Question about VIDAR Systems VIDAR TruScan Select Pro
Need a fuse for vidar scanner p-87? I know its bussman gdb f 6.3 AL, 250 volts. I need to know where to order.
Replace the lamp of 4230i
Nabil, Check the attached links how to replace lamp.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Contex HD5450 User Manual Replacing The Scanner Lamp unit
Contex FLEX50i User Manual Replacing The Scanner Lamp unit
. ContexParts buy parts and accessories for Contex Vidar and Ideal scanners...
Mar 07, 2016 | Contex H42-6799G513 - Hd Ultra 4230
The 6.3 amp 125volt fuse blew. Do you know what the part number is so I can order a new fuse? Thanks, Fred
a known manufacturer is BUSSMAN fuse BK/GMC-6.3A
you can find this brand everywhere. just make sure you do NOT use anything higher voltage.
good luck
Mar 24, 2011 | Sony STR-DE685 Receiver
Hi My wife was watching our 2002 Panasonic CT36SX12CF model t.v last night, all of a sudden there was a pop noise and the screen went black. The tv would not turn on again. Any ideas what the problem...
hey Al more than likelly it was the fuse that popped if you take the back panel off the fuse is next to the power cord and should take a 6.3 amp 125-250 volt fuse
Oct 31, 2010 | Panasonic CT-36SX12 36" TV
Can the vidar truscan p-88 4019 do color?
This scanner does black&white and gray-scale scanning but not color.
I hope this helps.
Aug 31, 2010 | VIDAR Systems VIDAR TruScan Select Pro
I don't have driver for truscan titan yet
hi,
hope this can help you for your truscan titan drivers update at the link below.
http://support.vidar.com/default.htm
Nov 28, 2008 | VIDAR Systems VIDAR TruScan Titan II
Software driver for vidar true scan select plus
Try this:
1. To obtain the driver, go to ftp://ftp.vidar.com/pub/sti drivers/ and
download "autocd.exe".
2. Run "autocd.exe" and the contents will be extracted to a folder.
3. In the Windows Control Panel, open the Device Manager (Control Panel->
System->Hardware Tab->Device Manager) and select the Driver tab within
the Vidar Scanners properties.
4. Click on "Update Driver" and browse to the STI folder (unpackaged from
autocd.exe).
May 09, 2008 | Office Equipment & Supplies
Minolta Dimage Scan Dual ll
Hello ! I try to use many difrent driver in difrent mod. eks:95,98,2000,xp
The best was 98,butt it still stops when the scanning starts.
Solution for my problem.......Vuescan from Hamrick.com
Mvh
Vidar
Norway
Feb 24, 2008 | Minolta Dimage Scan Dual II Film Scanner
Vidar select Pro Bulb? Blown out?
An E-mail to the makers web site will tell you whether parts are available for self fit or you need the expensive repair dude.
Nov 21, 2007 | VIDAR Systems VIDAR TruScan Select Pro
VIDAR Systems VIDAR TruScan Select Pro Logo
97 people viewed this question
Top VIDAR Systems Office Equipment & Supplies Experts
k24674
Marvin
Marvin
Are you a VIDAR Systems Office Equipment and Supply Expert? Answer questions, earn points and help others
