Question about Samsung LNT3242H Television
"Sound Select" in menu is grayed out. Cannot
SOURCE: close caption
You need to turn on closed captions through the menu of your PVR. To have it on all the time, turn the box off, press menu on the front of the box, and scroll down to captions.
This should fix the problem
Posted on Mar 10, 2008
  • 29 Answers
SOURCE: LN-T4671F
You have to have a RF cable hooked to the tuner on the back of the set, should be 2 tuners, hook up the cable to either one and the channel option will be selectable
Posted on Mar 15, 2008
SOURCE: samsung lcd ln46a550pf3 no sound from hdtv reciever
ok your tv does not come with the very best sound, you have to get a receiver 7.1 or you can use the optical wire , that's if the system you are using has that option.
Posted on Jun 28, 2008
SOURCE: HDMI Problem
check your owners manual tv. my tv has 3 hdmi input.your tv manual will tell you which one to use. make sure you select the correct resolution. 1080p/720/480 etc. oh...make sure you have hdmi cables too
Posted on Dec 08, 2008
tvtek
  • 1284 Answers
SOURCE: When plugging in a new
Does the HDMI output on the PS3 have to be turned on first in its settings? Make sure the settings on the PS3 are at a minimum of 720p as if it is set to 480i the TV probably wont notice anything connected to HDMI.
Posted on Nov 06, 2009
I have a Harman/Kardon AVR 235. I'm not getting sound for my tv and ps3 but sound from the radio. what should I check first?
I would check that you have selected not only the right source (eg: DVD or CD etc...) but you also need to assign which inputs follows the source selected.
So for example, if you plugged in your PS3 to your AVR235 using the Optical wire, and you want to select DVD every time you want the PS3, you must go in to the menu and make sure that Optical "xx" is assigned to DVD.
Select the button "Digital" on your remote to select in the Digital Input, and select the appropriate one.
That being said, you also need to make sure your TV Speakers are Disabled, or Sound sent to External source. Check in your TV menu to make sure that in your sound menu, that you select "TV Speakers to OFF" or might be other options, the option name varies from TV to TV.
Same with the PS3, make sure that in your System Setup Menu, scroll down until you see Sound Settings and select Audio Output Settings and make sure you select your connection (whether it is Analog RCA, or Optical.) Then try it again and see what happens.
Hope this helps,
Jul 24, 2011 | Harman Kardon Audio Players & Recorders
Tip
The Best Way to Connect Your PS3 To the Internet/Wifi
<span>Instructions</span> <ol> <li> <p>Make sure your wireless Internet connection is active and at full strength. Unplug the PS3's Ethernet cable if it is plugged into the system.<br /></li> <li> <p>Turn on the Playstation 3 game console and select "Network Settings" under the "Settings" option in the main menu.<br /></li> <li> <p>Select the "Internet Connection Settings" tab and select "Yes" when the system displays a new screen saying you will be disconnected from the Internet.<br /></li> <li> <p>Select "Easy" on the next screen that asks what type of installation you want to use.<br /></li> <li> <p>Select "Wireless" when it asks you what type of Internet connection you have.<br /></li> <li> <p>Select "Scan" on the next screen.The system will search for all available Internet connections in the area.<br /></li> <li> <p>Select your home Internet connection when the screen pops up displaying the available Internet options. Select your security settings and enter your encryption key. Save your settings.<br /></li> <li> <p>Test the connection by selecting the "Test Connection" option. If the connection has been made, your network information will appear on the screen. <br /></li></ol>
on Jan 05, 2011 | Sony Playstation 3 (PS3) Console
Tip
How to set up ps3 to wireless internet.
<span> <li> <p>Make sure your wireless Internet connection is active and at full strength. Unplug the PS3's Ethernet cable if it is plugged into the system.Turn on the Playstation 3 game console and select "Network Settings" under the "Settings" option in the main menu Select the "Internet Connection Settings" tab and select "Yes" when the system displays a new screen saying you will be disconnected from the Internet.Select "Easy" on the next screen that asks what type of installation you want to use.Select "Wireless" when it asks you what type of Internet connection you have.Select "Scan" on the next screen.The system will search for all available Internet connections in the area.Select your home Internet connection when the screen pops up displaying the available Internet options. Select your security settings and enter your encryption key. Save your settings.Test the connection by selecting the "Test Connection" option. If the connection has been made, your network information will appear on the screen.<br /></li><span><br /><br /></span></span>
on Dec 06, 2010 | Sony Playstation 3 (PS3) Console
Only sound comes when i connect HDMI cable to my TV for the ps3
you need to select High definition output on the PS3. Connect it via hdmi and via standard lead switch the tv to standard so you can see the picture then select high definition output. Switch over to hdmi and you should see a picture
Mar 01, 2011 | Video Game Consoles & Games
I tried to connect my emerson 227 bluetooth to my ps3. it tells me to press the start button and enter button on the device at the same time and wait until the screen changes.. well it never changes.. what...
Pairing the Headset with a Sony Playstation3 Entertainment System:
To pair your [EM-227] Bluetooth Headset with the Sony Playstation3 (PS3), go to the PS3 main menu, scroll to "Settings" and select.
Scroll to "Accessory Settings" and select.
Scroll to "Manage Bluetooth Devices" and select.
The menu will ask: "The Bluetooth device has not been registered. Do you want to register it?"
Select YES.
Put your [EM-227] Bluetooth Headset into discover mode (see X.XX of this manual for instructions on how to get the headset into discover mode).
Select "Start Scanning" from the PS3 menu.
Once the PS3 has discovered the [EM-227] Headset the screen will read "Select the Bluetooth device to register".
Select [EM-227].
The PS3 will ask for a passkey. Enter [0000] then press "OK".
Now press O (the PS3 circle button) to get back to the previous menu.
Scroll to "Audio Device Settings".
Change the "Input Device" to [EM-227].
Note: "Input Device" is the microphone, how others will hear you speak.
By default, the "Output Device" will now switch to [EM-227].
Note: "Output Device" is the audio, how you will hear the PS3 audio and others speaking.
If you would like to hear the PS3 audio and others speaking through your TV or Audio System, scroll to "Output Device" and switch to "System Default Device". If you would like to hear sound through the [EM-227] headset, then leave the "Output Device" setting on [EM-227].
To test your connection, speak into the headset and you will see the bars above the "Microphone Level" moving. If not, repeat the pairing process.
Press "OK" to confirm the new settings. You are now ready to use the [EM-227] Bluetooth Headset with your PS3 Entertainment System.
For further assistance with Bluetooth settings on your PS3 please refer to your PS3 instruction manual.
Oct 06, 2010 | Samsung WEP200 Headset
Tip
How to hook up bluetooth on ps3
<span> <li> <p>Update your PS3. If you do not have the latest system update, you may not be able to sync your devices correctly. To update your PS3, go to the "System Settings" menu and select the "System Update" icon. After you have finished updating, restart your PS3.Put your Bluetooth device in discovery mode. Generally, you activate this by holding the Bluetooth activation button--but because headsets vary, you may need to consult your manual for precise instructions.Go to the "Settings" tab on the PS3's cross-media bar and select the "Accessory Settings" menu. From the new menu, select "Scan for Bluetooth Device." The PlayStation 3 should detect it automatically.Return to the "Settings" menu and select "Audio Settings." Go to "Input/Output Settings" and select your headset as the device. Your Bluetooth headset should now be completely synced with your PS3 and ready for online chatting.<br /></li><span><br /><br /></span></span>
My PS3 will not play sound on my Sony Bravia HDX275 surround sound system. I have the HDMI cable plugged from the PS3 to the TV. I have another HDMI cable from the receiver to the TV as well as a opitcal...
Adjust the system's audio output settings. These settings are mainly used when the system is connected to audio devices that support digital audio output, such as AV amplifiers (receivers) for home entertainment systems.
1.
Confirm the formats supported by your audio device.
Settings vary depending on supported formats. For details, refer to the instructions supplied with the audio device.
2.
Select in_soundset.gif (Sound Settings) under in_setting.gif (Settings) in the home menu.
3.
Select [Audio Output Settings].
4.
Select the input connector on the audio device. Channel numbers and audio formats that are supported vary depending on the connector in use.
soundoutput001.jpg Input connectors on the TV or AV amplifier (receiver) PS3™ system output connectors Channels that can be used for output 2 Ch. 5.1 Ch. 7.1 Ch. HDMI HDMI OUT connector in_maru.gif in_maru.gif in_maru.gif Digital Out (Optical) Digital Out (Optical) connector in_maru.gif in_maru.gif - Audio Input Connector / SCART / AV MULTI AV MULTI OUT connector in_maru.gif - - 5.
Select audio output formats.
Select all output formats that are supported by the audio device in use. If [Audio Input Connector / SCART / AV MULTI] is selected in step 4, the screen for selecting audio output formats will not be displayed. If [HDMI] is selected, you can also select to automatically set the audio output format. (In this case, the HDMI device must be turned on.)
soundoutput003.jpg 6.
Check your settings.
You can go back to the previous screen and revise the settings by pressing the in_left_key.gif button.
soundoutput002.jpg 7.
Save your settings.
The audio output settings are saved on the system.
Hints
  • [Linear PCM 2 Ch.] audio is set to be output from all output connectors by default. If you change the audio output settings, audio will be output only from the connectors that were set.
  • If you change the audio output settings, the system will no longer be able to output audio from multiple output connectors at the same time. For example, if your system is connected to a TV via an HDMI cable and to an audio device via a digital optical cable and you switch to [Digital Out (Optical)] under [Audio Output Settings], audio will no longer be output from the TV. To output audio from the TV, switch the setting to [HDMI], or select in_setting.gif (Settings) > in_soundset.gif (Sound Settings) > [Audio Multi-Output] and set the option to [On].
  • If you select [Linear PCM 2 Ch. 88.2 kHz] or [Linear PCM 2 Ch. 176.4 kHz] in step 5, sound may be intermittent or may not be emitted from some audio devices.
  • When using an HDMI cable, only [Linear PCM 2 Ch.] audio will be output from PlayStation®2 and PlayStation® format software. To output Dolby Digital or DTS audio, you must connect the PS3™ system and the audio device using a digital optical cable and switch to [Digital Out (Optical)] under [Audio Output Settings].
  • If a device that is not compatible with the HDCP (High-bandwidth Digital Content Protection) standard is connected to the system using an HDMI cable, video and/or audio cannot be output from the system.
(Information taken from here)
Hope it helped.
Nov 18, 2009 | Sony Playstation 3 (PS3) Console
No sound from internal speakers on 1.9 GHz PowerPC G5
Go to System Preferences, then Sound, then Output. Select "Internal Speakers/Built-in Output".
Aug 10, 2009 | Apple Power Mac G5 Desktop
No sound
There are two quick things to try:
1) The TV's speakers may be turned off. To turn on: Press MENU, select "Sound Settings", select "Internal Speakers", then select "On" (as opposed to "Off"), and then EXIT.
2) The Sound source may be set to PIP (picture in picture) instead of Main picture. In that case press MENU, select "Picture", select "PIP", select "Select Sound", then select "Main" (as opposed to "Sub"), as the source of the sound, and then press EXIT.
Whatever PIP is set to may not even be connected to the TV so there would be no sound.
The terms and menus used here are from Samsung so they will be different from yours but the concept is the same.
Good luck,
Techjoel
Apr 26, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
No signal when connected via hdmi to dvi on tv
ya nothing shows up is all black no sound nothing
Oct 27, 2007 | Sony Playstation 3 (PS3) Console
Televison & Video Logo
1,024 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
