Question about D-Link DIR-615 Wireless Router
How do I change the security settings on my router
  • 134 Answers
You can plug stright into it with your computer using an ethernet cable and access everthing on it. should of come with a set up disk you may need that also.
Posted on Nov 11, 2010
Securing router from outside user.
Set wireless security to one of the options available. Also, set the router system ID, and change router login password, (record it somewhere, like on the actual router) change the wireless channel to 11 to avoid conflict with landline wireless handsets.
There are higher security settings, but wireless access password is pretty effective.
Oct 04, 2010 | NetGear Computers & Internet
Security setting
wireless security
Is there any computer connected to the router ?
If not then you will need to connect the computer to the router.
Do not change any wireless settings on the router with the wireless computer.
you will need to connect the computer to the router with the Ethernet cable.
check the IP address of the computer.
open the router set up page of the router.
Here you can change the wireless settings of the router.
Now once you change the network anme and security on the router, you will need to connect to the wireless network on your wireless computers.
Click Here for step by step instructions
Aug 12, 2010 | Dell TrueMobile 1184 Wireless Broadband...
Can not connect to internet thorough my dlink 614 router It tells me the internet security key is incorrect even though i know it is not
Please access the web interface of the router and confirm the security key. Also, you can try to change the security key. It can be a possibility that your computer is not synchronizing properly with the current security settings.
If you find that you are putting the right security key then please change the security type to wep 64 bit or wep 128 bit and configure a new key. Also, change the SSID or the network name and try to connect.
In case of any issues please let me know which windows you are running and the security settings on the router.
Thanks,
Rashish
Aug 09, 2010 | D-Link AirPlus DI-614+ Wireless Router
How do you go about securing wireless network connection (linksys)
depends what security you require. just wep or wpa is simple and can be found in the security settings
Jul 18, 2010 | Linksys Wireless-G WRT54G Router
I want to secure my wireless conection
to secure your wireless register for www.opendns.com it can help secure your router wireless internet try it now
Jun 18, 2010 | Linksys WRT160N Wireless Router
Just purchased iMac with Snow Leopard OS. Apple tech spt states WEP broadcasts incompatible with OS. Need to update router to WPA or WPA-2. How do I do this with DI-614+
Basically ypu will need to change the wireless settings of the router.
To change the wireless settings you will need to access the router set up page.
Is there any computer connected to the router? If not then you will need to connect one computer to the router with the cable. Open the set up page of the router and change the wireless settings of the router. When you change the wireless security settings, change the wireless network name also ( SSID ). Once you change the SSID and the security on the router, you will need to connect to the wireless network on all the wireless devices with the new network name and security
Click here for step by step instructions
Mar 21, 2010 | D-Link AirPlus DI-614+ Wireless Router
How do I change my security settings in my dir 600
You want to secure the wireless network.
Is there any computer connected to the router with the Ethernet cable?
If not then you will need to connect the computer to the router with the cable. Do not change wireless settings using a wireless computer.
Check the IP address on the computer. Open the router set up page.
Once you open the set up page, you will find the option to make it secured
Mar 01, 2010 | D-Link DIR-600 Router
Ip address wrong, showing 192.168.254.1
Solution Overview
This article explains how you can avoid having to run the Wireless Configuration Utility or Wireless Setup Assistant (Macintosh) after making changes to the router's security settings. The need to change these settings can arise if users forget their network key/passphrase or router web server password or if you have security concerns.
Printer response to security settings changes
The printer will respond with a flashing orange (pattlnk_6172008_1844-orgblksml.gif) Wi-Fi indicator light after the following actions are performed on the network or router/access point (AP):
  • -A change to the Service Set Identifier (SSID) or network name.
  • -A change to the security type (none, WEP, WPA, or WPA2 personal).
  • -A change to the security network key/passphrase.
  • -A hard reset of the router followed by entry of security values that are different from the original values.
  • -The printer is moved to a network (AP) that has different security values but already has installed drivers and created ports. NOTE: Port reconfiguration may be required in this case. Click here for instructions.
In order to rejoin (associate and authenticate) the wireless network (WLAN), the wireless client (printer) has to be reconfigured with the router's new SSID, security type, and network key. This requires connecting the USB configuration cable to the host computer and running the Wireless Configuration Utility or Wireless Setup Assistant to apply the new security settings on the printer's wireless network adapter.
Solution: Change the printer settings first
Change the security settings on the printer while it is still communicating on the network before making the changes on the router. Understand that this will cause a temporary change in the Wi-Fi indicator light from pattlnk_6172008_1952-tn_grnsolproof.jpg to pattlnk_6172008_1844-orgblksml.gif. After you have made equivalent changes on the router, the printer's Wi-Fi indicator light will return to pattlnk_6172008_1952-tn_grnsolproof.jpg.
Procedure: How to change security settings via the embedded web server
If you change your AP security settings frequently, this procedure is for you.
  1. Open your web browser application and enter the printer IP address into the web address field, i.e. http://ip_address.
  2. Click on Configuration.
  3. Click on Wireless.
  4. Enter the SSID, security type/encryption, and network key that will be used to configure the router.
  5. Click Submit.
Jan 16, 2010 | Lexmark X6650 4-In-One Wireless InkJet...
Need to change password from previously changed password
To secure the wireless network or to change any settings on the router you will need to access the router set up interface.
Open the set up interface of the router . Make sure that your computer will be connected to the router with the Ethernet cable.
Once you open the set up page of the router , you will find the place to change the wireless settings of the router. In case of Linksys wireless router , you will see the Wireless Tab at the top.
SSID : It is the name of the wireless network. This name will be shown on your wireless computer or the wireless device so that you can identify your own wireless network. All the routers come with their factory default settings. For example , the Linksys router will come with the Linksys network name.
It will be better to change the wireless network name.
Wireless Security
Change the security mode to WEP. This security type is supported by all the operating system. When change the security mode to WEP, you will find the Network key box to type the network key. Do not type anything in the Passphrase box. Type your network key in the Key 1 Box. If you set the encryption to 65 bits, your network key will be 10 digit hexadecimal number. that means you can use the combination of 0,1,2,3,4,5,6,7,8,9 and letters a,b,c,d,e,f only. remember it should be exactly 10.
If you set the Encryption to 128 bit, your network key will be the combination of 26 digits. You will need to remember the network key.
WPA
This is one of the most secured type of encryption.
Open the set up interface of the router. Change the wireless security mode to WPA personal. You will find the passphrase box. in this box you can type any password for your wireless network. The password should be the combination of number and letters and it should be 8 or more than 8 characters.
This security type is supported by WINDOWS XP SP2 and above Operating system.
WPA2
This is one of the highly secured type of encryption.
Open the set up interface of the router. Change the wireless security mode to WPA personal. You will find the passphrase box.In this box you can type any password for your wireless network. The password should be the combination of number and letters and it should be 8 or more than 8 characters. Keep the Algorithm to TKIP.
This security type is supported by WINDOWS VISTA and above.
Once you change the wireless settings on the router , try to connect to the new wireless network
Click Here for more info
Dec 19, 2009 | 2wire 1800HG Router (RG1800HG00)
Ntel(R) Wireless WiFi Link 4965AGN i want to
Wireless Security
WPA
WPA2
Once you change the wireless settings on the router , try to connect to the new wireless network .
Dec 16, 2009 | Computers & Internet
D-Link DIR-615 Wireless Router Logo
87 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
