Question about Intel D845GLLY Motherboard
In My Intel D85GLLY Mother Boar I put two 512MB 133 bus speed RAM. It is working but graphics only 64 MB shows in XP OS. I want to update it 128 MB. How can I update this? please help me.
    Scholar:
  • 105 Answers
HI.
Try this...
Go to Bios settings start pc,, press DEL or F2 depending on the brand of your motherboard to enter BIOS setup.
Check your settings concerning Integrated Graphics. some motherboards may allow memory to be extented.
select your graphics settings... see first if it can be extended. if yes. save and exit. restart pc... and voila
Case contrary.... Install windows xp and correct drivers... it may work smoothly..
Good luck
Posted on Nov 11, 2010
I have intel D845 Mother board with 4 memory (ram) slots one I am using is 256 KB SD RAM & I want to use one 128 KB SD Ram is it possible to use both Thanks.
Hello yeah, you can use both RAMs if they are compatible in terms of bus speed and type like DDR1.
Different types of DRAM modules (eg. DDR200 and DDR266 DIMMs/PC100 and PC133 DIMMs) should not be installed on one motherboard at the same time. This motherboard supports memory modules with capacities of 64/128/256/512MB and 1GB.
Hope this helps
Jan 17, 2011 | Intel Motherboard
I can upgrade to windows 7 in my n1000
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Personally i would recommend to upgrade ram then install win 7
Regards
Uttam
Windows 7 requirement If you want to run Windows 7 on your PC, here's what it takes:
  • 1 gigahertz (GHz) or faster 32-bit (x86) or 64-bit (x64) processor
  • 1 gigabyte (GB) RAM (32-bit) or 2 GB RAM (64-bit)
  • 16 GB available hard disk space (32-bit) or 20 GB (64-bit)
  • DirectX 9 graphics device with WDDM 1.0 or higher driver
http://www.microsoft.com/windows/windows-7/get/system-requirements.aspx
Here is you laptop spec
Processor Processor Intel Pentium M 733 / 1.1 GHz
  • Core voltage technology Ultra Low Voltage (ULV)
  • Data bus speed 400.0 MHz
  • Processor features Enhanced SpeedStep technology , Power-optimized processor system bus
  • Chipset type Intel 855GME
Cache Memory Type L2 cache
  • Cache size 2.0 MB
RAM Installed Size 512.0 MB / 2.0 GB (max)
  • Technology DDR SDRAM - 333.0 MHz
  • Memory specification compliance PC2700
Video Graphics Processor / Vendor Intel Extreme Graphics 2
  • Video Memory Dynamic Video Memory Technology 2.0
Operating System / Software
  • OS Provided Microsoft Windows XP Professional
  • Software Drivers & Utilities
Dec 10, 2009 | Averatec 1000 Notebook
Hardware upgrade required for autocad 2009
Your existing CPU will not work with that motherboard. The AM2+/AM2 processor slot is for AMD processors only. For this motherboard, you will need one of the following processors: Phenom FX / Phenom / Athlon 64 FX / Athlon 64 X2
Jul 06, 2009 | Dell Dimension 8250 PC Desktop
The 256MB SDRAM is showing as 128 MB SD RAM
if you have onboard graphics card that shares the ram memory with your graphics card then the configuration in the bios will determine how much memory is shared with your graphics card so you will lose memory there. Also windows xp does not always report the correct amount of memory so check with cpu z or wcpuid or another utility to check.
Also when you restart your computer when it detects the memory how much does it show that is installed there or if you go into the bios does it show the correct amount.
If it does not then it is not compatable and I would suggest going to www.crucial.com and selecting / getting the correct memory by selecting the correct computer / motherboard that you have.
Apr 10, 2009 | Computers & Internet
More Ram for graphics
You can share the RAM for VGA max of 256 only for some motherboards. On BIOS select the AUTO instead of selecting 128MB share memory.
Mar 24, 2009 | Computers & Internet
Need to know bus speed of Trigem Cognac MB used in HP Pavilion 6730. Is it 100 MHz or 66 MHz?
it's 100 other info as follows:
Component Attributes RAM (standard) 64 MB SDRAM standard Maximum 256 MB (2 x 128 MB DIMM) Speed 100 MHz synchronous Sockets Two 168-pin DIMMs Size 16, 32, 64, and 128 MB DIMMs Type Supported SDRAM, 100 MHz, Intel PC SDRAM unbuffered DIMM specification, revision 1.0 compliant
Cache Level Quantity Level 1 (Primary) 32 KB (on processor) Level 2 128 KB (on processor) Upgrade Sockets None
Dec 09, 2008 | Computers & Internet
I have a P3 at 500MHz and was wondering with this Motherboard,
The motherboard has three, dual in-line memory module (DIMM) sockets. Minimum memory size is 16 MB; maximum memory size is 768 MB. The largest DIMM supported at this time is 256 MB using unbuffered 128 Mbit technology parts. The BIOS automatically detects memory type, size, and speed.
The motherboard supports the following memory features:
  • 168-pin DIMMs with gold-plated contacts
  • 66 or 100 MHz SDRAM
  • Non-ECC (64-bit) and ECC (72-bit) memory
  • 3.3 V memory only
  • Unbuffered Single- or double-sided DIMMs in the following sizes:
DIMM Size Non-ECC Configuration ECC Configuration 16 MB 2M x 64 2M x 72 32 MB 4M x 64 4M x 72 64 MB 8M x 64 8M x 72 128 MB 16M x 64 16M x 72 256MB 32M x 64 32M x 72
Synchronous DRAM (SDRAM) can be installed in one, two, or three sockets. EDO DIMMs are not supported. Memory size and speed can vary between sockets.
Note: Intel® Pentium® II processors with 100 MHz front-side bus should be paired only with 100 MHz SDRAM. Processors with 66 MHz front-side bus can be paired with either 66 MHz or 100 MHz SDRAM.
All memory components and DIMMs used with the Intel® SE440BX-2 motherboard should comply with the PC SDRAM specifications. These include: the PC SDRAM Specification (memory component specific), the PC Unbuffered DIMM Specification, and the PC Serial Presence Detect Specification.
Note: It is recommended that SPD memory DIMMs be used with the SE440BX-2 motherboard. However, the BIOS will allow the use of non-SPD DIMM memory.
So the max you can go is 3 x 256 MB.
Thanks and please take a moment to rate fixya.
Jul 06, 2008 | Intel Desktop Board SE440BX-2 Motherboard
Intel 845 GVSR drivers for windows vista
Fix for older motherboards like Intel 845GVSR etc.,
HERE IS THE SOLUTION FOR FIXING DISPLAY PROBLEMS....
(This solution works for any Intel Motherboard)
No need to donwload or install any drivers.
Vista has everything built in.
Only thing is it needs atleast 128 Mb of Video Memory, but for older motherboards like Inter 845 by default the Video Memory is configured to 64 Mb which is resulting in your problem.
So what you have to do is...
SOLUTION:
Restart your computer > Press DEL Key
and
Go to BIOS Settings > Advanced > Video Configuration
1. Change "AGP Aperture Size" from 64 Mb to "128 Mb or Higher"
2. Leave "Primary Video Adapter" as "Integrated"
3. Change "Frame Buffer Size" from 1 Mb to "8 Mb"
and then press F10(i.e., Save changes and continue).
Sometimes, for the first time you may see screen not aligned properly, in that case just restart once more and Vista will automatically adjust the alignment for you.
Also, you can change the resolution to your desired one manually as follows...
1. Click "Start Button"
2. Right click on "Computer"
3. Select "Properties" option from the context menu.
4. Scroll down and find "Disply Settings" option and click it.
5. Adjust Resolution Size and Mode.
NOW, ENJOY USING VISTA.....
Apr 09, 2008 | Intel D845GVSR Motherboard
When i add a memory in damaged DIMM slot showing black screen?
Try moving the working DIMM to other slots, it should work in any slot, if it does, the other ram u have is incompatible or bad
Install a matched pair of DIMMs (equal in speed: DDR266, DDR333, or
DDR400; density: 64 MB, 128 MB, 256 MB, 512 MB, or 1 GB; and
technology: 128 Mb, 256 Mb, or 512 Mb) in DIMM 0 in both Channels A and
B. If additional memory is to be used, install another matched pair of DIMMs
in DIMM 1 in both Channels A and B.
Mar 25, 2008 | Intel D865GBF Motherboard
Intel D845GLLY Motherboard Logo
104 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
