Question about HP Color LaserJet 2600n Printer
2600n all 4 cartridges are locked and the printer saying replace supply error
  • HP Master
  • 1,719 Answers
If cartridges are fine, you can Override the Replace Supplies Message. Follow the instructions given below from (Page 146) of HP 2605dn Manual
I have done it myself and it works fine. Let me know if any further clarification/ assistance is required.
Good Luck!
Appreciate generously, if the solution could have been of any help!
CreativeTECH
Posted on Dec 22, 2010
10.103 Supply error
Yellow cartridge is bad, needs to be replaced.
1st try reinstalling the cartridge and power cycling the printer.
If error persists, then replace the cartridge.
Jun 27, 2011 | HP Color LaserJet 2600n Printer
My hp2600n says to replace supplies on display but doesn't say which cartridges need refilling. How do I determine which cartridges need replacing?
If you can print at all, go the the information menu and print the supplies status page which should show which supplies are at 0.
Mar 29, 2011 | HP Color LaserJet 2600n Printer
Printer displays 10.002 error
10.000x Supply error E-label cannot be read or print cartridge is
not properly installed.
10.0000 = Black print cartridge
10.0001 = Cyan print cartridge
10.0002 = Magenta print cartridge
10.0003 = Yellow print cartridge
1 Reinstall print cartridge.
2 Turn on the printer.
3 If the problem is not solved, replace the
cartridge.
Dec 24, 2010 | HP Color LaserJet 2600n Printer
Our HP Color LaserJet printer has a 10.10000 error
try this:
3 If the problem is not solved, replace the cartridge.
Nov 03, 2010 | HP Color LaserJet 2600n Printer
Hp 2600n error 51.22 magenta cartridge, says turn on and off, hel
51.22 is a Magenta laser scanner error.
Try removing the magenta restarting the printer and reinstalling.
If that does not work you likely need a laser assm.
You might want to call a tech. to replace.
Apr 01, 2009 | HP Color LaserJet 2600n Printer
Supply Memory Error
It sounds like you are having two diffrent problems. I don't think they are associated with each other.
First, the memory supply error. The cartridges on this machine have a chip. The chip could very well be faulty causing this supply error message. Change the black cartridge and see if the message clears. if it dosen't then the antena that reads that chip needs to be replaced. I suspect the cartridge is the problem.
Second, the paper jams. This can be caused by a worn p/u roller as you mentioned. Sounds like the jam happens first then the error, based on your description.
The black thing you refer to on the door is called the "transfer belt assembly".
Aug 21, 2008 | HP Color LaserJet 2600n Printer
Supply Memory - Error on Black
A supply memory error is the smart chip on the cartridge. It can also be a physically damaged or locked / froze catridge. In this case the machine is identifying the black cartridge. The first thing to do is replace the cartridge (black).
If it's missing or has a corrupted smart chip lots of weird errors can result but they will usually still direct you to the specific cartridge to replace. If it's a refilled or remanufactured cartridge I would HIGHLY suspect that is the issue.
To locate the smart chip to see if it has come loose, see the picture below:
It's the green little computer board in the picture. Make sure it hasn't come loose. Below is a close-up of the chip. If it is a remanufacture or refill it should look slightly different than shown in the picture as the picture shows an original HP chip. If it's the exact same and a refill, return the cartridge to your supplier.
Hope this helps you. If so hit it with a FIXYA. If not, try to get the printer to print a configuration page or error report and let me know the last couple errors shown by numbers. (Full numbers, like 10.10.1000 or 13.02.05.)
Cheers
Aug 20, 2008 | HP Color LaserJet 2600n Printer
I have installed all new cartridges but the screen says "supply memory error on Magenta"
The question is not complete but try turning the machine off for about 10 mins and this will allow a full reset of the printer.
Jun 25, 2008 | HP Color LaserJet 2600n Printer
PROBLEM WITH PRINTER
"10.001" is probably 10.00.01 and is referring to a supplies error with the cyan toner. Try reseating the toner cartridge as the cartridge mounted chip may not have made good contact with the printer. If this doesn't take care of it, replace the cartridge.
Hope this helps!
Mar 07, 2008 | HP Color LaserJet 2600n Printer
Hp couler laserjet 2600n
There is a chip on the cartridge that is bad or missing. If this an after market cartridge this a common error with the chips. You either need to return the cartridge or find someone that sells the chips fot the cartridge.
Jan 06, 2007 | HP Color LaserJet 2600n Printer
HP Color LaserJet 2600n Printer Logo
797 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
