Question about Arris SURFboard SBG900 (49402201900) Modem
I need to dmz my motorola router it is a Motorola SURFboard SBG900 or 800 Modem
What kind of router do I need to get so I can get wifi out of a Motorola Surfboard SB5101 Cable Modem ? My PC isn't wifi compatible but I have other equipment that are.
You will want to get a "Wireless N" Router, also known as an 802.11n Router. Price range is up to you, but here is a relatively cheap one that performs well: http://goo.gl/Szjovd
Dec 18, 2013 | Arris SURFboard® SB5101 Cable Modem
I have the Motorola SBV5120 SURFboard Cable Modem now because we upgraded to optimum now i do not know how to find the WEP Key on this modem please help me
The Motorola SBV5120 cable modem does not have wireless capabilities and therefore does not require WEP encryption key. There is no WEP setting available for this cable modem.
Jul 02, 2011 | Arris SURFboard SBG900 Wireless Router...
I want to plug in another wireless router into my surfboard modem and have the wireless router work as well as the surfboard. Is there a way to do this successfully?
Yes this is possiable. First you need to unplug the power to the Motorola and the new router. Second connect the ethernet cable from the Motorola to the internet port on your second router. This port may be colored in yellow, marked as modem, or the ethernet port by its self. Third connect a ethernet cable from the new router to a desktop or laptop this is only to configure the new router. Next power on the Motorola and wait for the online light to become solid. Then plug in the power to the new router. Give the router about two minutes to obtain ip address from the motorola then try to get on the internet with the pc connected with the ethernet cable. Now you can run the new router setup cd on the wired pc to setup router. Once completed remove ethernet cable to the pc and connect to either network you have and you are good to go. Any questions just ask.
Dec 30, 2010 | Arris SURFboard SBG900 Wireless Router...
I cannot find the security key on the bottom of my motorola surfboard modem
Contact your local Internet Service Provider for assistance with your cable-modem.
Or, if you have connected a wireless-router to the cable-modem, and now you are trying to connect a wireless-device to the wireless-router, that's where a "security-key" is needed.
Dec 20, 2010 | Arris SURFboard SBG900 (49402201900) Modem
I need help connection my motorola surfboard modem, to my belking wireless router... I've attached all wiring and powered down everything like the instructions say, but my router still doesn't seem to be...
you will need to set up the router manually.
First make sure that your computer is able to go online when connected to the motorola modem only.
Click Here for step by step solution
Nov 04, 2009 | Arris SURFboard SBG900 Wireless Router...
How to connect 2wire 2700 HG-B router to voice modem motorola
that 2wire only works with DSL services, if you are using cable internet then no it wont work. If the surfboard digital voice is just a VOIP router then yes, plug the surfboard into one of the ethernet ports on the back of the 2wire.
Jun 06, 2009 | 2wire 2700HG-B Router (2700HGB)
Xbox 360 live troubleshooting
Assign a static IP address to the 360, then go into your router's setting and set a DMZ for that static IP.
Oct 25, 2007 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Arris SURFboard SBG900 (49402201900) Modem Logo
455 people viewed this question
Top Arris Computers & Internet Experts
Jerry
Jerry
Suddenlink Help
Level 1 Expert
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
