Question about Lexmark X5495 Printer
CARTUCHO DE TINTA ERROR 1203 - Lexmark X5495 Printer
  • 53 Answers
SOURCE: tengo una impresora lexmark Z2320 recargue los
Lexmark no es compatible con los cartuchos rellenados.
Posted on May 18, 2009
pineworks
  • 4041 Answers
SOURCE: error el cartucho de tinta 02 de una impresosa hp
HI
You can try
Reset the product:
  1. Without turning off the product, disconnect the USB cable from the rear of the product.
  2. Remove the cartridges from the product.
  3. Wait for the 'Insert Cartridges ' message to display on the control panel.
  4. Disconnect the power cord from the back of the product.
  5. Wait 60 seconds.
  6. Reconnect the power cord. If the product does not automatically turn on, press the Power button (c01602202.gif ).
  7. Reinsert the cartridges, and then close any open doors on the product.
  8. If you receive a prompt to print a calibration page, do so.
  9. Reconnect the USB cable to the rear of the product, and then try printing again.
  10. All The Best: Pineworks
Posted on Jan 25, 2010
pineworks
  • 4041 Answers
SOURCE: Cartucho de tinta preto incompatível
INK TANK
Posted on Mar 22, 2010
MUKHTAR
  • 2022 Answers
SOURCE: acabo de cambiar los cartuchos
You need to do some basic troubleshooting steps below and hope that it would fix the problem.
  • Disconnect the Universal Serial Bus (USB) cable from the back of the product, but leave the product turned on.
  • Open the cover of the product and remove the print cartridges.
  • Close the cover and wait for the Insert Ink Cartridges message to display.
  • Disconnect the power cord from the back of the product and the wall socket, then wait for one minute.
  • Reconnect the power cord. If the product does not automatically turn on, press the Power button.
  • Open the cover and reinsert the print cartridges.
  • Close the cover. If prompted, print a calibration page.
  • Print a Self Test to verify product is functional.
  • Reconnect the USB cable, and try to print from the computer.
Try doing:
1. Unplug the power cord from printer.
2. Hold both o.k and Cancel simultaneously.
3. Plug the power cable while holding the buttons
Ink System Failure message. The error code shows was '0xc18a0005'. The tech had me press and hold the '*' key on the key pad, then press the '#' key and release them both. Then he had me enter '123' to enter maintenance mode. He then had me press the right arrow (beside the OK button) until System Config. menu appeared on panel. Then pressed OK two times to clear the error condition, then cancel two or three times to return to the top menu. Then powered off and back on,
Hope this helps. Please rate my response.
Thanks.
Have a good day
Posted on Dec 27, 2010
  • 304 Answers
SOURCE: como remover y poner los
Segun el modelo Mantener el boton pulsado hasta que el carro se visualice y puedas remover los cartuchos.
Posted on Jul 01, 2011
ES IMPRESORA Y SCANNER. NO PUEDO USARLA SOLO COMO SCANNER AUNQUE NO TENGA TINTA????
Muchos de los lectores tienen una funci?n de copia que utiliza la impresora . Usted puede ser capaz de comprar cartuchos de tinta para que o tal vez rellenado de los cartuchos de tinta si el coste es un problema. Creo que ser?a necesario de tinta para poder utilizar el esc?ner debido a la funci?n de copia.
Dec 31, 2014 | Office Equipment & Supplies
Mi impresora canon mp280 me sale el error b200 que puedo hacer..la tinta ya no corre
pruebalo con uno de los cartuchos afuera. si es que ves que tiene alguna reaccion diferente a lo que con los dos cartuchos tienes que cambiar ese cartucho que sacaste. yo tenia el mismo problema, lo cambie el cartucho de colores que era el que estaba mal y luego lo resetee y todo ok. mientras no lo cambias ese cartucho el reseteo no funciona.
Feb 24, 2012 | Office Equipment & Supplies
En mi impresora lexmark marca error 1203 ya limpie los contactos de cobre y sigue mismo error
Podría ser debido a un cartucho defectuoso. Trate de insertar un cartucho de diferentes conocidos de trabajo para determinarsi el otro está defectuosa.
Jul 28, 2011 | Lexmark X5470 All-In-One InkJet Printer
Impresora bloqueada y no detecta cartuchos de tinta
Trate de limpiar los inyectores de los cartuchos. Si estás utilizando Windows, vaya a Todos los programas o Programas y, a continuación, seleccione la carpeta de programa de la impresora de la> lista de la carpeta de la impresora, haga clic en Mantenimiento - Alinear cartuchos> haga clic en Imprimir> Siga las instrucciones en la pantalla del ordenador hasta el final.
Si está utilizando Macintosh, desde el escritorio del Finder, haga doble clic en la carpeta de la impresora> haga doble clic en el icono de la utilidad de la impresora> En la ficha Mantenimiento, haga clic en Limpiar inyectores de impresión. Una página se imprime, la tinta pase por los inyectores del cartucho de impresión para limpiarlos. Imprimir el documento para comprobar que la calidad de impresión ha mejorado.
Nota: Esto se traduce utilizando translate.google.com.
Jun 18, 2011 | Lexmark X2600 InkJet Printer
En mi imprsora lexmark me sale error 1203 cual es la solucion a mi problema gracias
El error 1203 son un asunto que ocurre o cuando un cartucho es malo o la Ranura de cartucho de impresora es mala...
1 - intenta de limpiar los contactos de cobre de la ambas ranura de carritos y carrito en la impresora y tratar otra vez.. O 2 - cuando error aparece,
cierre el poder de impresoras lejos; espere un minuto y g?relo atr?s en copia de prensa.
Si necessita mas asistencia, permita que sepa. Si esto ayuda o resuelve el asunto, por favor lo valora y da una recomendaci?n para mi respuesta. Gracias, Jose
Feb 25, 2011 | Lexmark X4270 All-In-One InkJet Printer
Deseo saber si el cartucho se puede recargar ?y cuantas veces?porfavor........
Los consumidores pueden rellenar cartuchos de tinta s? mismos con un juego, o ellos pueden tomar el cartucho a un refiller o el remanufacturer donde tinta es bombeada atr?s en el cartucho. Los informes del Mundo de computadora personal que rellenaron cartuchos tienen porcentajes de aver?as m?s altos, la impresi?n menos p?ginas que nuevos cartuchos, y demuestran m?s problemas de en-p?gina como pasar como un rayo, rizar, y el color sangran
Jan 14, 2011 | Office Equipment & Supplies
LEXMARK X3550
Quite los cartuchos. y asegúrese que las pequeñas cintas protectoras han sido quitadas de los contactos. Entonces examine donde los cartuchos caben en la impresora. ¿Es limpio en allí? ¿Hay allí alguna tinta secada o gotas de la tinta en allí? Si hay, usted puede apagar y desenchufar la impresora y usar una cantidad diminuta del alcohol desinfectante en un Qtip para limpiar la tinta.
Si no sustituyen los cartuchos que se los aseguran adecuado cómodamente. Ahora continúes su computadora a - Principio> Panel de instrumentos> impresoras y faxes> chasquido DERECHO en su icono de impresora y elija preferencias> servicios. Cuando usted está en servicios abiertos y mira cada opción allí. Haga cualquier prueba o limpieza de los cartuchos a los cuales esto le pregunta. Cuando usted es terminado, apaga su impresora y reanuda su computadora. Si el problema no es ido, contestarme. Espero que mi español sea comprensible. Gracias.
Aug 19, 2008 | Lexmark X3550 All-In-One Printer
Lexmark X5495 Printer Logo
79 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
