Question about Kenmore Dishwashers
My dishwasher has always cleaned dishes well. (I usually rinse before placing dishes in the dishwasher.) The unit is app. 15 years old. Recently I've noticed a white film, especially on plastic items like measuring spoons. I've tried reducing detergent and changing brands (now using Cascade). My water is very hot.
  • Kenmore Master
  • 43,501 Answers
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried invain to clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if theheating element goes bad then that also can mess things up bad... So I wouldbuy new spray arms, and also check out the heating element to make sure it isworking... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Posted on Nov 11, 2010
Ge dishwasher not cleaning dishes and leaving debris behind
check for corrosion or debris in the water jets clean if necessary
Mar 11, 2012 | Dishwashers
Hello ! We have a Whirlpool "Quiet Wash Plus" dishwasher that is approx 12yrs old. It has performed exceptional over this time, but notice recently it does not get the dishes as clean as before....
Is the water level ok? Check your water temp into the tub. It needs to be a minimum 120 degrees. Check for plugged spray arms. Do they turn freely? Does dishwasher drain completely?
Sep 25, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Dishes are not cleaning well
I often get calls similar to this client: Over the past several weeks-months, have been getting a whitish film/deposit on pots, tops of some plastic cups, etc. You don't really see it on plates.
Typically this is caused when someone switches detergent usually to a liquid gel. It is almost always because we use too much soap.
One of my most appreciated recommendations follows:
My suggestion is to throw the liquid away and use the Cascade Complete or Finish tablets. Place one in the bottom of the dishwasher. Do not put them in the dispenser.
The reason for this is you want the soap (abrasive) at the front end of the cleaning process so that the last little bit of food that is left on the dishes (I'm assuming you are rinsing your dishes) is blasted off and then the dishwasher can "sanitize" the dishes with water that is too hot for you to handle. That is the real purpose of a dishwasher.
Keep in mind that if you rinse your dishes well before placing them in the dishwasher you can probably use the shortest cycle and save quite a bit of money on electricity and water over the course of a year.
Also, take a coffee cup and fill it half way with white vinegar and place it upright in the top rack with your next load of dishes. Do this for the next several loads and then once per month for as long as you own and use a dishwasher.
Sep 02, 2011 | KitchenAid 24 in. KUDS01FLSS Built-In...
My dishes come out dirtier then when they went in. I usually rinse my dishes before I put them in because the dishwasher won't clean them. I tried cleaning the two filters today and this didn't help. I...
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Mar 20, 2011 | Bosch SHU9955UC Built-in Dishwasher
My kitchenaid dishwasher leaves a white residue on clean dishes. 4 year old appliance, worked great until 6 months ago. under warranty, service repairman said i was using too much soap( am not). he cleaned...
The scum, film and white residueproblems have started since the reductionof phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
heatman101
Mar 10, 2011 | KitchenAid 24 in. KUDS01FLBL Built-in...
My 5-year old Bosch dishwasher leaves a somewhat fine grit on dishes? especially obvious on the inside of glasses. I use only Cascade detergent, use a rinse aid, don't overfill the machine, and always...
I have the same problem with mine!! It's 6 years old, and I'm running loads of dishes through twice. Even that doesn't help! And I rinse the dishes too, so I have no idea where all these "crumbs" are coming from. Will check back for updates. Hope to get this problem solved!
Oct 01, 2010 | Bosch 24 in. SHU6802UC / SHU6806UC...
White film on dishes, glasses and silverware.
white film is actually from the calcium and magnesium found in hard water. your dishwasher is fine. its the water leaving the residue and spots. go to www.dishwasherfilter.com . they have a new product out exactly for this reason. very affordable and works amazing. you will love it.
Oct 06, 2009 | Dishwashers
Dishes have filmy finish
hello. this will help a great deal.
First of all empty out your dishwasher, toss in two cups of plain white or cider vinegar and run it on the highest and longest cycle.
Always run the hot water in the sink first and start the dishwasher only when the water is as hot as it will get.
This wash will clean out your dishwasher thoroughly.
Then always do your dishes after you have rinsed any residue off of them before placing them in the dishwasher and I always recommend the pot scrubber cycle if you have one.
Jul 07, 2009 | Dishwashers
Dishwashers Logo
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
