks.
You will find that when you turn the knob is seems very loose.
A service is required.
Jun 23, 2009 | Gaggia Platinum Vogue 90800 Espresso...
NEED SPARE PARTS ON GAGGIA SYNCRONY DIGITAL COFFEE MAKER
you can get parts from www.nuovaricambi.com
PS: if you somehow know Syla Mamadou officer if UN he whas in macedonia, in my town, many many Salams and greetings i want to send to him. i hope you know him, he is from Dakar too.
Nov 25, 2008 | Gaggia Titanium Espresso Machine
Gaggia Platinum Swing 2-Cup Coffee Maker Logo
2,234 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Roger Jackson
Roger Jackson
Level 1 Expert
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
